<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Building a Reliable Ethernet Gateway for MySensors – PCB Layout Considerations]]></title><description><![CDATA[<p dir="auto">I've been thinking about the hardware side of MySensors gateways, particularly when moving from a breadboard prototype to a dedicated PCB.</p>
<p dir="auto">A wired Ethernet gateway can be a good option for home automation setups where Wi-Fi connectivity isn't always reliable. But getting the Ethernet interface right on a custom PCB requires a little more attention than simply connecting a PHY and RJ45 connector.</p>
<p dir="auto">A few design considerations worth keeping in mind:</p>
<ul>
<li><strong>PHY and magnetics placement:</strong> Keep the PHY, Ethernet magnetics, and RJ45 connector close together to minimize the MDI trace length.</li>
<li><strong>Differential routing:</strong> Maintain 100 Ω differential impedance and avoid unnecessary vias or stubs in Ethernet signal pairs.</li>
<li><strong>Grounding and isolation:</strong> Keep chassis ground and circuit ground properly separated around the Ethernet magnetics.</li>
<li><strong>Power supply:</strong> Provide clean, well-decoupled power to the PHY. Switching regulator noise can affect Ethernet performance.</li>
<li><strong>ESD protection:</strong> Add suitable low-capacitance TVS protection near the Ethernet interface.</li>
</ul>
<p dir="auto">I work with technical content and PCB-related projects at PCBCool. While looking into practical PCB design challenges, Ethernet gateway layouts caught my attention because small layout decisions can make a noticeable difference in reliability.</p>
<p dir="auto">I'm curious about the experience of other MySensors users:</p>
<p dir="auto"><strong>Has anyone here designed a custom Ethernet gateway PCB for MySensors? Did you face any issues with Ethernet link stability, EMI, or communication between the gateway and sensor nodes?</strong></p>
<p dir="auto">It would be interesting to hear what worked well in your hardware designs.</p>
]]></description><link>https://forum.mysensors.org/topic/12361/building-a-reliable-ethernet-gateway-for-mysensors-pcb-layout-considerations</link><generator>RSS for Node</generator><lastBuildDate>Sun, 29 Nov 2026 22:02:34 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12361.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Nov 2026 11:22:31 GMT</pubDate><ttl>60</ttl></channel></rss>
