<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to drill 1mm diameter holes?  My drills won&#x27;t even hold the bit!]]></title><description><![CDATA[<p dir="auto">Trying to enlarge some holes on an incorrectly fab'd PCB.  I have a 1mm diameter drlll bit, but it turns out none of my drills will hold it--their chucks have a more than 1mm diameter void when closed.  I never knew until now, when the chips are down.  So, for the future, what drills will hold small bits like this?</p>
<p dir="auto">As a one-off, I held the bit with a pair of pliers and crudely rotated the PCB around it to drill the 3 holes, but it was awkward and I never want to have to do that again.  As a one-off, it did work though.</p>
]]></description><link>https://forum.mysensors.org/topic/12027/how-to-drill-1mm-diameter-holes-my-drills-won-t-even-hold-the-bit</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 17:46:40 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12027.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Sep 2022 18:33:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to drill 1mm diameter holes?  My drills won&#x27;t even hold the bit! on Sun, 18 Sep 2022 17:16:19 GMT]]></title><description><![CDATA[<p dir="auto">You need a Pin Vice (or vise if you're across the pond and want to butcher the <s>Queen's</s> King's English)...</p>
<p dir="auto"><a href="https://www.ebay.co.uk/itm/143450664932?epid=2305158887&amp;hash=item2166536fe4:g:g-AAAOSwnO1d2YjH&amp;amdata=enc%3AAQAHAAAAoNgdTu9H35nxAzYb88y%2Bd%2BnDpgfsjI2QXCJzOGcO0bj4xAlrbUz9IScDEEydVAxUQ2Fv%2FQXkfPURAH3PWftlQIbAploXhvcmwP4%2F%2FY1YNgXeglqfwkTWyP%2BQkgvRuss8OI4OkverPgiUT%2BBftCZcFLqrm6LdeKgcz8uqo4pMxnLx4AtDgoQHTnSznUbSxLM4jDkUGLECVv%2Bqaptf8fgnWu0%3D%7Ctkp%3ABk9SR8DLmJnqYA" rel="nofollow ugc">https://www.ebay.co.uk/itm/143450664932?epid=2305158887&amp;hash=item2166536fe4:g:g-AAAOSwnO1d2YjH&amp;amdata=enc%3AAQAHAAAAoNgdTu9H35nxAzYb88y%2Bd%2BnDpgfsjI2QXCJzOGcO0bj4xAlrbUz9IScDEEydVAxUQ2Fv%2FQXkfPURAH3PWftlQIbAploXhvcmwP4%2F%2FY1YNgXeglqfwkTWyP%2BQkgvRuss8OI4OkverPgiUT%2BBftCZcFLqrm6LdeKgcz8uqo4pMxnLx4AtDgoQHTnSznUbSxLM4jDkUGLECVv%2Bqaptf8fgnWu0%3D|tkp%3ABk9SR8DLmJnqYA</a></p>
<p dir="auto">Pete.</p>
]]></description><link>https://forum.mysensors.org/post/113030</link><guid isPermaLink="true">https://forum.mysensors.org/post/113030</guid><dc:creator><![CDATA[PeteKnight]]></dc:creator><pubDate>Sun, 18 Sep 2022 17:16:19 GMT</pubDate></item><item><title><![CDATA[Reply to How to drill 1mm diameter holes?  My drills won&#x27;t even hold the bit! on Sun, 11 Sep 2022 21:07:09 GMT]]></title><description><![CDATA[<p dir="auto">A few turns of (Scotch) tape to make the drill bit fit might be good enough to beat the PCB rotation method.</p>
]]></description><link>https://forum.mysensors.org/post/112997</link><guid isPermaLink="true">https://forum.mysensors.org/post/112997</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sun, 11 Sep 2022 21:07:09 GMT</pubDate></item><item><title><![CDATA[Reply to How to drill 1mm diameter holes?  My drills won&#x27;t even hold the bit! on Sun, 11 Sep 2022 21:02:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monte" aria-label="Profile: monte">@<bdi>monte</bdi></a> Thank you for sharing, just ordered the bits.</p>
]]></description><link>https://forum.mysensors.org/post/112994</link><guid isPermaLink="true">https://forum.mysensors.org/post/112994</guid><dc:creator><![CDATA[virtualmkr]]></dc:creator><pubDate>Sun, 11 Sep 2022 21:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to How to drill 1mm diameter holes?  My drills won&#x27;t even hold the bit! on Sun, 11 Sep 2022 18:45:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neverdie" aria-label="Profile: NeverDie">@<bdi>NeverDie</bdi></a> <a href="https://www.aliexpress.com/item/32738503593.html" rel="nofollow ugc">https://www.aliexpress.com/item/32738503593.html</a> special bits, that has the same diameter of the tail side, and will fit the standard drill. Or you can buy a drill with small jaws, or just another chuck, that will fit your drill.<br />
I am using dremel tool with a drill chuck bought separately <a href="https://www.dremel.com/us/en/p/4486-2615004486" rel="nofollow ugc">https://www.dremel.com/us/en/p/4486-2615004486</a></p>
]]></description><link>https://forum.mysensors.org/post/112993</link><guid isPermaLink="true">https://forum.mysensors.org/post/112993</guid><dc:creator><![CDATA[monte]]></dc:creator><pubDate>Sun, 11 Sep 2022 18:45:40 GMT</pubDate></item></channel></rss>
