<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Temperature and humidity room sensor]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">Let me start of by mentioning that English is not my native tongue so if there are anything I should explain further or rephrase please let me know.</p>
<p dir="auto">I’m planning a “DIY” heating system and I’m right now really interested in pihome’s solution.<br />
There is really only two things;</p>
<ul>
<li>does anyone know if it’s possible to add a humidity sensor to the room sensor and have the communication work in the same way as the temperature sensor.</li>
</ul>
<p dir="auto">Could someone estimate what impact this would have on the battery life?</p>
<ul>
<li>the other thing is that I would like to send the data to a sql for further analysis. I’ve been looking into machine learning with deep learning and I would like to collect the data for testing algorithms on.</li>
</ul>
<p dir="auto">Thanks in advance,</p>
<p dir="auto">Martin</p>
]]></description><link>https://forum.mysensors.org/topic/12023/temperature-and-humidity-room-sensor</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 10:57:17 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12023.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Sep 2022 20:19:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Temperature and humidity room sensor on Sat, 17 Sep 2022 19:48:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldsurferdude" aria-label="Profile: OldSurferDude">@<bdi>OldSurferDude</bdi></a> thank you so much for your reply, I’ll definitely look into this further!</p>
]]></description><link>https://forum.mysensors.org/post/113029</link><guid isPermaLink="true">https://forum.mysensors.org/post/113029</guid><dc:creator><![CDATA[martin1234567]]></dc:creator><pubDate>Sat, 17 Sep 2022 19:48:11 GMT</pubDate></item><item><title><![CDATA[Reply to Temperature and humidity room sensor on Wed, 07 Sep 2022 19:27:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/martin1234567" aria-label="Profile: martin1234567">@<bdi>martin1234567</bdi></a> There are devices called DHT (digital humidity temperature).  A cheap one that is hardly accurate is the <a href="https://www.aliexpress.com/item/2251801020835639.html?spm=a2g0o.productlist.0.0.6cb2505470uAHr&amp;algo_pvid=625973da-4281-44e7-82ae-8af60921bbe2&amp;algo_exp_id=625973da-4281-44e7-82ae-8af60921bbe2-0&amp;pdp_ext_f=%7B%22sku_id%22%3A%2257993801854%22%7D&amp;pdp_npi=2%40dis%21USD%210.62%210.59%21%21%21%21%21%402101e9d216625787914687317e9df0%2157993801854%21sea&amp;curPageLogUid=k9xU9sBhHuFn" rel="nofollow ugc">DHT11</a>.  If you want accuracy, the cost goes up exponentially.</p>
]]></description><link>https://forum.mysensors.org/post/112979</link><guid isPermaLink="true">https://forum.mysensors.org/post/112979</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Wed, 07 Sep 2022 19:27:56 GMT</pubDate></item></channel></rss>
