<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problem with button and mqtt after restart gateway]]></title><description><![CDATA[<p dir="auto">Hello everyone.</p>
<p dir="auto">I am a beginner ;)<br />
Based on the sketch from this forum, I wrote my own with control the switches, one button and a temperature sensor.<br />
If it i turn led on/off from HA, the state is written in eeprom and mqtt . However, if you control it with the button, state changes in HA (everything seems ok) but after restarting the gateway, the state is correct for a while (read from epreom I think), but after establishing the connection to the broker, led is switch to  state is as the last one in HA (by clik).</p>
<pre><code>// Enable debug prints to serial monitor
//#define MY_DEBUG
#define MY_BAUD_RATE 9600
//#define MY_RADIO_RF24
//#define MY_RADIO_RFM95
#define MY_GATEWAY_ESP8266
// Set MQTT client id
// Enable these if your MQTT broker requires username/password
#define MY_MQTT_USER "***"
#define MY_MQTT_PASSWORD "***"
// Set WIFI SSID and password
#define MY_WIFI_SSID "***"
#define MY_WIFI_PASSWORD "***"
// passed to the DHCP server if not static.
#define MY_HOSTNAME "ESP8266_MQTT_GW"
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 100
//MQTT broker if using URL instead of ip address.
// #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
#define MY_PORT 1883
// Enable inclusion mode
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
#include &lt;MySensors.h&gt;
#include &lt;SPI.h&gt;
#include &lt;Bounce2.h&gt;
#include &lt;DHT.h&gt;
#define DHT_DATA_PIN D5
#define DHTTYPE DHT11     // typ czujnika (DHT11). Jesli posiadamy DHT22 wybieramy DHT22
#define SENSOR_TEMP_OFFSET 0
// Must be &gt;1000ms for DHT22 and &gt;2000ms for DHT11
#define CHILD_ID_HUM 3
#define CHILD_ID_TEMP 4
#define CHILD_ID_LIGHT 5
float lastTemp;
float lastHum;
uint8_t nNoUpdatesTemp;
uint8_t nNoUpdatesHum;
bool metric = true;
//czyjnik światła
int lastodczytanaWartosc = 0;
DHT dht(DHT_DATA_PIN, DHTTYPE);
#define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
#define RELAY_OFF 1
#define noRelays 3                     //2-4
#define noButtons 1
const int relayPin[] = {D2,D3,D6};          //  switch around pins to your desire
const int buttonPin[] = {D1};      //  switch around pins to your desire
class Relay             // relay class, store all relevant data (equivalent to struct)
public:
  int buttonPin;                   // physical pin number of button
  int relayPin;             // physical pin number of relay
  int value;
  boolean relayState;               // relay status (also stored in EEPROM)
Relay Relays[noRelays];
Bounce debouncer[noRelays];
MyMessage msg[noRelays];
MyMessage msgIlu(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
void setup(){
    sendHeartbeat();
    wait(100);
    dht.begin();
    // Initialize Relays
    for (int i = 0; i &lt; noRelays; i++){
   // Relays[i].buttonPin = buttonPin[i];              // assign physical pins
    Relays[i].relayPin = relayPin[i];
    msg[i].sensor = i;                                   // initialize messages
    msg[i].type = V_LIGHT;
   // pinMode(Relays[i].buttonPin, INPUT_PULLUP);
   // wait(100);
    Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
    digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
    send(msg[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
    wait(50);
    //debouncer[i] = Bounce();                        // initialize debouncer
    //debouncer[i].attach(buttonPin[i]);
    //debouncer[i].interval(20);
    //wait(50);
     // Initialize Button
    for (int i = 0; i &lt; noButtons; i++){
    //msg[i].sensor = i;                                   // initialize messages
    //msg[i].type = V_LIGHT;
    wait(100);
    //pinMode(Relays[i].relayPin, OUTPUT);
    //Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
    //digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
    //send(msg[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
    //wait(50);
    wait(50);
void presentation()  {
      sendSketchInfo("MultiRelayButton", "1.0");
      wait(100);
      present(i, S_LIGHT);                               // present sensor to gateway
     present(CHILD_ID_HUM, S_HUM);
     wait(100);
     wait(100);
  // pomiar światła
  int odczytanaWartosc = analogRead(A0);
    if (odczytanaWartosc != lastodczytanaWartosc) {
        send(msgIlu.set(odczytanaWartosc));
        lastodczytanaWartosc = odczytanaWartosc;
    sleep(30000);
  float temperature = dht.readTemperature();
  if (isnan(temperature)) {
    lastTemp = temperature;
    // Reset no updates counter
    nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
    Serial.print("T: ");
    Serial.println(temperature);
  } else {
    nNoUpdatesTemp++;
  float humidity = dht.readHumidity();
  if (isnan(humidity)) {
    lastHum = humidity;
    nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
    Serial.print("H: ");
    Serial.println(humidity);
  } else {
    nNoUpdatesHum++;
  sleep(UPDATE_INTERVAL);
  // relay&amp;button
    for (byte i = 0; i &lt; noRelays; i++) {
        if (debouncer[i].update()) {
            Relays[i].value= debouncer[i].read();
            if(Relays[i].value == LOW){
              saveState(i, !loadState(i));
              digitalWrite(Relays[i].relayPin, loadState(i)?RELAY_ON:RELAY_OFF);
              send(msg[i].set(loadState(i)));
              // save sensor state in EEPROM (location == sensor number)
              //saveState( i, Relays[i].relayState );
    wait(20);
// process incoming message
void receive(const MyMessage &amp;message){
   if (message.type == V_LIGHT){
   if (message.sensor &lt;noRelays){            // check if message is valid for relays..... previous line  &lsqb;&lsqb;[ if (message.sensor &lt;=noRelays){ &rsqb;&rsqb;]
   digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
   saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
  wait(20);
</code></pre>
<p dir="auto">What am I doing wrong? :D<br />
please help</p>
]]></description><link>https://forum.mysensors.org/topic/11825/problem-with-button-and-mqtt-after-restart-gateway</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:21:05 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11825.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Oct 2021 14:52:02 GMT</pubDate><ttl>60</ttl></channel></rss>
