<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UV Sketch use pin A0 or 3?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Building my first project using the UV example sketch. (rebuild of my broken cresta UV sensor in the same housing)<br />
In the wiring things up table <strong>pin 3</strong> is showed as out (<a href="http://www.mysensors.org/build/uv" rel="nofollow ugc">http://www.mysensors.org/build/uv</a>)<br />
But in the sample sketch i see in the first lines of code,  out &gt;&gt;&gt; <strong>A0</strong> &gt;&gt;&gt;</p>
<p dir="auto">Can someone explain which one is the right pin to get a correct output?</p>
<p dir="auto">I like Mysensors a lot btw!!</p>
<p dir="auto">Thanks in advance,</p>
<p dir="auto">Edwin</p>
]]></description><link>https://forum.mysensors.org/topic/1452/uv-sketch-use-pin-a0-or-3</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 02:12:39 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1452.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 May 2015 19:15:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UV Sketch use pin A0 or 3? on Sun, 24 May 2015 20:44:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/edweather" aria-label="Profile: edweather">@<bdi>edweather</bdi></a> said:</p>
<blockquote>
<p dir="auto"><a href="http://www.mysensors.org/build/uv" rel="nofollow ugc">http://www.mysensors.org/build/uv</a></p>
</blockquote>
<p dir="auto">The documentation on site is wrong. A0 is the correct pin. Thanks for reporting, I'll update.</p>
]]></description><link>https://forum.mysensors.org/post/14643</link><guid isPermaLink="true">https://forum.mysensors.org/post/14643</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Sun, 24 May 2015 20:44:58 GMT</pubDate></item></channel></rss>
