<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Vera Inclusion Not Working]]></title><description><![CDATA[<p dir="auto">Newbie.  Please be gentle.</p>
<p dir="auto">First off a BIG thank you to hek and all of those involved with this.  I wrote my own JSON webservice interface to my Arduino sensors and relays.  I recently bought a Vera Lite and decided to incorporate my Arduino JSON webservice...and then I came across this. You've saved me countless hours and perhaps even saved my marriage.</p>
<p dir="auto">I've added the MySensors USB gateway to my Vera Lite.  In Devices I see the MySensors plugin along with the Start and Stop inclusion buttons.  When I press on the Start button, nothing seems to happen.  The button does not stay highlighted, nor does my sensor (motion) appear after restarting it within the 60 second default time frame.  I tried adding a momentary button and still nothing seems to happen when I attempt to include the sensor.  Should I expect the Start button to be highlighted and/or a message to appear in the message window at the top of the Vera interface page?</p>
<p dir="auto">I have the latest release of the Vera firmware (1.6.641).  The MySensors plug in version is 1.3.</p>
<p dir="auto">Thanks!</p>
<p dir="auto">Robert</p>
]]></description><link>https://forum.mysensors.org/topic/21/vera-inclusion-not-working</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 17:18:07 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/21.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Apr 2014 04:52:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Vera Inclusion Not Working on Wed, 16 Apr 2014 17:03:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistere" aria-label="Profile: MisterE">@<bdi>MisterE</bdi></a><br />
Good!</p>
<p dir="auto">If you try the "broken" radio with a capacitor it will probably work fine.</p>
]]></description><link>https://forum.mysensors.org/post/214</link><guid isPermaLink="true">https://forum.mysensors.org/post/214</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Wed, 16 Apr 2014 17:03:47 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Wed, 16 Apr 2014 16:55:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> That was it.  I swapped the radio and all is well.  Thank you for your patience HEK!</p>
]]></description><link>https://forum.mysensors.org/post/213</link><guid isPermaLink="true">https://forum.mysensors.org/post/213</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Wed, 16 Apr 2014 16:55:53 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Wed, 16 Apr 2014 05:45:20 GMT]]></title><description><![CDATA[<p dir="auto">While waiting for the capacitors you can always try to switch radio (if you got the 10-pack) to rule out HW failure.<br />
Which type of Arduino are you using for the sensor side? And what type of regulator (if any)?</p>
]]></description><link>https://forum.mysensors.org/post/193</link><guid isPermaLink="true">https://forum.mysensors.org/post/193</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Wed, 16 Apr 2014 05:45:20 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Wed, 16 Apr 2014 05:36:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: HEK">@<bdi>HEK</bdi></a> I went through the troubleshoot guide.</p>
<p dir="auto">I am using the latest version of the MySensors library.  The plugin version does not match the library version (Plugin Version 1.3 vs. Lib Version 1.2+).  My understanding based upon another post, is that this discrepancy should be fine.<br />
I've triple-checked the radio wiring.<br />
I have not tried adding a decoupling capacitor.<br />
I am not using an amplified version of the NRF24L01+ chip.</p>
<p dir="auto">Below is a copy of the sensor debug logs:</p>
<p dir="auto">These three lines appear about every second:</p>
<p dir="auto">Relaying message back to gateway.<br />
Tx: fr=255,to=0,la=255,ne=0,ci=255,mt=4,ty=5,cr=136:<br />
Ack: receive timeout</p>
<p dir="auto">These two lines appear every 10 seconds:</p>
<p dir="auto">No relay nodes was found. Trying again in 10 seconds.<br />
Tx: fr=255,to=255,la=255,ne=255,ci=255,mt=4,ty=9,cr=184:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bulldoglowell" aria-label="Profile: BULLDOGLOWELL">@<bdi>BULLDOGLOWELL</bdi></a> I haven't tried the capacitors yet.  I'll order some and give it a try. FWIW, I have the radios within a few feet of each other.</p>
<p dir="auto">If there's anything else you can suggest, I'd greatly appreciate it.</p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.mysensors.org/post/192</link><guid isPermaLink="true">https://forum.mysensors.org/post/192</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Wed, 16 Apr 2014 05:36:17 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Tue, 15 Apr 2014 17:57:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistere" aria-label="Profile: MisterE">@<bdi>MisterE</bdi></a></p>
<p dir="auto">Are you using the capacitors on the radios?</p>
]]></description><link>https://forum.mysensors.org/post/181</link><guid isPermaLink="true">https://forum.mysensors.org/post/181</guid><dc:creator><![CDATA[BulldogLowell]]></dc:creator><pubDate>Tue, 15 Apr 2014 17:57:42 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Tue, 15 Apr 2014 17:16:07 GMT]]></title><description><![CDATA[<p dir="auto">The errors is not related to Arduino plugin.</p>
<p dir="auto">You seem to receive the version from your arduino (which means that communication between vera&lt;-&gt;gw is working).</p>
<p dir="auto">Please check the <a href="http://www.mysensors.org/build/debug" rel="nofollow ugc">troubleshoot guide</a> and post sensor debug logs for further assistance.</p>
]]></description><link>https://forum.mysensors.org/post/180</link><guid isPermaLink="true">https://forum.mysensors.org/post/180</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Tue, 15 Apr 2014 17:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Tue, 15 Apr 2014 16:16:28 GMT]]></title><description><![CDATA[<p dir="auto">I switched to the Ethernet Gateway and I'm now able to see that the Inclusion mode is starting.  The start button is highlighted and stays in Inclusion mode for 60 seconds.  I haven't yet been able to get it to include a sensor and I'm seeing the following in the Vera log files:</p>
<p dir="auto">0	04/15/14 9:09:04.140	luup_log:55: Arduino plugin: library L_Arduino loaded <strong>LEAK</strong> this:57344 start:57344 to 0x928000 &lt;0x2c001680&gt;<br />
50	04/15/14 9:09:04.140	luup_log:55: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.3, 55 &lt;0x2c001680&gt;<br />
50	04/15/14 9:09:04.141	luup_log:55: Arduino: Using network connection: IP address is 192.168.1.77:5003 &lt;0x2c001680&gt;<br />
50	04/15/14 9:09:04.243	luup_log:55: Arduino: Sending: 0;0;4;4;Get Version &lt;0x2c001680&gt;<br />
50	04/15/14 9:09:04.256	luup_log:55: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,ArduinoLibVersion, 1.2+, 55 <strong>LEAK</strong> this:24576 start:81920 to 0x92e000 &lt;0x2e801680&gt;<br />
01	04/15/14 9:09:04.647	FileUtils::ReadURL 0/resp:404 ERROR:Resource doesn't exist size 29 <a href="https://us-device12.mios.com/device/device/device/35021529/kit" rel="nofollow ugc">https://us-device12.mios.com/device/device/device/35021529/kit</a> <strong>LEAK</strong> this:73728 start:155648 to 0x940000 &lt;0x2c001680&gt;<br />
01	04/15/14 9:09:04.650	JobHandler_LuaUPnP::DoFetchKits server: <a href="http://us-device12.mios.com" rel="nofollow ugc">us-device12.mios.com</a> error:404 unable to parse: (null) &lt;0x2c001680&gt;<br />
01	04/15/14 9:09:05.027	FileUtils::ReadURL 0/resp:404 ERROR:Resource doesn't exist size 29 <a href="https://us-device11.mios.com/device/device/device/35021529/kit" rel="nofollow ugc">https://us-device11.mios.com/device/device/device/35021529/kit</a> <strong>LEAK</strong> this:135168 start:290816 to 0x961000 &lt;0x2c001680&gt;<br />
01	04/15/14 9:09:05.029	JobHandler_LuaUPnP::DoFetchKits server: <a href="http://us-device11.mios.com" rel="nofollow ugc">us-device11.mios.com</a> error:404 unable to parse: (null) &lt;0x2c001680&gt;<br />
08	04/15/14 9:10:29.251	JobHandler_LuaUPnP::HandleActionRequest device: 55 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <strong>LEAK</strong> this:69632 start:360448 to 0x972000 &lt;0x2ec01680&gt;</p>
<p dir="auto">The 6th through 9th line are showing errors.  Can anyone point me in the right direction?</p>
]]></description><link>https://forum.mysensors.org/post/179</link><guid isPermaLink="true">https://forum.mysensors.org/post/179</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Tue, 15 Apr 2014 16:16:28 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Mon, 07 Apr 2014 14:38:46 GMT]]></title><description><![CDATA[<p dir="auto">I've checked it on a fresh Arduino IDE install and I'm not seeing anything in the Serial Window.  I've uncommented the debug line in config.h.  If the Serial Gateway is working properly, should I see messages in the Serial Window?</p>
<p dir="auto">Is anyone using MySensors with UI6?</p>
]]></description><link>https://forum.mysensors.org/post/117</link><guid isPermaLink="true">https://forum.mysensors.org/post/117</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Mon, 07 Apr 2014 14:38:46 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Sun, 06 Apr 2014 16:13:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/malx" aria-label="Profile: Malx">@<bdi>Malx</bdi></a> Thanks.  I checked the baud rate in the Serial Window.  It is set to 115200.</p>
]]></description><link>https://forum.mysensors.org/post/107</link><guid isPermaLink="true">https://forum.mysensors.org/post/107</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Sun, 06 Apr 2014 16:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Sun, 06 Apr 2014 13:34:58 GMT]]></title><description><![CDATA[<p dir="auto">You must set the right baudrate in serial window, otherwise you will only get garbage.<br />
(default 115200)</p>
]]></description><link>https://forum.mysensors.org/post/106</link><guid isPermaLink="true">https://forum.mysensors.org/post/106</guid><dc:creator><![CDATA[Malx]]></dc:creator><pubDate>Sun, 06 Apr 2014 13:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Sat, 05 Apr 2014 20:31:33 GMT]]></title><description><![CDATA[<p dir="auto">In the serial window I'm getting "0;0;ô" followed by several "à" characters.</p>
<p dir="auto">In the Arduino IDE, I'm seeing this in the bottom window:</p>
<p dir="auto">Error inside Serial.serialEvent()<br />
java.io.IOException: Bad file descriptor in nativeavailable<br />
at gnu.io.RXTXPort.nativeavailable(Native Method)<br />
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)<br />
at processing.app.Serial.serialEvent(Serial.java:258)<br />
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)<br />
at gnu.io.RXTXPort.eventLoop(Native Method)<br />
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)</p>
<p dir="auto">I am using an Arduino Nano v3.0.</p>
]]></description><link>https://forum.mysensors.org/post/105</link><guid isPermaLink="true">https://forum.mysensors.org/post/105</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Sat, 05 Apr 2014 20:31:33 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Sat, 05 Apr 2014 19:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistere" aria-label="Profile: MisterE">@<bdi>MisterE</bdi></a></p>
<p dir="auto">The plugin has not yet been verified on UI6.</p>
<p dir="auto">What does your Arduino <strong>Nano</strong> (&lt;- important) Gateway say when you plug it into your computer and look at the serial output? Did you turn on debug prints when uploading SerialGateway sketch?</p>
<p dir="auto"><a href="http://mysensors.org/build/debug" rel="nofollow ugc">http://mysensors.org/build/debug</a></p>
]]></description><link>https://forum.mysensors.org/post/104</link><guid isPermaLink="true">https://forum.mysensors.org/post/104</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Sat, 05 Apr 2014 19:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Sat, 05 Apr 2014 19:19:08 GMT]]></title><description><![CDATA[<p dir="auto">I tried the powered USB hub and still no luck.</p>
<p dir="auto">The Vera logs shows the following.  The last two lines are in red.  Does this mean they are failing?<br />
...<br />
50	04/05/14 12:13:04.195	luup_log:49: Arduino: Trying for a serial connection &lt;0x2bf61680&gt;<br />
50	04/05/14 12:13:04.196	luup_log:49: Arduino: Serial port is connected &lt;0x2bf61680&gt;<br />
50	04/05/14 12:13:04.196	luup_log:49: Arduino: Baud is 115200 &lt;0x2bf61680&gt;<br />
50	04/05/14 12:13:04.198	luup_log:49: Arduino: Sending: 0;0;4;4;Get Version &lt;0x2bf61680&gt;<br />
01	04/05/14 12:13:31.119	FileUtils::ReadURL 28/resp:0  size 1 <a href="http://192.168.1.7/get_status.cgi" rel="nofollow ugc">http://192.168.1.7/get_status.cgi</a> <strong>LEAK</strong> this:81920 start:278528 to 0xdc6000 &lt;0x2bf61680&gt;<br />
01	04/05/14 12:13:46.136	FileUtils::ReadURL 28/resp:0  size 1 <a href="http://192.168.1.7/cgi-bin/get_status.cgi" rel="nofollow ugc">http://192.168.1.7/cgi-bin/get_status.cgi</a> &lt;0x2bf61680&gt;</p>
<p dir="auto">I'm using UI6.  Could that be the problem?</p>
]]></description><link>https://forum.mysensors.org/post/103</link><guid isPermaLink="true">https://forum.mysensors.org/post/103</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Sat, 05 Apr 2014 19:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Fri, 04 Apr 2014 13:33:23 GMT]]></title><description><![CDATA[<p dir="auto">I don't think there would be an issue cycling the power but I'm no expert.  It has taken up to 30 seconds to pick up the sensors on occasion.  I usually press start in Vera then power up the sensor.  You should see that sensors are being found in the gateway.</p>
]]></description><link>https://forum.mysensors.org/post/86</link><guid isPermaLink="true">https://forum.mysensors.org/post/86</guid><dc:creator><![CDATA[petewill]]></dc:creator><pubDate>Fri, 04 Apr 2014 13:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Fri, 04 Apr 2014 08:56:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistere" aria-label="Profile: MisterE">@<bdi>MisterE</bdi></a></p>
<p dir="auto">You should see that inclusion mode has started on the vera buttons.</p>
]]></description><link>https://forum.mysensors.org/post/85</link><guid isPermaLink="true">https://forum.mysensors.org/post/85</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Fri, 04 Apr 2014 08:56:12 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Fri, 04 Apr 2014 05:35:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> Love the new slogan, although I'm sure some of our spouses may disagree. ;)  I am using a Nano for the gateway.  I wasn't even aware that there were logs (thanks!), but based upon your questions, I suspect the problem may be that I had an Insteon gateway connected to the Vera's USB port and simply swapped it out for the Arduino gateway.  Perhaps leaving the Insteon gateway configured in Vera is the cause of my problem.  I'll still need the Insteon gateway...because, after all, a man can't have too many gateways.  A powered USB hub should arrive tomorrow which will allow me to use both simultaneously.  An unpowered USB hub didn't solve my issue (no surprise).  I'll test again once the new powered hub arrives.    I'll dive into the logs if the new hub doesn't do the trick.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/petewill" aria-label="Profile: petewill">@<bdi>petewill</bdi></a> - I did have the sensor powered up when I clicked the Start button but recycled power within the default inclusion time of 60 seconds.  Could there be an issue with having it powered up at the time the Start button was pressed even though it was powered down and up shortly  afterwards, or was your issue related to not recycling the power within the inclusion time frame?</p>
<p dir="auto">Can anyone confirm whether there is a visual indicator within the Vera UI during the inclusion period (i.e. Highlighted Start button, message at the top of the screen, etc.)?</p>
]]></description><link>https://forum.mysensors.org/post/84</link><guid isPermaLink="true">https://forum.mysensors.org/post/84</guid><dc:creator><![CDATA[MisterE]]></dc:creator><pubDate>Fri, 04 Apr 2014 05:35:00 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Thu, 03 Apr 2014 19:20:59 GMT]]></title><description><![CDATA[<p dir="auto">When I first started I already had my device powered up then tried to include it.  Make sure it is not powered before you press the inclusion button in Vera</p>
]]></description><link>https://forum.mysensors.org/post/83</link><guid isPermaLink="true">https://forum.mysensors.org/post/83</guid><dc:creator><![CDATA[petewill]]></dc:creator><pubDate>Thu, 03 Apr 2014 19:20:59 GMT</pubDate></item><item><title><![CDATA[Reply to Vera Inclusion Not Working on Thu, 03 Apr 2014 07:02:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistere" aria-label="Profile: MisterE">@<bdi>MisterE</bdi></a></p>
<p dir="auto">"MySensors - The Marriage Saver" - our new slogan. :)</p>
<p dir="auto">I wonder if your Vera really has contact with the Arduino?<br />
You're really using an Arduino Nano? What does the debug prints say when you have the gateway attached to your PC? Do you know how to look in the Vera logs?</p>
]]></description><link>https://forum.mysensors.org/post/82</link><guid isPermaLink="true">https://forum.mysensors.org/post/82</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Thu, 03 Apr 2014 07:02:30 GMT</pubDate></item></channel></rss>
