<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Balcony flower box irrigation]]></title><description><![CDATA[<p dir="auto">I don't have a home controller. The sensor network and the gateway are enough for me if<br />
I could place the humidity control and an html server on the gateway.<br />
my sensors: arduino pro mini, rf24, and humidity sensor. unfortunately I can't find an entry point on how to extract the humidity values, for example, for processing.<br />
Maybe someone can give me a tip? Best with an example.</p>
]]></description><link>https://forum.mysensors.org/topic/12121/balcony-flower-box-irrigation</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 13:46:08 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12121.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Mar 2023 11:54:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Balcony flower box irrigation on Sun, 21 May 2023 20:22:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pbw" aria-label="Profile: pbw">@<bdi>pbw</bdi></a> a gateway's function is to act as a gateway between the nodes and a controller. I don't think you will have all of the needed memory available to add logic to the gateway and you will make your solution very static.</p>
<p dir="auto">You can implemented your own lightway controller, just have a look at the Serial API. But controllers like Domoticz are lightweight and the already over a browser based interface. And most of them are easy to setup creating a much more versatile and dynamic solution.</p>
]]></description><link>https://forum.mysensors.org/post/113715</link><guid isPermaLink="true">https://forum.mysensors.org/post/113715</guid><dc:creator><![CDATA[TheoL]]></dc:creator><pubDate>Sun, 21 May 2023 20:22:48 GMT</pubDate></item></channel></rss>
