<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Home Assistant Green Controller with Sensebender gateway?]]></title><description><![CDATA[<p dir="auto">Hi folks   - I am new to this space so please don't crucify me if this a dumb question:    A few years  ago,  I purchased a heap of NRF24L01+ boards and a few Sensebender gateway boards planning to hook these up to Widows hosted Domoticz controller.  Ran out of time to play then - and are now looking at a Home Assistant Green instead of Domoticz as I am now keen on a fanless host.  My question is what would be the best Green/Sensebender interface to use (assuming it is possible/practical?).</p>
<p dir="auto">Thanks in advance for your help/mercy :)</p>
]]></description><link>https://forum.mysensors.org/topic/12344/home-assistant-green-controller-with-sensebender-gateway</link><generator>RSS for Node</generator><lastBuildDate>Thu, 02 Jul 2026 07:30:22 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12344.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Jun 2026 11:49:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Home Assistant Green Controller with Sensebender gateway? on Wed, 01 Jul 2026 15:59:03 GMT]]></title><description><![CDATA[<p dir="auto">You have three ways to for the gateway to communicate to Home Assistant (HA), serial, ethernet, and MQTT.</p>
<p dir="auto">It comes to this: A serial gateway will be in very close proximity to the HA Green.  It is very simple to set up.  ethernet or MQTT can be anywhere there is ethernet or WiFi, but not so simple to set up.</p>
<p dir="auto">The latter two require ethernet connectivity hardware added.  This makes the configuration much more complicated and, if going this way, I'd recommend the RPi zero 2W with your radio of choice running Raspberry Pi OS as your gateway.  The gateway software runs in the OS (I run this set up).</p>
<p dir="auto">The serial gateway is a wired connection to your HA Green and the HA Green would power it.  The location of your HA Green/serial gateway probably take some experimentation.</p>
<p dir="auto">The downside is the range of your radio.  Fortunately, with repeater nodes or nodes that also act as repeaters, too, this isn't too bad.  I find the range, line-of-sight, no obstructions about 10m.  Or, 3m through 1 wall.</p>
<p dir="auto">I am unfamiliar with Sensebender.   Googling it I find one from <a href="https://itead.cc/product/mysensors-gateway" rel="nofollow ugc">Itead</a> one from <a href="https://www.openhardware.io/view/1/Sensebender-Micro#tabs-design" rel="nofollow ugc">OpenHardware</a>.   I'm not finding much in the way of documentation. :(</p>
<p dir="auto">I am familiar with the <a href="https://www.aliexpress.us/item/3256808840197195.html" rel="nofollow ugc">RF-Nano</a> (Arduino Nano compatible with nRF24 built in) and would offer much the same capabilities as the Sensbender.  The range on the RF-Nano is a bit less than that of the stand-alone nRF24.</p>
<p dir="auto">The Nano is powered from the computer, though from what I can glean from the docs, the Sensebender would also require a <a href="https://www.amazon.com/dp/B07D6LLX19" rel="nofollow ugc">serial-to-USB adapter</a> (use 3V3 pin on adapter for power).  This is amazingly simple hardware.</p>
<p dir="auto">The Nano gateway can also have sensors.  This is very cool for me because I run HA in a virtual box under Ubuntu on a refurb PC.  The serial gateway is a Nano compatible and I use it to "push" buttons on a remote.  I'm not using a radio at all.  Essentially the Nano and MySensors gateway software gives me I/O ports for my pc.</p>
<p dir="auto">Let us know how your project goes.</p>
]]></description><link>https://forum.mysensors.org/post/114743</link><guid isPermaLink="true">https://forum.mysensors.org/post/114743</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Wed, 01 Jul 2026 15:59:03 GMT</pubDate></item></channel></rss>
