<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Node can send I_FIND_PARENT_REQUEST but cannot receive I_FIND_PARENT_RESPONSE]]></title><description><![CDATA[<p dir="auto">I recently designed and fabricated a new PCB utilizing the NRF24 with an ATMEGA168P (12MHz, 3.3V) and as usual, I ran into problems immediately. This time, it seems that the node is able to broadcast the I_FIND_PARENT_REQUEST to the gateway which receives it, but somehow is unable to itself receive the I_FIND_PARENT_RESPONSE from the gateway.</p>
<p dir="auto">Here is the simple sketch (LightSensor example) that I used. I added the <code>#define MY_NODE_ID 15</code> line to force the node to broadcast a preset ID as not including this line led to the controller not logging any record of receiving the I_FIND_PARENT_REQUEST.</p>
<pre><code>// Enable debug prints to serial monitor
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM95
#include &lt;MySensors.h&gt;
#define CHILD_ID_LIGHT 25
#define LIGHT_SENSOR_ANALOG_PIN 0
//uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
int lastLightLevel;
	sendSketchInfo("Light Sensor", "1.0");
	int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
	Serial.println(lightLevel);
		send(msg.set(lightLevel));
		lastLightLevel = lightLevel;
</code></pre>
<p dir="auto">Here are the logs from the node:</p>
<pre><code> __  __       ____
        |___/                      2.3.2
16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=12,REL=255,VER=2.3.2
27 TSM:INIT
28 TSF:WUR:MS=0
35 TSM:INIT:TSP OK
38 TSM:FPAR
3353 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
5363 !TSM:FPAR:NO REPLY
5364 TSM:FPAR
8680 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
10689 !TSM:FPAR:NO REPLY
10690 TSM:FPAR
14006 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
16016 !TSM:FPAR:NO REPLY
16018 TSM:FPAR
19334 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
21344 !TSM:FPAR:FAIL
21345 TSM:FAIL:CNT=1
21348 TSM:FAIL:DIS
21349 TSF:TDI:TSL
</code></pre>
<p dir="auto">and !TSM:FPAR:NO REPLY repeats over and over... But strangely these are the logs from the controller (Raspi running HA):</p>
<pre><code>2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;20391 TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:20391 TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;20398 TSF:MSG:BC
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:20398 TSF:MSG:BC
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;20401 TSF:MSG:FPAR REQ,ID=15
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:20401 TSF:MSG:FPAR REQ,ID=15
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;20404 TSF:PNG:SEND,TO=0
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:20404 TSF:PNG:SEND,TO=0
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;20407 TSF:CKU:OK
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:20407 TSF:CKU:OK
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;20410 TSF:MSG:GWL OK
2022-06-04 17:14:43 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:20410 TSF:MSG:GWL OK
2022-06-04 17:14:44 DEBUG (MainThread) [mysensors.transport] Receiving 0;255;3;0;9;21404 !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
2022-06-04 17:14:44 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:21404 !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
</code></pre>
<p dir="auto">From the <code>st=NACK:0</code>, it seems that the node is not acknowledging the I_FIND_PARENT_RESPONSE.</p>
<p dir="auto">I have already tried soldering a 100uF cap across the RF24 supply pins as well as powering the entire circuit using a lab bench power supply at 3.3V.<br />
I find this extremely puzzling as the node can clearly establish a one-way communication line with the controller but not vice versa. Any help as to why this is happening would be greatly appreciated. Thanks.</p>
]]></description><link>https://forum.mysensors.org/topic/11961/node-can-send-i_find_parent_request-but-cannot-receive-i_find_parent_response</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 00:34:29 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11961.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jun 2022 09:49:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Node can send I_FIND_PARENT_REQUEST but cannot receive I_FIND_PARENT_RESPONSE on Sun, 05 Jun 2022 14:55:50 GMT]]></title><description><![CDATA[<p dir="auto">If you have the wrong modules, it could give you problems yes. Check out the buying guide, there are recommendations for the modules to pick, for example the ebyte ones. The will work very reliable. Big advantage of NRF24 to RFM69 is the throughput and response time.</p>
]]></description><link>https://forum.mysensors.org/post/112178</link><guid isPermaLink="true">https://forum.mysensors.org/post/112178</guid><dc:creator><![CDATA[electrik]]></dc:creator><pubDate>Sun, 05 Jun 2022 14:55:50 GMT</pubDate></item><item><title><![CDATA[Reply to Node can send I_FIND_PARENT_REQUEST but cannot receive I_FIND_PARENT_RESPONSE on Sun, 05 Jun 2022 04:08:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/electrik" aria-label="Profile: electrik">@<bdi>electrik</bdi></a> it is connected to INT0 (D2). I went through all my RF24 modules and finally got one to work. As such I think the problem was with the RF24 module.</p>
<p dir="auto">I am going to migrate to RFM69 as RF24 modules are too inconsistent and low quality for reliable home automation.</p>
]]></description><link>https://forum.mysensors.org/post/112173</link><guid isPermaLink="true">https://forum.mysensors.org/post/112173</guid><dc:creator><![CDATA[Ethan Chua]]></dc:creator><pubDate>Sun, 05 Jun 2022 04:08:08 GMT</pubDate></item><item><title><![CDATA[Reply to Node can send I_FIND_PARENT_REQUEST but cannot receive I_FIND_PARENT_RESPONSE on Sat, 04 Jun 2022 12:06:19 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure the INT pin is connected?<br />
Sending will work, but it will never get an interrupt on recieving a message</p>
]]></description><link>https://forum.mysensors.org/post/112166</link><guid isPermaLink="true">https://forum.mysensors.org/post/112166</guid><dc:creator><![CDATA[electrik]]></dc:creator><pubDate>Sat, 04 Jun 2022 12:06:19 GMT</pubDate></item></channel></rss>
