<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A super easy MQTT getting starting guide?]]></title><description><![CDATA[<p dir="auto">Can anyone recommend one?</p>
<p dir="auto">I did find a recent super easy overview:<br />
<a href="https://www.youtube.com/watch?v=1GbYkCrbChw" rel="nofollow ugc">https://www.youtube.com/watch?v=1GbYkCrbChw</a><br />
but I have no idea how to get going with one, or even what platform I should prefer for the broker (arduino, Pi2, PC, or cloud?).</p>
<p dir="auto">My preferance would be to start with something extremely simple that's already working and then modify it.</p>
<p dir="auto">Suggestions/recommendations?</p>
]]></description><link>https://forum.mysensors.org/topic/1672/a-super-easy-mqtt-getting-starting-guide</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 03:41:00 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1672.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2015 14:38:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Sun, 25 Oct 2015 21:37:26 GMT]]></title><description><![CDATA[<p dir="auto">I had to restart this night which was the first restart since months. Tonight the clocks were changed (Daylight Savings Time). I suspect that this was the reason. Apart from that it is absolutely stable.</p>
]]></description><link>https://forum.mysensors.org/post/23458</link><guid isPermaLink="true">https://forum.mysensors.org/post/23458</guid><dc:creator><![CDATA[tomkxy]]></dc:creator><pubDate>Sun, 25 Oct 2015 21:37:26 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Sun, 25 Oct 2015 20:33:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomkxy" aria-label="Profile: tomkxy">@<bdi>tomkxy</bdi></a> Is it stable ? Do you need to restart OpenHab every while  ?</p>
]]></description><link>https://forum.mysensors.org/post/23449</link><guid isPermaLink="true">https://forum.mysensors.org/post/23449</guid><dc:creator><![CDATA[ahmedadelhosni]]></dc:creator><pubDate>Sun, 25 Oct 2015 20:33:20 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Sun, 25 Oct 2015 15:20:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomkxy" aria-label="Profile: tomkxy">@<bdi>tomkxy</bdi></a> Good. Thank you</p>
]]></description><link>https://forum.mysensors.org/post/23432</link><guid isPermaLink="true">https://forum.mysensors.org/post/23432</guid><dc:creator><![CDATA[ahmedadelhosni]]></dc:creator><pubDate>Sun, 25 Oct 2015 15:20:43 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Sat, 24 Oct 2015 21:29:34 GMT]]></title><description><![CDATA[<p dir="auto">i am currently using a Rpi II running OpenHab and the Mosquito broker. Startup is slow, but it works. However, I do not have a lot of sensor currently connected.</p>
]]></description><link>https://forum.mysensors.org/post/23398</link><guid isPermaLink="true">https://forum.mysensors.org/post/23398</guid><dc:creator><![CDATA[tomkxy]]></dc:creator><pubDate>Sat, 24 Oct 2015 21:29:34 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Sat, 24 Oct 2015 17:23:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gambituk" aria-label="Profile: Gambituk">@<bdi>Gambituk</bdi></a> Is OpenHab stable on the Rpi B+ ? I tried it once but had problems so I'll try it again soon. but It took a lot of time to boot and then failed.</p>
]]></description><link>https://forum.mysensors.org/post/23390</link><guid isPermaLink="true">https://forum.mysensors.org/post/23390</guid><dc:creator><![CDATA[ahmedadelhosni]]></dc:creator><pubDate>Sat, 24 Oct 2015 17:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Sat, 18 Jul 2015 11:45:02 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, that's the one step i didn't do, i already had a Rpi, so i started from this step, but i think they should all be somewhat similar, maybe someone else has tried something but i can't offer any genuine advice.</p>
]]></description><link>https://forum.mysensors.org/post/17256</link><guid isPermaLink="true">https://forum.mysensors.org/post/17256</guid><dc:creator><![CDATA[Gambituk]]></dc:creator><pubDate>Sat, 18 Jul 2015 11:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Fri, 17 Jul 2015 22:51:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gambituk" aria-label="Profile: Gambituk">@<bdi>Gambituk</bdi></a> said:</p>
<blockquote>
<p dir="auto">Cloud is probably easiest to get started..  and then depending what you have available you could try mosquitto on windows as a test, assuming you have a windows box already running and then when you are happy with that and understand what is going on then i would suggest investing in something like a raspberry pi so you can have an always on broker on your home network...</p>
<p dir="auto">I am running mosquito on a Rpi b+ without issues, and also openhab running on the same device, and a mysensors mqtt gateway and several sensor nodes for temp and a power meter that i am working on getting going.</p>
<p dir="auto">Don't know if that helps.</p>
<p dir="auto">Gambituk</p>
</blockquote>
<p dir="auto">Fair enough.  Any suggestions as to which cloud would be easiest to get started with?</p>
]]></description><link>https://forum.mysensors.org/post/17236</link><guid isPermaLink="true">https://forum.mysensors.org/post/17236</guid><dc:creator><![CDATA[NeverDie]]></dc:creator><pubDate>Fri, 17 Jul 2015 22:51:14 GMT</pubDate></item><item><title><![CDATA[Reply to A super easy MQTT getting starting guide? on Fri, 17 Jul 2015 17:25:47 GMT]]></title><description><![CDATA[<p dir="auto">Cloud is probably easiest to get started..  and then depending what you have available you could try mosquitto on windows as a test, assuming you have a windows box already running and then when you are happy with that and understand what is going on then i would suggest investing in something like a raspberry pi so you can have an always on broker on your home network...</p>
]]></description><link>https://forum.mysensors.org/post/17213</link><guid isPermaLink="true">https://forum.mysensors.org/post/17213</guid><dc:creator><![CDATA[Gambituk]]></dc:creator><pubDate>Fri, 17 Jul 2015 17:25:47 GMT</pubDate></item></channel></rss>
