<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;0&quot; Temp and Pressure readings from BMP280]]></title><description><![CDATA[<p dir="auto">Please assist if possible,</p>
<p dir="auto">I am using an Arduino UNO as well as a ESP8266 card with a BMP280 installed</p>
<p dir="auto">I am using the following sketch to try to get familiar with this operation</p>
<p dir="auto">SparkFun_BME280/I2C_ReadAllData.ino at master · mhaack/SparkFun_BME280 (<a href="http://github.com" rel="nofollow ugc">github.com</a>)</p>
<p dir="auto">On the serial port I am getting a "0" reading for Temp C and "0" Pa which possibly accounts for an extremely high Altitude reading.</p>
<p dir="auto">From my untrained eye, this looks like a calibration issue but I am probably wrong. Possibly a coding issue.</p>
<p dir="auto">I cannot see what the issue is.</p>
]]></description><link>https://forum.mysensors.org/topic/11969/0-temp-and-pressure-readings-from-bmp280</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 08:39:42 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11969.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jun 2022 07:46:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;0&quot; Temp and Pressure readings from BMP280 on Tue, 14 Jun 2022 15:15:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/merlotmaker" aria-label="Profile: Merlotmaker">@<bdi>Merlotmaker</bdi></a>,</p>
<p dir="auto">If you want more reactions from members, you should provide more information.</p>
<ul>
<li>what for sensor do you have, because you are speaking about BMP280 and BME280</li>
<li>the lib you are referring to is a specific one for the <a href="https://www.sparkfun.com/products/13676" rel="nofollow ugc">https://www.sparkfun.com/products/13676</a></li>
<li>how did you connect your sensor to the UNO?</li>
<li>did you follow this guide already? <a href="https://learn.sparkfun.com/tutorials/sparkfun-bme280-breakout-hookup-guide" rel="nofollow ugc">https://learn.sparkfun.com/tutorials/sparkfun-bme280-breakout-hookup-guide</a></li>
</ul>
]]></description><link>https://forum.mysensors.org/post/112332</link><guid isPermaLink="true">https://forum.mysensors.org/post/112332</guid><dc:creator><![CDATA[evb]]></dc:creator><pubDate>Tue, 14 Jun 2022 15:15:02 GMT</pubDate></item></channel></rss>
