<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DHT22 Sensor Issue, Maybe Sketch?]]></title><description><![CDATA[<p dir="auto">Created a test sensor with the base humidity sketch on MySensors, using a DHT22. Initially the device is recognized and appears to work, however after a day of use I see that the temperature reading is not being updated. Also, a second sensor on the same node has appeared, with what appears to be incorrect humidity, and temperature that is being translated to F from my already set point of F. This is giving me readings of 160+, when I should be in the 70's. Pictures attached. Not sure where to go from here.</p>
<p dir="auto"><a href="http://www.mysensors.org/build/humidity" rel="nofollow ugc">http://www.mysensors.org/build/humidity</a></p>
<p dir="auto"><img src="/uploads/files/1444251975657-temp2.png" alt="temp2.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/uploads/files/1444251975656-temp1.png" alt="temp1.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/2132/dht22-sensor-issue-maybe-sketch</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 16:08:30 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2132.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Oct 2015 21:07:08 GMT</pubDate><ttl>60</ttl></channel></rss>
