<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Enclosure for Easy-Peasy-LEDsy nRF24 Serial Gateway]]></title><description><![CDATA[<p dir="auto">HI all,</p>
<p dir="auto">I'm sharing a serial gateway I built, based on the Easy-Peasy Serial Gateway.<br />
You can find the hardware on OpenHardware: <a href="https://www.openhardware.io/view/41787/Easy-Peasy-LEDsy-MySensors-NRF24-Serial-Gateway" rel="nofollow ugc">Easy-Peasy-LEDsy MySensors NRF24 Serial Gateway</a>. It is basically a D1 mini with a shield into which you connect an nRF24+PA+LNA module and the LEDs.</p>
<p dir="auto"><img src="/assets/uploads/files/1794085116905-1000008736-resized.jpg" alt="1000008736.jpg" class="img-markdown  img-fluid" width="4032" height="2268" /><br />
<img src="/assets/uploads/files/1794084750659-nrf24-d1-mini05.png" alt="NRF24-D1-MINI05.png" class="img-markdown  img-fluid" width="598" height="609" /> <img src="/assets/uploads/files/1794084761290-nrf24-d1-mini11.png" alt="NRF24-D1-MINI11.png" class="img-markdown  img-fluid" width="619" height="554" /> <img src="/assets/uploads/files/1794084790635-nrf24-d1-mini08.png" alt="NRF24-D1-MINI08.png" class="img-markdown  img-fluid" width="600" height="599" /></p>
<p dir="auto">Here are the stl files:<br />
<a href="/assets/uploads/files/1794085317540-gw_case.stl">GW_Case.stl</a><br />
<a href="/assets/uploads/files/1794085328253-gw_cover.stl">GW_Cover.stl</a><br />
<a href="/assets/uploads/files/1794085342496-gw_hold-down.stl">GW_Hold Down.stl</a></p>
<p dir="auto">It has a snap on cover, ventilation, and a hold-down to fix the D1 mini.</p>
]]></description><link>https://forum.mysensors.org/topic/12358/enclosure-for-easy-peasy-ledsy-nrf24-serial-gateway</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 16:03:16 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12358.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2026 21:08:34 GMT</pubDate><ttl>60</ttl></channel></rss>
