<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Moving From Vera to HomeSeer]]></title><description><![CDATA[<p dir="auto">I'm in the process of evaluating HomeSeer (From what I've seen I'm most likely going to make the move) for a move from Vera.</p>
<p dir="auto">What is the best and easiest way to move my MySensors network from the Vera controller to the HomeSeer computer?</p>
]]></description><link>https://forum.mysensors.org/topic/1417/moving-from-vera-to-homeseer</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 15:59:01 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1417.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 May 2015 17:23:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 21:34:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hleidecker" aria-label="Profile: hleidecker">@<bdi>hleidecker</bdi></a> Thank you VERY much for your plug in.  I tried posting some questions to problems that I'm having but they must be moderated first...</p>
<p dir="auto">If you have a chance:</p>
<ol>
<li>How do I display battery levels?</li>
<li>The "Light indicators" don't work with a status change (Light is always off)</li>
</ol>
]]></description><link>https://forum.mysensors.org/post/14286</link><guid isPermaLink="true">https://forum.mysensors.org/post/14286</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sun, 17 May 2015 21:34:32 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 21:30:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm the developer of the MySensors HomeSeer plugin. The expiry date was implemented in order to ensure that most users are running the latest version of the plugin.</p>
<p dir="auto">I'm happy to hear that you are taking my plugin into use.</p>
<p dir="auto">A lot of effort has been spent on adding support for retransmission, timeout, unit strings etc. Adding support for new sensors is in principle trivial as long as the protocol is clear - for some of the sensors I had to talk to HEK about the definition of the protocol.</p>
<p dir="auto">Maybe focus should be changed to additional sensor support for the coming releases.</p>
<p dir="auto">Best regards,<br />
Henrik</p>
]]></description><link>https://forum.mysensors.org/post/14285</link><guid isPermaLink="true">https://forum.mysensors.org/post/14285</guid><dc:creator><![CDATA[hleidecker]]></dc:creator><pubDate>Sun, 17 May 2015 21:30:57 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 18:16:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sparkman" aria-label="Profile: Sparkman">@<bdi>Sparkman</bdi></a> Oh.... Ok....</p>
]]></description><link>https://forum.mysensors.org/post/14283</link><guid isPermaLink="true">https://forum.mysensors.org/post/14283</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sun, 17 May 2015 18:16:18 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 18:14:48 GMT]]></title><description><![CDATA[<p dir="auto">@ServiceXp It means the plugin will stop working on that date.  The author should release a new version prior to then, so it should not be an issue.  I'm not sure why the author elected to release the plugin with an expiry date.</p>
<p dir="auto">Cheers<br />
Al</p>
]]></description><link>https://forum.mysensors.org/post/14282</link><guid isPermaLink="true">https://forum.mysensors.org/post/14282</guid><dc:creator><![CDATA[Sparkman]]></dc:creator><pubDate>Sun, 17 May 2015 18:14:48 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 17:57:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sparkman" aria-label="Profile: Sparkman">@<bdi>Sparkman</bdi></a> I have a question: When I added the gateway to HS3, It's say "WARNING: Expires: 5/31/2015 12:00:00 PM"</p>
<p dir="auto">What does that exactly mean?</p>
]]></description><link>https://forum.mysensors.org/post/14281</link><guid isPermaLink="true">https://forum.mysensors.org/post/14281</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sun, 17 May 2015 17:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 17:53:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sparkman" aria-label="Profile: Sparkman">@<bdi>Sparkman</bdi></a> Thank You!</p>
]]></description><link>https://forum.mysensors.org/post/14280</link><guid isPermaLink="true">https://forum.mysensors.org/post/14280</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sun, 17 May 2015 17:53:46 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 17:53:13 GMT]]></title><description><![CDATA[<p dir="auto">@ServiceXp Those are all supported so you should be good.</p>
Al</p>
]]></description><link>https://forum.mysensors.org/post/14279</link><guid isPermaLink="true">https://forum.mysensors.org/post/14279</guid><dc:creator><![CDATA[Sparkman]]></dc:creator><pubDate>Sun, 17 May 2015 17:53:13 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 17:52:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sparkman" aria-label="Profile: Sparkman">@<bdi>Sparkman</bdi></a></p>
<p dir="auto">I'm Using Temp, Humidity, Relay and Motion.</p>
]]></description><link>https://forum.mysensors.org/post/14278</link><guid isPermaLink="true">https://forum.mysensors.org/post/14278</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sun, 17 May 2015 17:52:20 GMT</pubDate></item><item><title><![CDATA[Reply to Moving From Vera to HomeSeer on Sun, 17 May 2015 17:30:24 GMT]]></title><description><![CDATA[<p dir="auto">@ServiceXp I use HS3 (have been using HS for over 15 years) and the MySensors plugin.  One thing to note is that the HS MySensors plugin does not yet support all of the same devices as the Vera plugin does.  What types of sensors are you using?  I believe that when you hook-up the gateway to HS3 and put the plugin in inclusion mode, it should see all of the data come in and then create the associated HS devices automatically.</p>
Al</p>
]]></description><link>https://forum.mysensors.org/post/14277</link><guid isPermaLink="true">https://forum.mysensors.org/post/14277</guid><dc:creator><![CDATA[Sparkman]]></dc:creator><pubDate>Sun, 17 May 2015 17:30:24 GMT</pubDate></item></channel></rss>
