<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gateway using Odroid-N2 via 40pin-&gt;SPI]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've made necessary changes to MySensors 2.4.0-alpha in order to work on Odroid-N2 SBC running Ubuntu 21.04 with 5.13.0 kernel<br />
Library would have worked if every reference to pin number was at least uint16_t (not uint8_t, like it is). That's because Odroid-N2 have &gt;2^8 pin numbering, and GPIO ranges in 460-490 decimal.</p>
<p dir="auto">I've made my fork@github and pushed odroid-n2 required changes version.<br />
Using polling (non-IRQ) mysgw drains 1.0% cpu time.<br />
Still waiting for interrupt issues to resolve with HK team - hopefully soon.</p>
<p dir="auto">Github repo @ <a href="https://github.com/Gobol/MySensors" rel="nofollow ugc">https://github.com/Gobol/MySensors</a></p>
]]></description><link>https://forum.mysensors.org/topic/11772/gateway-using-odroid-n2-via-40pin-spi</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 00:24:22 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11772.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Aug 2021 16:50:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gateway using Odroid-N2 via 40pin-&gt;SPI on Tue, 02 Nov 2021 13:57:28 GMT]]></title><description><![CDATA[<p dir="auto">My repo depends on hardkernel's linux kernel, esp. 4.9.277. It won't work with kernels &gt;4.9 for Odroid N2, because the developers left GPIO subsystem down (no IRQs, no /dev/gpiomem), and it only works partially...</p>
]]></description><link>https://forum.mysensors.org/post/111196</link><guid isPermaLink="true">https://forum.mysensors.org/post/111196</guid><dc:creator><![CDATA[Bogusz Jagoda]]></dc:creator><pubDate>Tue, 02 Nov 2021 13:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to Gateway using Odroid-N2 via 40pin-&gt;SPI on Tue, 05 Oct 2021 19:21:35 GMT]]></title><description><![CDATA[<p dir="auto">Nice work <a class="plugin-mentions-user plugin-mentions-a" href="/user/norton" aria-label="Profile: Norton">@<bdi>Norton</bdi></a>, thanks for reporting back!</p>
]]></description><link>https://forum.mysensors.org/post/111045</link><guid isPermaLink="true">https://forum.mysensors.org/post/111045</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Tue, 05 Oct 2021 19:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to Gateway using Odroid-N2 via 40pin-&gt;SPI on Tue, 05 Oct 2021 18:11:36 GMT]]></title><description><![CDATA[<p dir="auto">Solved - it was problem with armbian. i changed it to hardkernel´s ubuntu and now it working.<br />
Thanks.</p>
]]></description><link>https://forum.mysensors.org/post/111044</link><guid isPermaLink="true">https://forum.mysensors.org/post/111044</guid><dc:creator><![CDATA[Norton]]></dc:creator><pubDate>Tue, 05 Oct 2021 18:11:36 GMT</pubDate></item><item><title><![CDATA[Reply to Gateway using Odroid-N2 via 40pin-&gt;SPI on Sun, 03 Oct 2021 20:52:25 GMT]]></title><description><![CDATA[<p dir="auto">i tried it on my odroid N2 with Ubuntu 21.04, kernel 5.14.0 but i can't get it work. I got this error:</p>
<pre><code>Could not open /sys/class/gpio/gpio9/direction
</code></pre>
<p dir="auto">i used your github repo. I don't know what is wrong or did i forget something?</p>
]]></description><link>https://forum.mysensors.org/post/111039</link><guid isPermaLink="true">https://forum.mysensors.org/post/111039</guid><dc:creator><![CDATA[Norton]]></dc:creator><pubDate>Sun, 03 Oct 2021 20:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to Gateway using Odroid-N2 via 40pin-&gt;SPI on Mon, 20 Sep 2021 04:36:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/norton" aria-label="Profile: Norton">@<bdi>Norton</bdi></a> yep, it works in polling mode (~1% of cpu).</p>
]]></description><link>https://forum.mysensors.org/post/110980</link><guid isPermaLink="true">https://forum.mysensors.org/post/110980</guid><dc:creator><![CDATA[Bogusz Jagoda]]></dc:creator><pubDate>Mon, 20 Sep 2021 04:36:44 GMT</pubDate></item><item><title><![CDATA[Reply to Gateway using Odroid-N2 via 40pin-&gt;SPI on Sun, 19 Sep 2021 06:50:12 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
i plan to replace RPI 3B and use odroid n2 also via 40 pin SPI bus. Is your library working? Thanks for your work.</p>
]]></description><link>https://forum.mysensors.org/post/110969</link><guid isPermaLink="true">https://forum.mysensors.org/post/110969</guid><dc:creator><![CDATA[Norton]]></dc:creator><pubDate>Sun, 19 Sep 2021 06:50:12 GMT</pubDate></item></channel></rss>
