<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Temperature&#x2F;moisture sensor for compost bin]]></title><description><![CDATA[<p dir="auto">I havevrecently purchased a plastic compost bin and partly filled it with some mixture of grass cuttings and horse Manure. I would like to bevable to.monitor the temperature and moisture level in the middle of the pile of rotting compost to allow me to adjust the conditions if necessary ideally I would like to be able to read the data from inside my house. So my question is, does anyone make a sensor that will detect temperature and moisture level, that will stand the conditions inside the cospistvheap. It will need to have a problematic leastb50cm long. Ideally it will communicate with my phone, or a Raspberry Pi, or a Home Assistant system by Bluetooth or Wfi or Zigbee or some other wireless means. Or if I can't find this, it could be 1-wire.<br />
Does such a thing exist? If not, what would be the easiest way to make one?</p>
<p dir="auto">Thank you - Rowan</p>
]]></description><link>https://forum.mysensors.org/topic/12342/temperature-moisture-sensor-for-compost-bin</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 20:15:10 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12342.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Jun 2026 16:53:03 GMT</pubDate><ttl>60</ttl></channel></rss>
