<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Suddenly after an HA update i get no sensor data anymore]]></title><description><![CDATA[<p dir="auto">Hello,<br />
After installing the Core Update 2026.7.4 HA did not received any data from all my "MySensors" sensors.</p>
<p dir="auto">I use the serial gateway on a raspberry pi 3. The connection to this seems to work:</p>
<pre><code>"2026-08-04 17:45:39.160 INFO (MainThread) [mysensors.transport] Connected to Serial&lt;id=0x7f54ec9a50, open=True&gt;(port='/dev/ttyUSB0', baudrate=38400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)"
</code></pre>
<p dir="auto">I get no more messages from mysensors after the startup.<br />
I tried a reboot as well as a shut down and a complete power cycle.<br />
I tried to repower the sensors as well. But this doesnt work either.</p>
<p dir="auto">Sometimes, about 2 to 3 times per day, i get a message like this:</p>
<pre><code>2026-08-05 22:29:42.054 DEBUG (MainThread) [mysensors.transport] Receiving ��D������D��w���^y
2026-08-05 22:29:42.056 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: ��D������D��w���^y
2026-08-05 22:29:42.057 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
</code></pre>
<p dir="auto">I tested the serial gateway on my pc. The sensors appear in the serial console:</p>
<pre><code>8;0;1;0;0;21.59&lt;\n&gt;
8;1;1;0;1;58.98&lt;\n&gt;
8;255;3;0;0;85&lt;\n&gt;
5;0;1;0;0;23.40&lt;\n&gt;
2;0;1;0;0;19.05&lt;\n&gt;
2;1;1;0;1;68.34&lt;\n&gt;
2;255;3;0;0;63&lt;\n&gt;
</code></pre>
<p dir="auto">I am running out of ideas. On github i also created a issue.<br />
Has someone an idea how can i debug or fix this?<br />
As last opportunity i can build a MQTT-Gateway.</p>
<p dir="auto">regards,<br />
Sebastian</p>
]]></description><link>https://forum.mysensors.org/topic/12351/suddenly-after-an-ha-update-i-get-no-sensor-data-anymore</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 15:27:25 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12351.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Aug 2026 08:56:25 GMT</pubDate><ttl>60</ttl></channel></rss>
