<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Anyone using MySensors relays for a breakfast casserole warmer?]]></title><description><![CDATA[<p dir="auto">I'm setting up a small MySensors network at home in Omaha, mostly Arduino Pro Mini nodes with NRF24 radios, and I'm working out how to keep a breakfast tater tot casserole warm before guests arrive. The plan is a temperature sensor node near the dish feeding a relay node that switches a low-power warming plate, with the gateway passing values to my controller.</p>
<p dir="auto">My concern is the relay side: the warming plate draws a few hundred watts, and I don't want to push a cheap relay module near its limit or have the node reset when the element cycles. I've also seen comments online about NRF24 range dropping when relays are close to the radio, though I have no first-hand experience there.</p>
<p dir="auto">Has anyone here run a similar sensing and switching setup for a food warmer? I'd like to hear how you handled relay sizing, wire routing, and keeping the radio stable.</p>
]]></description><link>https://forum.mysensors.org/topic/12362/anyone-using-mysensors-relays-for-a-breakfast-casserole-warmer</link><generator>RSS for Node</generator><lastBuildDate>Thu, 26 Nov 2026 13:39:41 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12362.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Nov 2026 22:51:41 GMT</pubDate><ttl>60</ttl></channel></rss>
