<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Local Sensors on Raspberry Pi Gateway]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/11596/raspberry-pi-ethernet-gateway-with-local-sensors">Raspberry Pi Ethernet Gateway with local sensors</a></p>
<p dir="auto">Currently I have an RPi as an irrigation controller.  It controls 10 relays in a cross-bar configuration to control 25 valves.  This program is written in C++.</p>
<p dir="auto">Running on the same RPI is another process controlling the water lift system to move water a higher level (which will be the source of the water for the gravity fed irrigation)  This process uses the nRf24L01 radio to talk to 4 Arduinos, each of which monitors the water levels in a holding tank and controls a pump relay)  This is also written in C++ and relies heavily on the libraries (and help) of <a href="https://tmrh20.github.io/" rel="nofollow ugc">TMRh20</a></p>
<p dir="auto">This latter process screams MySensors, and Home Assistant.  I am in the process of converting.</p>
<p dir="auto">But my irrigation controller will still be on the same RPi.  Surely there must be a way to have intra-computer communication from a sensor to a gateway?  The most simple way would be to put another RF24 radio on the RPi, assuming that I can run a second radio by using CE1 instead of CE0 and maybe a different pin for CSN</p>
<p dir="auto">I found the discussion <a href="https://forum.mysensors.org/topic/937/rpi-as-a-node">Pi as a node</a> but it didn't have any concrete examples.  In <a href="https://forum.mysensors.org/topic/5488/rpi-as-a-node">similar topic</a> there was no discussion.  There were a couple of suggestions of modifying mysgw using the --my-gateway=none parameter, but I need a gateway, so I'd have two instances of mysgw and it still leaves with the problem of getting the data to the functional gateway.</p>
<p dir="auto">There were a couple of notes that the RPi is very expensive compared to a Nano ($50 vs $5)  Even still, I need 10 I/O's and after the radio, and debug I/O, the Nano would only have 6 (3-8). No, wait! I could use 4 analog ports, too.</p>
<p dir="auto">Thus I could port my irrigation controller to a Nano.  Or, I could using an Nano as a gateway gateway and just modify my existing code to talk to it over the USB port.  Not the elegant solution I sought.</p>
<p dir="auto">Still RPi running a gateway and one or more local sensors.  Has anyone done this?</p>
<p dir="auto">OSD</p>
]]></description><link>https://forum.mysensors.org/topic/11937/local-sensors-on-raspberry-pi-gateway</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 17:11:13 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11937.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Apr 2022 20:07:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Local Sensors on Raspberry Pi Gateway on Tue, 06 Dec 2022 22:45:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a></p>
<p dir="auto">I finally got it to work.  Look at my <a href="https://community.home-assistant.io/t/ha-with-mysensors-integration-mqtt/498513" rel="nofollow ugc">post on the Home Assistant forum</a>.</p>
<p dir="auto">There is an amazing thing that someone in the MySensors world did that makes RPi I/O very easy!  Just like the Arduino, one uses the code:</p>
<pre><code>pinMode(MphysicalPin, OUTPUT);
</code></pre>
<p dir="auto">I couldn't believe my eyes when I saw that.  And then got double flabbergasted when I discovered that <strong>pin</strong> is the physical pin of the RPi!  No mapping of GPIOi to the pins.<br />
Whew!</p>
<p dir="auto">So the I/O was easier than both of us could have imagined!  <a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> if you know who did this, send them praise and thanks.</p>
]]></description><link>https://forum.mysensors.org/post/113337</link><guid isPermaLink="true">https://forum.mysensors.org/post/113337</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Tue, 06 Dec 2022 22:45:08 GMT</pubDate></item><item><title><![CDATA[Reply to Local Sensors on Raspberry Pi Gateway on Wed, 13 Apr 2022 07:27:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldsurferdude" aria-label="Profile: OldSurferDude">@<bdi>OldSurferDude</bdi></a> I am not sure what the real difference between c/c++ code with the Arduino libraries, and c/c++ code without the Arduino libraries. But I don't think there is much difference. it is still code, and it is possible to add other libraries as well. So if your code needs any libraries, you should be able to include them like you would normally do.</p>
<p dir="auto">From what I understand, the <a href="https://github.com/mysensors/MySensors/tree/development/hal/architecture/Linux" rel="nofollow ugc">MySensors hardware abstraction layer for rpi</a> includes an <a href="https://github.com/mysensors/MySensors/blob/development/hal/architecture/Linux/drivers/core/SoftEeprom.cpp" rel="nofollow ugc">emulated EEPROM</a>. So you can use the Arduino EEPROM stuff if you want to, or just use plain c or c++ code to write to a file.</p>
<p dir="auto">For nodes, it is possible to force node id by setting <a href="https://www.mysensors.org/apidocs/group__RoutingNodeSettingGrpPub.html#gac677233da7f20bbf93cb479471e3234e" rel="nofollow ugc">MY_NODE_ID</a>. However, a MySensors gateway <em>always</em> has node id 0 so this is not applicable for a gateway. You would not need to write any code that saves and restores the node id.</p>
]]></description><link>https://forum.mysensors.org/post/111809</link><guid isPermaLink="true">https://forum.mysensors.org/post/111809</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Wed, 13 Apr 2022 07:27:15 GMT</pubDate></item><item><title><![CDATA[Reply to Local Sensors on Raspberry Pi Gateway on Tue, 12 Apr 2022 21:52:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a></p>
<p dir="auto">I am wary of success on that program as it looks like it's written for an Arduino, thus the libraries are for an Arduino.  For completeness sake, I try to note some differences</p>
<p dir="auto"><strong>Arduino</strong> on boot<br />
execute the <em>setup</em> function once<br />
start executing code in the <em>loop</em> function.  When you get to the end of <em>loop</em> start again at the start of <em>loop</em></p>
<p dir="auto"><strong>Linux C++</strong> on boot<br />
Start executing code in the function <em>main</em><br />
When you get to the end of the function <em>main</em>, exit the program</p>
<p dir="auto">To make the linux c++ code to be more Arduino like, the first lines of code after <em>main</em> are those that would normally be in <em>setup</em>.  After all the setup steps one, uses a while loop that never terminates <em>while</em>(1){ loop code here } . <em>while(1)</em> creates an infinite loop because the evaluated value is always true..</p>
<p dir="auto">Also, the Arduino uses EEPROM and the RPi uses a file for non-volatile memory.</p>
<p dir="auto">On a tangent here, I make the assumption that the Node ID is stored in the EEPROM on the Arduino.  Can one force a Node ID?  This is important because my Arduino code is identical  for all Arduinos (reading a preset NodeID from EEPROM) and the master uses the Node ID to perform a function that is location dependent.</p>
<p dir="auto">Arcing back in, if I am correct in that this code is written for an Arduino, I'll have to write code that saves and restores the Node ID, (and other parameters?)</p>
<p dir="auto">Thanks for your suggestion, I'll be looking in to it.</p>
]]></description><link>https://forum.mysensors.org/post/111808</link><guid isPermaLink="true">https://forum.mysensors.org/post/111808</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Tue, 12 Apr 2022 21:52:36 GMT</pubDate></item><item><title><![CDATA[Reply to Local Sensors on Raspberry Pi Gateway on Tue, 12 Apr 2022 20:46:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldsurferdude" aria-label="Profile: OldSurferDude">@<bdi>OldSurferDude</bdi></a> yes, the rpi gateway can have local sensors.</p>
<p dir="auto">I don't know how to program io on a rpi, but it seems you have that part figured out already. I think all you need to do is to insert your program into <a href="https://github.com/mysensors/MySensors/blob/development/examples_linux/mysgw.cpp" rel="nofollow ugc">https://github.com/mysensors/MySensors/blob/development/examples_linux/mysgw.cpp</a> before you <code>make</code> the gateway. Whenever you need to send or receive data, use MySensors send and receive just like you would on a node. No need for an extra nrf24.</p>
]]></description><link>https://forum.mysensors.org/post/111807</link><guid isPermaLink="true">https://forum.mysensors.org/post/111807</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Tue, 12 Apr 2022 20:46:54 GMT</pubDate></item></channel></rss>
