  3. Relay with button example sketch, works...but not as expected
15 Posts 4 Posters 5.6k Views 2 Watching
  • R
    R
    roffy
    Hi all, am fairly new to automation but have tinkered with arduino in the past.
    my setup is currently
    VeraLite UI7
    arduino seral gateway (working with no obvious errors)
    1 arduino nanno running door/window/button sketch
    (this is working as expected)
    and the one i have just setup running relayWithButton.
    so, i have no relay to controll i just want my button to be able to activate some scenes in vera.
    the sketch and button are attached and running, added to the vera seemingly ok.
    i can turn on/off the device in the vera UI and can see commands being recieved in serial monitor on the relay node arduino.
    one thing i am stuck on, it seems that my button only changes the device state after the gw has altered it first.
    i.e. if i turn it on in vera, the button when pressed will then turn it off again.
    after that the button becomes useless and i have to turn it back on through the vera UI.
    What am i missing here? is the button behaving as it should or should the button be active (change the device state) every press?
    here is my serial monitor readout of the button press After turning the device on in the vera UI
    Incoming change for sensor:1, New status: 1  //i just turned it on in vera
    send: 2-2-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0        // just pressed the button
    read: 0-0-2 s=1,c=1,t=2,pt=2,l=2:0
    This is an ack from gateway
    and here is the serial monitor readout when pressing the button again without touching the vera UI
    the divice does not change state after the second press.
    Thanks for any help, sorry if im missing something bleeding obvious!
    • rvendrameR
      rvendrameR
      rvendrame
      how are you powering the radio and arduino, on sensor side? Post your sensor's sketch too...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • R
        R
        roffy
        powered from the usb of my PC as i have only uploaded the sketch then went to try it out.
        i was thinking it wasent a power supply problem as the sensor seems to be working ok. no errors or fails in the serial monitor.
        sketch is a direct coppy and past from the example of relay with button. here it is.
        // Example sketch för a "light switch" where you can control light or something
        // else from both vera and a local physical button (connected between digital
        // pin 3 and GND).
        // This node also works as a repeader for other nodes
        #include <Bounce2.h>
        #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
        #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        int oldValue=0;
        bool state;
        MyMessage msg(CHILD_ID,V_LIGHT);
          gw.sendSketchInfo("Relay & Button", "1.0");
         // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_LIGHT);
          pinMode(RELAY_PIN, OUTPUT);
          state = gw.loadState(CHILD_ID);
          gw.process();
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue && value==0) {
              gw.send(msg.set(state?false:true), true); // Send new state and request ack back
          oldValue = value;
          if (message.isAck()) {
          if (message.type == V_LIGHT && strlen(msg.getString()) != 0) {
             // Change relay state
             state = message.getBool();
             // Store state in eeprom
             gw.saveState(CHILD_ID, state);
             // Write some debug info
             Serial.print(message.sensor);
        does this help at all?
        • rvendrameR
          rvendrameR
          rvendrame
          Try changing this line
          to this
          if (value != oldValue) {
          Alexa / Google Home
          • BulldogLowellB
            BulldogLowellB
            BulldogLowell
            wrote on last edited by BulldogLowell
            also, are you aware that you are not changing the variable "state" with a button press?
            nor are you affecting the relay, fyi...
              gw.process();
              debouncer.update();
                  state = !state;
                  digitalWrite(RELAY_PIN, state);
                  gw.send(msg.set(state, true)); // Send new state and request ack back
              oldValue = value;
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
                gw.process();
                debouncer.update();
                    state = !state;
                    gw.saveState(CHILD_ID, state);// forgot to save the new state to EEPROM
                oldValue = value;
              • rvendrameR rvendrame
                to this
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                to this
                I don't think you want to affect a state change on both sides of the button press....
                • rvendrameR
                  rvendrameR
                  rvendrame
                  ... if you are thinking in a pushbutton , yes I agree with you --- But what about a regular on-off switch?
                  Alexa / Google Home
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    For an on/off switch? well you would probably not have that on a device that is also controlled remotely/wirelessly.
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      Why not? I do have the original on/off switch from my lights for example. I want to control them via automation but also via wall switch...
                      Alexa / Google Home
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        yeah, but every wall switch I have, which are integrated into my home automation, are not two position switches. Anyways, the OP has to chime in here... in the rare event he's using a two-position switch, well your code may still need to change. Time to hear from the OP.
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          Just to mention, state is being changed:
                                state = !state;   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                          Alexa / Google Home
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @rvendrame
                            yes, I added that... it was missing from OP's code
                              Yes, as you are aware not the WithButton example was created to be used with a monostable button.
                              Haven't really thought about bi-stable but should be doable.
                              The state is actually not stored in EEPROM until ack message comes back from gateway. It is also only then the actual realy is flipped.
                              As you already mention above removing value==0 would send of a change when flipping button. Not sure if one should pick up oldValue from eeprom at startup as well.
                              • R
                                R
                                roffy
                                wow thanks for all the suggestions guys! sorry for the slow reply, this is the first time iv actually been able to sit at my computer since i posted, if only we didnt have to work to pay bills id be here all day...ahhh if only..... anyway!
                                Yes i am using a pushbutton not a rocker switch so i would need it to only do something on the down press and ignore the upward contact on the release of the button.
                                Ill try changing the script as explained above and see what that does, (as you have probably guessed by now my arduino tinkering only covered the first 10 or so lessons in the basic tutorial, then i went off and only looked up specific coding for the small projects i was working on....and most of which i have forgotten as i haven't used them for a long time :( need to brush up on what i should already know i guess)
                                anyway i shall post results as soon as i try out the suggestions. i think you all get what im trying to achieve here! thanks again,
