<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Serial Port for Node]]></title><description><![CDATA[<p dir="auto">I'd like to use a DF Player Sound Module on a node using a Pro Mini. The sound module can be controlled using a serial interface at 9600 but all serial libraries I've tried - being the usual ones on the Arduino and Teensy websites use interupts and while running well without MySensors included always bring up compilation errors when including MySensors.<br />
Although there is another method of control using stepped analog voltages on other inputs , I'd prefer to use the serial inputs if possible. Has anyone ever connected a serial device to a node?  Any suggestions would be welcome.</p>
]]></description><link>https://forum.mysensors.org/topic/1643/serial-port-for-node</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 16:43:10 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1643.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Jul 2015 00:14:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Serial Port for Node on Thu, 09 Jul 2015 20:36:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bobc" aria-label="Profile: BobC">@<bdi>BobC</bdi></a> OK no problem.  A new idea.  As I only need to Tx to the player I'll just do a bit of bit banging to a pin.  That should work just fine.<br />
The idea behind the project is to add a door bell to my system which has selectable MP3 files to play when the 'button' is pressed.  Really quite a fun thing to have a personalised message to welcome visitors to special events rather than just a DingDong.</p>
]]></description><link>https://forum.mysensors.org/post/16832</link><guid isPermaLink="true">https://forum.mysensors.org/post/16832</guid><dc:creator><![CDATA[BobC]]></dc:creator><pubDate>Thu, 09 Jul 2015 20:36:05 GMT</pubDate></item></channel></rss>
