<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[error compiling]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Latest MySensors 2.3.2 on Moteino USB is giving the following compile errors:</p>
<pre><code>"C:\\Users\\ashes\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\ashes\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\cores\\arduino" "-IC:\\Users\\ashes\\AppData\\Local\\Arduino15\\packages\\Moteino\\hardware\\avr\\1.6.1\\variants\\Moteino" "-Ic:\\Users\\ashes\\Documents\\Arduino\\libraries\\MySensors" "-IC:\\Users\\ashes\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\libraries\\SPI\\src" "-IC:\\Users\\ashes\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\libraries\\Wire\\src" "-Ic:\\Users\\ashes\\Documents\\Arduino\\libraries\\SparkFun_BME280\\src" "C:\\Users\\ashes\\AppData\\Local\\Temp\\arduino-sketch-9F678573572D7168587156F8AF298387\\sketch\\MotionSensor-lowlabs_v2_Nr2.ino.cpp" -o "C:\\Users\\ashes\\AppData\\Local\\Temp\\arduino-sketch-9F678573572D7168587156F8AF298387\\sketch\\MotionSensor-lowlabs_v2_Nr2.ino.cpp.o"
In file included from c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/MyCryptoAVR.h:25:0,
                 from c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/MyCryptoAVR.cpp:21,
                 from c:\Users\ashes\Documents\Arduino\libraries\MySensors/MySensors.h:65,
                 from C:\Users\ashes\Documents\Arduino\MotionSensor-lowlabs_v2_Nr2\MotionSensor-lowlabs_v2_Nr2.ino:17:
c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/drivers/AES/aes.cpp: In function 'AES_CBC_encrypt_buffer(AES_ctx*, unsigned char*, unsigned long)':
c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/drivers/AES/aes.cpp:525:1: error: unable to find a register to spill in class 'POINTER_REGS'
c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/drivers/AES/aes.cpp:525:1: error: this is the insn:
(insn 288 325 289 11 (set (reg:HI 26 r26)
        (reg/v/f:HI 67 [ buf ])) c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/drivers/AES/aes.cpp:524 82 {*movhi}
     (expr_list:REG_DEAD (reg/v/f:HI 67 [ buf ])
        (nil)))
c:\Users\ashes\Documents\Arduino\libraries\MySensors/hal/crypto/AVR/drivers/AES/aes.cpp:525: confused by earlier errors, bailing out
Using library MySensors at version 2.3.2 in folder: C:\Users\ashes\Documents\Arduino\libraries\MySensors
Using library SPI at version 1.0 in folder: C:\Users\ashes\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.4\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\ashes\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.4\libraries\Wire
Using library SparkFun_BME280 at version 2.0.9 in folder: C:\Users\ashes\Documents\Arduino\libraries\SparkFun_BME280
exit status 1
Compilation error: exit status 1
</code></pre>
<p dir="auto">Any idea how to fix it? Using latest Arduino IDE and libraries</p>
]]></description><link>https://forum.mysensors.org/topic/12032/error-compiling</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 07:20:58 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12032.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Sep 2022 17:10:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to error compiling on Wed, 14 Sep 2022 20:57:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexsh1" aria-label="Profile: alexsh1">@<bdi>alexsh1</bdi></a> <a href="https://github.com/arduino/ArduinoCore-avr/issues/158" rel="nofollow ugc">https://github.com/arduino/ArduinoCore-avr/issues/158</a> and <a href="https://gcc.gnu.org/bugzilla/show_bug.cgi?id=60040" rel="nofollow ugc">https://gcc.gnu.org/bugzilla/show_bug.cgi?id=60040</a> suggests it is a bug in gcc. It seems to have been resolved a long time ago though.</p>
]]></description><link>https://forum.mysensors.org/post/113016</link><guid isPermaLink="true">https://forum.mysensors.org/post/113016</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Wed, 14 Sep 2022 20:57:06 GMT</pubDate></item></channel></rss>
