<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HW-488 infrared sensor not detecting properly]]></title><description><![CDATA[<p dir="auto">I’m testing the HW-488 IR obstacle avoidance sensor with my Arduino, but the readings are weird. Sometimes it doesn’t detect anything, even if I put an object really close. Do I need to do something with the EN pin, or should it just work with VCC, GND, and OUT?</p>
]]></description><link>https://forum.mysensors.org/topic/12303/hw-488-infrared-sensor-not-detecting-properly</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 23:23:53 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12303.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Sep 2025 18:02:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HW-488 infrared sensor not detecting properly on Sun, 07 Sep 2025 01:54:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jaydenlord" aria-label="Profile: jaydenlord">@<bdi>jaydenlord</bdi></a> Probably you do.  If you leave the EN floating, electrical noise could cause it to enable or disable randomly.</p>
<p dir="auto">Some enable pin require a HIGH, some LOW.  Connect it to VCC to see if it works more consistently.  If it doesn't detect, connect it to GND.</p>
<p dir="auto">If one of these works, then the part wasn't designed to be in a default state of enable.</p>
<p dir="auto">Let us know your results   (I found this <a href="https://www.youtube.com/watch?v=ESqhOKgKt5c" rel="nofollow ugc">video</a></p>
<p dir="auto">OSD</p>
]]></description><link>https://forum.mysensors.org/post/114437</link><guid isPermaLink="true">https://forum.mysensors.org/post/114437</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Sun, 07 Sep 2025 01:54:36 GMT</pubDate></item></channel></rss>
