<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Solid State Relay ?]]></title><description><![CDATA[<p dir="auto">hello everybody ,</p>
<p dir="auto">i have domoticz interfaced with mysensors , i'm very happy but i need to use SSR like thiss : <a href="http://www.dx.com/fr/p/ssr-25da-25a-solid-state-relay-white-134494#.VTuG0iHtmko" rel="nofollow ugc">http://www.dx.com/fr/p/ssr-25da-25a-solid-state-relay-white-134494#.VTuG0iHtmko</a> .</p>
<p dir="auto">but i have no signal , juste to power with 3,3v the side DC of m ssr ...</p>
<p dir="auto">thanks in advance .</p>
]]></description><link>https://forum.mysensors.org/topic/1300/solid-state-relay</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 09:21:59 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1300.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 25 Apr 2015 12:24:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Solid State Relay ? on Mon, 13 Nov 2017 11:47:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boots33" aria-label="Profile: Boots33">@<bdi>Boots33</bdi></a></p>
<p dir="auto">This is it!<br />
Thank you very much</p>
<p dir="auto">Lazlo</p>
]]></description><link>https://forum.mysensors.org/post/79469</link><guid isPermaLink="true">https://forum.mysensors.org/post/79469</guid><dc:creator><![CDATA[szempo]]></dc:creator><pubDate>Mon, 13 Nov 2017 11:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to Solid State Relay ? on Mon, 13 Nov 2017 09:59:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/szempo" aria-label="Profile: szempo">@<bdi>szempo</bdi></a> I built a controller using ssr's , it was a while ago but you may get some ideas from the post.</p>
<p dir="auto"><a href="https://forum.mysensors.org/topic/4510/ac-power-controller-with-node-to-node-remotes">AC Power controller with node to node remotes</a></p>
]]></description><link>https://forum.mysensors.org/post/79461</link><guid isPermaLink="true">https://forum.mysensors.org/post/79461</guid><dc:creator><![CDATA[Boots33]]></dc:creator><pubDate>Mon, 13 Nov 2017 09:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to Solid State Relay ? on Mon, 13 Nov 2017 07:17:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fred97" aria-label="Profile: fred97">@<bdi>fred97</bdi></a></p>
<p dir="auto">Hy</p>
<p dir="auto">How can I control it? arduino nano + nrpf24 +two pin ssr 25 da relay modul ?? Domoticz.</p>
<p dir="auto">This relay two pins + and -. Mysensors how to HIgh and LOW pin arduino.</p>
<p dir="auto">Thank you in advance for your reply.</p>
]]></description><link>https://forum.mysensors.org/post/79449</link><guid isPermaLink="true">https://forum.mysensors.org/post/79449</guid><dc:creator><![CDATA[szempo]]></dc:creator><pubDate>Mon, 13 Nov 2017 07:17:26 GMT</pubDate></item><item><title><![CDATA[Reply to Solid State Relay ? on Sat, 25 Apr 2015 17:15:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fred97" aria-label="Profile: fred97">@<bdi>fred97</bdi></a> If you apply 3.3V power, it will close the circuit between the AC terminals, so you can consider the + side the signal and connect - to ground.  The + side would then connect to an output on the Arduino and you would turn on the SSR by bringing it high.   You could also wire it the other way around (- to an output on the Arduino and + to 3.3v) and then turn the SSR on by bringing the output low.</p>
<p dir="auto">One thing to confirm is how much current the DC side of the SSR draws to make sure it's within the limits of what the Arduino can supply.  Most SSR will draw less, but I would measure it just to be safe.</p>
<p dir="auto">Cheers<br />
Al</p>
]]></description><link>https://forum.mysensors.org/post/13141</link><guid isPermaLink="true">https://forum.mysensors.org/post/13141</guid><dc:creator><![CDATA[Sparkman]]></dc:creator><pubDate>Sat, 25 Apr 2015 17:15:52 GMT</pubDate></item></channel></rss>
