<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MySensor lib doesn&#x27;t work with an chip nrfl24l01&#x2F;SE8R01]]></title><description><![CDATA[<p dir="auto">Good morning,<br />
I use MySensor lib in my home automation and it work well (thank to the wonderful library).<br />
I recently bought a new "compatible" transceiver nrfl24l01 module (smaller cheaper) based on chip SE8R01.</p>
<p dir="auto"><a href="http://www.aliexpress.com/snapshot/6579035554.html?orderId=66593219286095" rel="nofollow ugc">http://www.aliexpress.com/snapshot/6579035554.html?orderId=66593219286095</a></p>
<p dir="auto">Unfortutnatly (of course) it doesn't work !!. Due to a difference into an buffer size.<br />
Do you know the change to apply to the RF24 library to make it compatible with this module.</p>
<p dir="auto">Many Thanks, FC</p>
]]></description><link>https://forum.mysensors.org/topic/1442/mysensor-lib-doesn-t-work-with-an-chip-nrfl24l01-se8r01</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Mar 2026 20:12:23 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1442.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2015 11:22:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MySensor lib doesn&#x27;t work with an chip nrfl24l01&#x2F;SE8R01 on Fri, 22 May 2015 21:48:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fc31" aria-label="Profile: fc31">@<bdi>fc31</bdi></a></p>
<p dir="auto">According to <a href="http://nerdralph.blogspot.co.at/2014/11/se8r01-24ghz-wireless-modules.html" rel="nofollow ugc">this</a> site, se8r01 uses another onair format, and is NOT compatible with nrf24l01(+).</p>
<p dir="auto">So I don't think that you'll get any success including it in your existing network with nrf24 modules.</p>
<p dir="auto">If you used an se8r01 as gateway, together with sensors that uses the same transciever, you <em>might</em> have some luck.</p>
]]></description><link>https://forum.mysensors.org/post/14507</link><guid isPermaLink="true">https://forum.mysensors.org/post/14507</guid><dc:creator><![CDATA[tbowmo]]></dc:creator><pubDate>Fri, 22 May 2015 21:48:56 GMT</pubDate></item><item><title><![CDATA[Reply to MySensor lib doesn&#x27;t work with an chip nrfl24l01&#x2F;SE8R01 on Fri, 22 May 2015 14:57:55 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for you help, but i have alway the same issue.</p>
<p dir="auto">I copied this files (from  <a href="https://github.com/TMRh20/RF24" rel="nofollow ugc">https://github.com/TMRh20/RF24</a>) nRF24L01.h, RF24.cpp, RF24.h RF24_config.h into my MySensors\Utility library.<br />
But it doesn't work .<br />
Have you an idea of the problem ?.<br />
I have tested with :</p>
<ul>
<li>SerialGateway</li>
<li>SwitchSensor</li>
</ul>
<p dir="auto">Best regards, FC</p>
<p dir="auto">nota : With the "normal" nrf24l01 module it's work well.</p>
]]></description><link>https://forum.mysensors.org/post/14506</link><guid isPermaLink="true">https://forum.mysensors.org/post/14506</guid><dc:creator><![CDATA[fc31]]></dc:creator><pubDate>Fri, 22 May 2015 14:57:55 GMT</pubDate></item><item><title><![CDATA[Reply to MySensor lib doesn&#x27;t work with an chip nrfl24l01&#x2F;SE8R01 on Fri, 22 May 2015 11:50:59 GMT]]></title><description><![CDATA[<p dir="auto">We're using this RF24 fork.</p>
<p dir="auto"><a href="https://github.com/TMRh20/RF24" rel="nofollow ugc">https://github.com/TMRh20/RF24</a></p>
<p dir="auto">We might ping the author <a class="plugin-mentions-user plugin-mentions-a" href="/user/tmrh20projects" aria-label="Profile: TMRh20Projects">@<bdi>TMRh20Projects</bdi></a> who visits the forum on some occasions.</p>
]]></description><link>https://forum.mysensors.org/post/14497</link><guid isPermaLink="true">https://forum.mysensors.org/post/14497</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Fri, 22 May 2015 11:50:59 GMT</pubDate></item></channel></rss>
