<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[st=fail help please]]></title><description><![CDATA[<p dir="auto">Hi my name is Matias, I´m addicted to this website. I´m building my sensor network and now getting this common error.</p>
<p dir="auto">I have MQTT Gateway with OpenHab as controller</p>
<p dir="auto">MySensor vesion is 1.5 and using Arduino 1.6.5</p>
<p dir="auto">Working on the same room, gateway and 2 sensors are not talking  as they should. I´m getting ST=Fail</p>
<p dir="auto">Here is the Log of one of my Sensors</p>
<p dir="auto">send: 21-21-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=fail:1.5<br />
send: 21-21-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0<br />
repeater started, id=21, parent=0, distance=1<br />
send: 21-21-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=fail:Relay + Humidity<br />
send: 21-21-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1<br />
send: 21-21-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=fail:<br />
send: 21-21-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=fail:<br />
find parent<br />
send: 21-21-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:<br />
send: 21-21-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=fail:<br />
send: 21-21-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=fail:<br />
send: 21-21-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:<br />
send: 21-21-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=fail:</p>
<p dir="auto">Here is my gateway debug</p>
<p dir="auto">0;0;3;0;9;gateway started, id=0, parent=0, distance=0<br />
Ok!<br />
&lt;&lt;10 12 00 06 4D 51 49 73 64 70 03 02 00 3C 00 04 4D 51 54 54</p>
<blockquote>
<blockquote>
<p dir="auto">20 02 00 00<br />
&lt;&lt;82 17 00 E2 00 12 4D 79 4D 51 54 54 2F 32 30 2F 31 2F 56 5F 54 45 4D 50 00<br />
90 03 00 E2 00<br />
MyMQTT/20/1/V_TEMP<br />
0;0;3;0;9;send: 0-0-20-20 s=1,c=1,t=0,pt=0,l=0,sg=0,st=fail:<br />
&lt;&lt;82 16 00 E3 00 11 4D 79 4D 51 54 54 2F 32 30 2F 30 2F 56 5F 48 55 4D 00<br />
90 03 00 E3 00<br />
MyMQTT/20/0/V_HUM<br />
0;0;3;0;9;send: 0-0-20-20 s=0,c=1,t=1,pt=0,l=0,sg=0,st=fail:<br />
&lt;&lt;82 17 00 E4 00 12 4D 79 4D 51 54 54 2F 32 31 2F 31 2F 56 5F 54 45 4D 50 00<br />
90 03 00 E4 00<br />
MyMQTT/21/1/V_TEMP<br />
0;0;3;0;9;send: 0-0-21-21 s=1,c=1,t=0,pt=0,l=0,sg=0,st=fail:<br />
&lt;&lt;82 16 00 E5 00 11 4D 79 4D 51 54 54 2F 32 31 2F 30 2F 56 5F 48 55 4D 00<br />
90 03 00 E5 00<br />
MyMQTT/21/0/V_HUM<br />
0;0;3;0;9;send: 0-0-21-21 s=0,c=1,t=1,pt=0,l=0,sg=0,st=fail:<br />
0;0;3;0;9;read: 21-21-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.0<br />
30 17 00 11 4D 79 4D 51 54 54 2F 32 31 2F 30 2F 56 5F 48 55 4D 33 39 2E 30<br />
0;0;3;0;9;read: 21-21-255 s=255,c=3,t=7,pt=0,l=0,sg=0:<br />
0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0</p>
</blockquote>
</blockquote>
<p dir="auto">and this is what happended on my gateway when I send a command from OpenHab<br />
MyMQTT/21/2/V_LIGHT<br />
0;0;3;0;9;send: 0-0-21-21 s=2,c=1,t=2,pt=0,l=1,sg=0,st=fail:1</p>
<p dir="auto">Sensor does not get any message</p>
<p dir="auto">The 3 radios have the 4.7uF  35v capacitor.<br />
The Gateway has a 3.3 voltage regulator,<br />
I´m using 3 identical 3.3v 8 Mhz Arduino pro mini</p>
<p dir="auto">I don´t know what else to check.</p>
<p dir="auto">Hope you can help me.<br />
Thank you very much.</p>
]]></description><link>https://forum.mysensors.org/topic/2244/st-fail-help-please</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 15:14:59 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2244.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Oct 2015 04:39:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to st=fail help please on Fri, 13 Nov 2015 18:24:47 GMT]]></title><description><![CDATA[<p dir="auto">Hey all,<br />
I started to build an advanced sensor node after playing around the samples. Messed up sometimes, which took me few hours to figure out. So here are some basic things to check (probably for noobs like me):</p>
<ul>
<li>This is NOT a 5V device, connect to 3.3V :)</li>
<li>Call "gw.process()" often! Without it a few messages might be still sent, but ack will surely fail.</li>
<li>Do NOT sleep. use gw.wait() (same when you do long operations on another device, like waiting for Serial events)</li>
<li>double-triple check if you use the same MyConfig.h for your sensors (forgot to flash with the new one)</li>
<li>take care when using interrupts. No Serial in ISR! :)<br />
+1: when you 'present' some sensors with ack, gw.wait() a bit between them for a better success rate.<br />
Hope you won't have these kind of issues.</li>
</ul>
<p dir="auto">// If you this this post should not be here, please rage ;)</p>
]]></description><link>https://forum.mysensors.org/post/24494</link><guid isPermaLink="true">https://forum.mysensors.org/post/24494</guid><dc:creator><![CDATA[Marcell Kovacs]]></dc:creator><pubDate>Fri, 13 Nov 2015 18:24:47 GMT</pubDate></item><item><title><![CDATA[Reply to st=fail help please on Wed, 11 Nov 2015 17:55:24 GMT]]></title><description><![CDATA[<p dir="auto">I have been trying to solve this same error while using the GatewayESP826MQTTClient sketch in the development branch</p>
<p dir="auto">(<a href="http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/2" rel="nofollow ugc">http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/2</a>)</p>
<p dir="auto">I am powering the radio via the 3.3v pin on the nodemcu breakout board.  I have a cap on the radio, as I have on all my radios, and I get very good range and reception.</p>
<p dir="auto">I will try to change the following:</p>
<p dir="auto">#define MY_RF24_PA_LEVEL RF24_PA_LOW</p>
<p dir="auto">Thank you,</p>
<p dir="auto">Mike</p>
]]></description><link>https://forum.mysensors.org/post/24370</link><guid isPermaLink="true">https://forum.mysensors.org/post/24370</guid><dc:creator><![CDATA[Mike Cayouette]]></dc:creator><pubDate>Wed, 11 Nov 2015 17:55:24 GMT</pubDate></item><item><title><![CDATA[Reply to st=fail help please on Sat, 24 Oct 2015 22:23:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/matias53" aria-label="Profile: matias53">@<bdi>matias53</bdi></a> ,</p>
<p dir="auto">Usually the ack failues is solved by decoupling the radio (giving it more stable power). Not sure if you've received a unusually bad batch of NRF-clones or should try to alter the cap-size/channel to get good transmission.</p>
<p dir="auto">Radio sometimes is a bit of voodoo dance. But stable radio powering helps a lot :)</p>
]]></description><link>https://forum.mysensors.org/post/23401</link><guid isPermaLink="true">https://forum.mysensors.org/post/23401</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Sat, 24 Oct 2015 22:23:31 GMT</pubDate></item><item><title><![CDATA[Reply to st=fail help please on Sat, 24 Oct 2015 09:20:55 GMT]]></title><description><![CDATA[<p dir="auto">If these st=fails are gone when you put your finger on the antenna of the radio, then try to use less transmit power.</p>
<p dir="auto">Using the latest development build I do as follows:</p>
]]></description><link>https://forum.mysensors.org/post/23368</link><guid isPermaLink="true">https://forum.mysensors.org/post/23368</guid><dc:creator><![CDATA[GertSanders]]></dc:creator><pubDate>Sat, 24 Oct 2015 09:20:55 GMT</pubDate></item></channel></rss>
