<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gyroscope calibration]]></title><description><![CDATA[<p dir="auto">This is my first time using the gyroscope to measure angular velocity so I don't have much experience in gyro calibration. When using my gyro, I found its error to be quite large. I understand that, due to bias stability, the gyro will not output zero even when it is not moving and its output will also drift over time but although I have tried to choose a gyroscope with a relatively low bias stability, the error is still quite high compared to my expectation. I am thinking that, maybe it measure the angular velocity of Earth as well. So is there any way i can only measure angular velocity relative to the body frame (change configuration mode,...)? Or are there any other effective ways to calibrate the gyro by coding?<br />
Thank you so much!</p>
]]></description><link>https://forum.mysensors.org/topic/11888/gyroscope-calibration</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 16:38:52 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11888.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Jan 2022 09:02:03 GMT</pubDate><ttl>60</ttl></channel></rss>
