<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[W5100 Ethernet module PoE]]></title><description><![CDATA[<p dir="auto">Hello everyone !</p>
<p dir="auto">I'm trying to supply power to my project using this <a href="http://www.aliexpress.com/item/Free-shipping-W5100-Ethernet-module-Ethernet-network-module-for-arduino/2027367160.html" rel="nofollow ugc">breakout board (W5100)</a> and a PoE injector.</p>
<p dir="auto">The board have PoE+ and PoE- pin directly connected on ethernet pin 8 and 7 but when I provide power through the ethernet cable, there isn't any power on PoE+ and PoE-.</p>
<p dir="auto">Probably I'm doing something wrong...</p>
<p dir="auto">Can someone give me a little help ?</p>
<p dir="auto">Thanks a lot !</p>
]]></description><link>https://forum.mysensors.org/topic/1772/w5100-ethernet-module-poe</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 04:49:18 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1772.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Aug 2015 10:10:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Sun, 17 May 2020 17:48:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi, sorry for the delay, I had just read your post and I could said "me too"<br />
But I solved the problem and it works for two years now.<br />
I explain my solution here, if the French don't afraid you.<br />
<a href="https://easydomoticz.com/forum/viewtopic.php?f=20&amp;t=6497" rel="nofollow ugc">https://easydomoticz.com/forum/viewtopic.php?f=20&amp;t=6497</a><br />
I resume, a 7.5volts power supply, a passive injector, and a spécial home-made cable to bypass the RJ45 socket. The 7.5 v go to Vin-Gnd of the Nano to produce 5v wich is returned to the W5100. QED.</p>
<p dir="auto">Rpx.</p>
]]></description><link>https://forum.mysensors.org/post/105637</link><guid isPermaLink="true">https://forum.mysensors.org/post/105637</guid><dc:creator><![CDATA[Rpx]]></dc:creator><pubDate>Sun, 17 May 2020 17:48:56 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Wed, 30 Nov 2016 07:34:25 GMT]]></title><description><![CDATA[<p dir="auto">To close this topic : this particular module doesn't have anything close to PoE (passive nor active)</p>
<p dir="auto">The PoE labels on the board are Fake or leftover.</p>
]]></description><link>https://forum.mysensors.org/post/53590</link><guid isPermaLink="true">https://forum.mysensors.org/post/53590</guid><dc:creator><![CDATA[SebDominguez]]></dc:creator><pubDate>Wed, 30 Nov 2016 07:34:25 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Wed, 30 Nov 2016 07:11:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi, ive had the same Problem...<br />
According to the datasheet from the rj45 port, poe is not possible in this  circuitry.<br />
<a href="http://www.kosmodrom.com.ua/pdf/HR911105A.pdf" rel="nofollow ugc">http://www.kosmodrom.com.ua/pdf/HR911105A.pdf</a></p>
]]></description><link>https://forum.mysensors.org/post/53588</link><guid isPermaLink="true">https://forum.mysensors.org/post/53588</guid><dc:creator><![CDATA[Niun]]></dc:creator><pubDate>Wed, 30 Nov 2016 07:11:58 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Sat, 16 Jan 2016 18:46:09 GMT]]></title><description><![CDATA[<p dir="auto">Did you have any luck on solving this?</p>
]]></description><link>https://forum.mysensors.org/post/28762</link><guid isPermaLink="true">https://forum.mysensors.org/post/28762</guid><dc:creator><![CDATA[poldim]]></dc:creator><pubDate>Sat, 16 Jan 2016 18:46:09 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Fri, 14 Aug 2015 19:13:47 GMT]]></title><description><![CDATA[<p dir="auto">There isn't any DC/DC converter, but there is 2 pin dedicated to PoE according to the labels on the PCB :/</p>
]]></description><link>https://forum.mysensors.org/post/18980</link><guid isPermaLink="true">https://forum.mysensors.org/post/18980</guid><dc:creator><![CDATA[SebDominguez]]></dc:creator><pubDate>Fri, 14 Aug 2015 19:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Fri, 14 Aug 2015 19:12:55 GMT]]></title><description><![CDATA[<p dir="auto">This module doesn't seem to have a 48v dc/dc converter. At least from the picture I do not recognize it.<br />
Allso I don't see in the description that it have power over ethernet.</p>
]]></description><link>https://forum.mysensors.org/post/18978</link><guid isPermaLink="true">https://forum.mysensors.org/post/18978</guid><dc:creator><![CDATA[pjeterinfo]]></dc:creator><pubDate>Fri, 14 Aug 2015 19:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Fri, 14 Aug 2015 18:46:18 GMT]]></title><description><![CDATA[<p dir="auto">In standard PoE yes,  but I'm trying everything here and I can't get current on those pin.<br />
I'v tried V+ on pin 8 and V- on pin 7, V+ on pin 4, 5, V- to pin 7, 8 and still nothing...</p>
<p dir="auto">this guy : <a href="http://hazymat.co.uk/2015/01/home-automation-poe-with-arduino-in-praise-of-diy-poe/" rel="nofollow ugc">http://hazymat.co.uk/2015/01/home-automation-poe-with-arduino-in-praise-of-diy-poe/</a> had the same issue...</p>
<p dir="auto">Is it possible that this ethernet breakout has "fake" PoE label ?</p>
]]></description><link>https://forum.mysensors.org/post/18974</link><guid isPermaLink="true">https://forum.mysensors.org/post/18974</guid><dc:creator><![CDATA[SebDominguez]]></dc:creator><pubDate>Fri, 14 Aug 2015 18:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Fri, 14 Aug 2015 18:27:59 GMT]]></title><description><![CDATA[<p dir="auto">Are 7 and 8 not both gnd?</p>
]]></description><link>https://forum.mysensors.org/post/18972</link><guid isPermaLink="true">https://forum.mysensors.org/post/18972</guid><dc:creator><![CDATA[pjeterinfo]]></dc:creator><pubDate>Fri, 14 Aug 2015 18:27:59 GMT</pubDate></item><item><title><![CDATA[Reply to W5100 Ethernet module PoE on Fri, 14 Aug 2015 18:14:12 GMT]]></title><description><![CDATA[<p dir="auto">Nobody ?</p>
]]></description><link>https://forum.mysensors.org/post/18966</link><guid isPermaLink="true">https://forum.mysensors.org/post/18966</guid><dc:creator><![CDATA[SebDominguez]]></dc:creator><pubDate>Fri, 14 Aug 2015 18:14:12 GMT</pubDate></item></channel></rss>
