<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hello all!]]></title><description><![CDATA[<p dir="auto">Hello all! Happy to join the MySensors community. I enjoy electronics, wireless sensor projects, and sharing practical engineering experience with everyone.</p>
]]></description><link>https://forum.mysensors.org/topic/12346/hello-all</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Jul 2026 09:01:50 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12346.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2026 09:38:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hello all! on Sun, 19 Jul 2026 02:57:22 GMT]]></title><description><![CDATA[<p dir="auto">The nRF24 is good for short distances ~10m.  That distance can be extended because nodes can also be a repeater to the gateway.</p>
<p dir="auto">I'm using an RPi zero 2W for my gateway (which is also my irrigation controller.)  Can you reach your greenhouse with WiFi?  This may work for you.</p>
<p dir="auto">I'd look at the <a href="https://www.aliexpress.us/item/3256802527146843.html" rel="nofollow ugc">RFnano</a>  that has the nRF24 integrated.  It costs about  more than a <a href="https://www.aliexpress.us/item/3256808820734226.html" rel="nofollow ugc">Nano</a> and <a href="https://www.aliexpress.us/item/3256806081358279.html" rel="nofollow ugc">nRF24</a> separately, but what you gain is no wiring and no wiring failures.</p>
<p dir="auto">I tried to used this <a href="https://www.amazon.com/MTDELE-Capacitive-Moisture-Compatible-Raspberry/dp/B0F9WX5XH6/ref=sr_1_1_sspa" rel="nofollow ugc">moisture sensor</a> and it corroded within a year.  DHT-12 (digital humidity and temperature) can be off as much as 4°C per the specs and suffers from the same corrosion challenge.</p>
<p dir="auto">Speaking of corrosion, be sure to "paint" all your electronics with  <a href="https://www.amazon.com/dp/B00DRHSFCS" rel="nofollow ugc">electrical lacquer sealer</a> (but not on the sensors)</p>
<p dir="auto">You have to consider how you're going to power your sensors.  I'm not a big fan of batteries because you have to jump through a lot of hoops to get the most out of the batteries.  On the flip side, you'll have to run 5V to all your sensors.    This is my [pathetic] attempt at a <a href="https://github.com/OldSurferDude/Soil-Moisture-Sensor-remote-battery-solar" rel="nofollow ugc">remote soil sensor</a></p>
]]></description><link>https://forum.mysensors.org/post/114757</link><guid isPermaLink="true">https://forum.mysensors.org/post/114757</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Sun, 19 Jul 2026 02:57:22 GMT</pubDate></item><item><title><![CDATA[Reply to Hello all! on Sat, 18 Jul 2026 07:40:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldsurferdude" aria-label="Profile: OldSurferDude">@<bdi>OldSurferDude</bdi></a><br />
Hi!<br />
I'm planning to build a small wireless greenhouse monitoring system. My goal is to measure soil moisture, temperature and humidity at several locations, then send the data to Home Assistant. Later, I'd also like to automatically control a small irrigation pump or a relay based on soil moisture. I'm still deciding between nRF24L01 and RFM69. Has anyone compared them for outdoor reliability?</p>
]]></description><link>https://forum.mysensors.org/post/114755</link><guid isPermaLink="true">https://forum.mysensors.org/post/114755</guid><dc:creator><![CDATA[robert fletcher]]></dc:creator><pubDate>Sat, 18 Jul 2026 07:40:47 GMT</pubDate></item><item><title><![CDATA[Reply to Hello all! on Fri, 17 Jul 2026 23:46:05 GMT]]></title><description><![CDATA[<p dir="auto">What are you looking to monitor and/or control <a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-fletcher" aria-label="Profile: robert-fletcher">@<bdi>robert-fletcher</bdi></a>?</p>
]]></description><link>https://forum.mysensors.org/post/114754</link><guid isPermaLink="true">https://forum.mysensors.org/post/114754</guid><dc:creator><![CDATA[OldSurferDude]]></dc:creator><pubDate>Fri, 17 Jul 2026 23:46:05 GMT</pubDate></item></channel></rss>
