<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[repeater and sensor in one node.]]></title><description><![CDATA[<p dir="auto">It is possible in one node is repeater and sensor?</p>
<p dir="auto">Thanx<br />
Pawel</p>
]]></description><link>https://forum.mysensors.org/topic/1364/repeater-and-sensor-in-one-node</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 07:59:54 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1364.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 May 2015 18:14:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to repeater and sensor in one node. on Fri, 08 May 2015 20:57:05 GMT]]></title><description><![CDATA[<p dir="auto">Yes, that should do it.</p>
<p dir="auto">And yes you shouldn't use delay() or sleep the node. Instead you use timer or your own millis() checks.</p>
]]></description><link>https://forum.mysensors.org/post/13752</link><guid isPermaLink="true">https://forum.mysensors.org/post/13752</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Fri, 08 May 2015 20:57:05 GMT</pubDate></item><item><title><![CDATA[Reply to repeater and sensor in one node. on Fri, 08 May 2015 19:09:08 GMT]]></title><description><![CDATA[<p dir="auto">I should change:</p>
<ol>
<li>in setup():<br />
gw.begin()  --&gt;  gw.begin(NULL, AUTO, true);</li>
<li>in loop();<br />
gw.sleep(SLEEP_TIME);  --&gt; gw.process();</li>
</ol>
<p dir="auto">this will be enough?<br />
when i use node as repeater with sensor . this will be work all time without sleep mode?<br />
And I should us timer (not delay) send sensors value.<br />
What else?</p>
]]></description><link>https://forum.mysensors.org/post/13747</link><guid isPermaLink="true">https://forum.mysensors.org/post/13747</guid><dc:creator><![CDATA[pawel]]></dc:creator><pubDate>Fri, 08 May 2015 19:09:08 GMT</pubDate></item><item><title><![CDATA[Reply to repeater and sensor in one node. on Thu, 07 May 2015 19:01:24 GMT]]></title><description><![CDATA[<p dir="auto">Yes, repeaters can report sensor data.</p>
]]></description><link>https://forum.mysensors.org/post/13704</link><guid isPermaLink="true">https://forum.mysensors.org/post/13704</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Thu, 07 May 2015 19:01:24 GMT</pubDate></item></channel></rss>
