<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESP8266 gateway and sensor node not talking  - noobie]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">I just had all of my parts arrive and are builing my contoller and first sensor (DHT11 on MEGA clone). After flashing both (using the development build), they both seem to be working according to the serial monitor, but i cannot seem to make them talk to each other!</p>
<p dir="auto">Can anyone help me out? I am using the examples on both the gateway and node.</p>
<p dir="auto">Here is the output from the gateway after pressing reset:</p>
<pre><code>0‚~?–4“Ò¶£ÿOAaû0;0;3;0;9;Starting...
scandone
f 0, ....scandone
.add 0
aid 4
pm open phy_2,type:2 0 0
cnt
connected with &lt;ssid&gt;, channel 1
ip:192.168.1.200,mask:255.255.255.0,gw:192.168.1.254
.IP: 192.168.1.200
</code></pre>
<p dir="auto">this is from the sensor node:</p>
<pre><code>Starting...
find parent
send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
find parent
read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
find parent
find parent
find parent
sensor started, id=255, parent=255, distance=255
T:21.00
find parent
H:36.00
find parent
</code></pre>
<p dir="auto">and here is the log from domotitz</p>
<pre><code>2015-10-29 07:11:37.529 Domoticz V2.3347 (c)2012-2015 GizMoCuz
2015-10-29 07:11:37.529 Build Hash: b835f24, Date: 2015-10-15 03:16:03
2015-10-29 07:11:37.554 Sunrise: 05:48:00 SunSet:19:10:00
2015-10-29 07:11:37.554 EventSystem: reset all events...
2015-10-29 07:11:37.561 Active notification subsystems: (0/10)
2015-10-29 07:11:37.657 Webserver started on port: 8080
2015-10-29 07:11:37.662 Started shared server on: ::
2015-10-29 07:11:37.720 Incoming connection from: 127.0.0.1
2015-10-29 07:11:39.666 EventSystem: reset all events...
2015-10-29 07:11:39.667 EventSystem: reset all device statuses...
2015-10-29 07:11:39.667 EventSystem: Started
2015-10-29 07:11:41.672 MySensors: connected to: 192.168.1.200:5003
2015-10-29 07:11:41.672 MySensors: Gateway Ready...
2015-10-29 07:11:42.366 Login successfull : user 'admin'
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/2278/esp8266-gateway-and-sensor-node-not-talking-noobie</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:30:25 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2278.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Oct 2015 20:45:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sat, 13 Feb 2016 08:47:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> I already did! <a href="https://github.com/mysensors/Arduino/pull/396" rel="nofollow ugc">https://github.com/mysensors/Arduino/pull/396</a></p>
]]></description><link>https://forum.mysensors.org/post/31468</link><guid isPermaLink="true">https://forum.mysensors.org/post/31468</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Sat, 13 Feb 2016 08:47:56 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sat, 13 Feb 2016 08:43:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrille" aria-label="Profile: chrille">@<bdi>chrille</bdi></a> Could you create a pull-request (or a bug report) for this fix in MySensors' github repo ?</p>
]]></description><link>https://forum.mysensors.org/post/31464</link><guid isPermaLink="true">https://forum.mysensors.org/post/31464</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sat, 13 Feb 2016 08:43:13 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sat, 13 Feb 2016 08:24:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a>  Thank you very much. This seems to have fixed the issue now!</p>
]]></description><link>https://forum.mysensors.org/post/31458</link><guid isPermaLink="true">https://forum.mysensors.org/post/31458</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Sat, 13 Feb 2016 08:24:38 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sat, 13 Feb 2016 07:51:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrille" aria-label="Profile: chrille">@<bdi>chrille</bdi></a> I'm not familiar with rfm implementation, but you could try adding a call to yield() inside the while loop.</p>
]]></description><link>https://forum.mysensors.org/post/31453</link><guid isPermaLink="true">https://forum.mysensors.org/post/31453</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sat, 13 Feb 2016 07:51:44 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sat, 13 Feb 2016 07:47:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> I think I have narrowed down the issue now to this code in RFM69.cpp</p>
<pre><code class="lang-///">void RFM69::sendACK(const void* buffer, byte bufferSize) {
debug(PSTR("RFM69: void sendACK\n"));
  byte sender = SENDERID;
  debug(PSTR("RFM69: sendACK - entering while()\n"));
  while (!canSend()) receiveDone();
  sendFrame(sender, buffer, bufferSize, false, true);
</code></pre>
<p dir="auto">(The debug lines are added by me)</p>
<p dir="auto">Most of the time the WDT kicks in, after logging "entering while()" - occasionally it will reach sendFrame() and log a "read: " line but then the WDT kicks in when it gets to the while() loop again.<br />
sendAck is called from sendFrame, that disables interrupts, by calling select()</p>
<p dir="auto">With a bunch of additional debug turned on, this is what I get on the console</p>
<pre><code>0;255;3;0;9;Init complete, id=0, parent=0, distance=0
chg_B:-60
chg_B:-120
0;255;3;0;9;RFM69: interruptHandler
0;255;3;0;9;RFM69: IRQ handler - select chip
0;255;3;0;9;RFM69: IRQ handler - release chip
0;255;3;0;9;RFM69: IRQ handler - read RSSI
0;255;3;0;9;RFM69: receiveDone() - payload
0;255;3;0;9;RFM69: void sendACK
chg_B:-60
0;255;3;0;9;RFM69: sendACK - entering while()
0;255;3;0;9;RFM69: sendFrame()
0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
Soft WDT reset
ctx: cont
sp: 3ffefa70 end: 3ffefd30 offset: 01b0
&gt;&gt;&gt;stack&gt;&gt;&gt;
3ffefc20:  00000001 3ffefdd4 3ffeffdc 000000ff
3ffefc30:  00000024 3ffefdd4 3ffeffdc 402022da
3ffefc40:  3ffe8496 00000000 3ffefdd4 40202360
3ffefc50:  00000000 00000000 3ffefdd4 4020254b
3ffefc60:  3ffefdf2 00000000 3ffefdd4 402037f9
3ffefc70:  3fffdc20 00000000 3ffefdd4 3ffefdac
3ffefc80:  3fffdc20 3ffefdf1 3ffefdd4 4020385c
3ffefc90:  00000003 00000000 3ffeecf8 40204035
3ffefca0:  00000003 00000000 00000000 00000000
3ffefcb0:  3ffefd58 3ffefdd4 3ffeffdc 3ffeed00
3ffefcc0:  3ffefe00 00000000 3ffefe98 40203aec
3ffefcd0:  00000003 00000000 000000ff 00000000
3ffefce0:  000000ff 00000002 00000000 00000000
3ffefcf0:  3fffdc20 00000000 3ffeecf8 3ffeed00
3ffefd00:  3fffdc20 00000000 3ffeecf8 40203c06
3ffefd10:  00000000 00000000 3ffeecf8 4020432c
3ffefd20:  00000000 00000000 3ffeed10 40100114
&lt;&lt;&lt;stack&lt;&lt;&lt;
</code></pre>
<p dir="auto">Any ideas on how to fix this, would be greatly appreciated!</p>
]]></description><link>https://forum.mysensors.org/post/31452</link><guid isPermaLink="true">https://forum.mysensors.org/post/31452</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Sat, 13 Feb 2016 07:47:58 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 27 Jan 2016 20:58:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> I did some further tests and it may be related to the inclusion mode feature. At least disabling this makes things more stable - but I still haven't got the radio side working reliable. When this is working I will go back to the gateway and see if I can find out what triggers the crash</p>
]]></description><link>https://forum.mysensors.org/post/29891</link><guid isPermaLink="true">https://forum.mysensors.org/post/29891</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Wed, 27 Jan 2016 20:58:32 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sun, 24 Jan 2016 12:22:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrille" aria-label="Profile: chrille">@<bdi>chrille</bdi></a> said:</p>
<blockquote>
<p dir="auto">the module still reboots</p>
</blockquote>
<p dir="auto">Probably the hardware watchdog kicks in then...</p>
]]></description><link>https://forum.mysensors.org/post/29478</link><guid isPermaLink="true">https://forum.mysensors.org/post/29478</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 24 Jan 2016 12:22:24 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sun, 24 Jan 2016 11:08:49 GMT]]></title><description><![CDATA[<p dir="auto">...I also tried to change TIME_OUT in rfm69.cpp to 500 as suggested by Fabien. Doesn't make any difference</p>
]]></description><link>https://forum.mysensors.org/post/29471</link><guid isPermaLink="true">https://forum.mysensors.org/post/29471</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Sun, 24 Jan 2016 11:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sun, 24 Jan 2016 11:04:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> Just tried that. The change removed the watchdog message and the stack trace, but the module still reboots</p>
]]></description><link>https://forum.mysensors.org/post/29470</link><guid isPermaLink="true">https://forum.mysensors.org/post/29470</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Sun, 24 Jan 2016 11:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sun, 24 Jan 2016 10:58:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrille" aria-label="Profile: chrille">@<bdi>chrille</bdi></a> Try adding the following line to your setup() function:</p>
<pre><code>ESP.wdtDisable();
</code></pre>
<p dir="auto">It <strong>should</strong> disable the (software) watchdog on ESP. See if it continues, or if it will now just hang.</p>
]]></description><link>https://forum.mysensors.org/post/29467</link><guid isPermaLink="true">https://forum.mysensors.org/post/29467</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 24 Jan 2016 10:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Sun, 24 Jan 2016 10:41:35 GMT]]></title><description><![CDATA[<p dir="auto">I am seeing something similar with RFM69 (specifically RFM69CW) and ESP8266. I have build an ESP8266 gateway based on the GatewayESP8266 sketch and this is what I changed</p>
<pre><code>#define MY_RADIO_RFM69
#define MY_GATEWAY_ESP8266
#define MY_RFM69_FREQUENCY   RF69_868MHZ
#define MY_RF69_IRQ_PIN 4
#define MY_RF69_SPI_CS 15
#define MY_RF69_IRQ_NUM 4
</code></pre>
<p dir="auto">I build a sensor node with the DallasTemperatureSensor sketch on an Arduino Mini Pro and defined</p>
</code></pre>
<p dir="auto">When I start up the gateway I see</p>
<pre><code>0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0-beta)
0;255;3;0;9;Radio init successful.
....scandone
state: 0 -&gt; 2 (b0)
state: 2 -&gt; 3 (0)
state: 3 -&gt; 5 (10)
add 0
aid 8
cnt
connected with AP, channel 1
ip:62.x.x.x,mask:255.255.255.128,gw:62.x.x.x
.IP: 62.x.x.x
</code></pre>
<p dir="auto">So far so good - I assume all the radio wiring is OK, since the radio init is successful</p>
<p dir="auto">On the sensor node I see</p>
<pre><code>Starting sensor (RRNNA-, 2.0.0-beta)
find parent
find parent
find parent
Init complete, id=255, parent=255, distance=255
</code></pre>
<p dir="auto">As soon as the sensor node is started the ESP8266 crashes with a WDT reset</p>
<pre><code>Soft WDT reset
ctx: cont
sp: 3ffef370 end: 3ffef630 offset: 01b0
3ffef520:  00000001 3ffef6d4 3ffef964 00000000
3ffef530:  00000024 3ffef6d4 3ffef964 40202436
3ffef540:  3ffe8432 00000000 3ffef6d4 402024bc
3ffef550:  3ffe8432 00000000 3ffef6d4 402026a7
3ffef560:  3ffef6f2 00000001 3ffef6d4 40202b87
3ffef570:  3fffdae0 00000000 3ffee600 3ffef6ac
3ffef580:  3fffdae0 3ffef6f1 3ffef6d4 40202cf4
3ffef590:  3fff1210 00000000 3ffee600 402042b4
3ffef5a0:  00000000 00000002 3ffef82c 40203d20
3ffef5b0:  00000000 3ffef6d4 3ffef964 4020247c
3ffef5c0:  401057ff 00000400 00000103 3ffef5f0
3ffef5d0:  3ffef5e0 00000004 3ffef6cd 4020249c
3ffef5e0:  3ffe8920 00000000 00000000 3ffee608
3ffef5f0:  3fffdae0 00000000 3ffee600 3ffee608
3ffef600:  3fffdae0 00000000 3ffee600 40203e6c
3ffef610:  feefeffe feefeffe 3ffee600 402045b4
3ffef620:  feefeffe feefeffe 3ffee610 40100114
</code></pre>
<p dir="auto">The libraries are 2.0 beta as from a few days ago. I consider the power to the ESP8266 to be OK, since I use the same for en NRF24 based gateway and also for several other ESP modules.</p>
<p dir="auto">From the thread I understand that known issues should be fixed in the current beta. Any ideas on how to move on?</p>
]]></description><link>https://forum.mysensors.org/post/29463</link><guid isPermaLink="true">https://forum.mysensors.org/post/29463</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Sun, 24 Jan 2016 10:41:35 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Mon, 14 Dec 2015 08:28:58 GMT]]></title><description><![CDATA[<p dir="auto">This is working great !</p>
<p dir="auto">Tx for this !</p>
]]></description><link>https://forum.mysensors.org/post/26375</link><guid isPermaLink="true">https://forum.mysensors.org/post/26375</guid><dc:creator><![CDATA[Mersing]]></dc:creator><pubDate>Mon, 14 Dec 2015 08:28:58 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Thu, 10 Dec 2015 18:56:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> :+1:</p>
]]></description><link>https://forum.mysensors.org/post/26136</link><guid isPermaLink="true">https://forum.mysensors.org/post/26136</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Thu, 10 Dec 2015 18:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Thu, 10 Dec 2015 18:22:11 GMT]]></title><description><![CDATA[<p dir="auto">Yep,</p>
<p dir="auto"><a href="https://github.com/mysensors/Arduino/pull/287" rel="nofollow ugc">https://github.com/mysensors/Arduino/pull/287</a></p>
]]></description><link>https://forum.mysensors.org/post/26133</link><guid isPermaLink="true">https://forum.mysensors.org/post/26133</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Thu, 10 Dec 2015 18:22:11 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Thu, 10 Dec 2015 17:28:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> said:</p>
<blockquote>
<p dir="auto">Ok, great. We need to increase timeout then.</p>
</blockquote>
<p dir="auto">Better add a yield() call in those blocking wait loops.<br />
When quiclkly looking over the code of the RF69 driver, the RFM69::initialize call could in theory block for 1.5 sec...<br />
That's a watchdog reset waiting to happen!</p>
]]></description><link>https://forum.mysensors.org/post/26130</link><guid isPermaLink="true">https://forum.mysensors.org/post/26130</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Thu, 10 Dec 2015 17:28:20 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:40:48 GMT]]></title><description><![CDATA[<p dir="auto">Work with 51ms timeout with my config. I set 60ms to be "secure"</p>
]]></description><link>https://forum.mysensors.org/post/26091</link><guid isPermaLink="true">https://forum.mysensors.org/post/26091</guid><dc:creator><![CDATA[Fabien]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:40:48 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:31:15 GMT]]></title><description><![CDATA[<p dir="auto">sorry MY_RF69_IRQ_PIN ...</p>
]]></description><link>https://forum.mysensors.org/post/26089</link><guid isPermaLink="true">https://forum.mysensors.org/post/26089</guid><dc:creator><![CDATA[Fabien]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:31:15 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:30:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fabien" aria-label="Profile: Fabien">@<bdi>Fabien</bdi></a> said:</p>
<blockquote>
<p dir="auto">MY_RF26_IRQ_PIN</p>
</blockquote>
<p dir="auto">I cannot find this defined anywhere...</p>
]]></description><link>https://forum.mysensors.org/post/26088</link><guid isPermaLink="true">https://forum.mysensors.org/post/26088</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:30:34 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:26:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> Yes and perhaps a feature to set MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN when using ESP8266. Do You want to test other timeout values ? Is it critical ?</p>
]]></description><link>https://forum.mysensors.org/post/26087</link><guid isPermaLink="true">https://forum.mysensors.org/post/26087</guid><dc:creator><![CDATA[Fabien]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:26:54 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:25:10 GMT]]></title><description><![CDATA[<p dir="auto">Ok, great. We need to increase timeout then.</p>
]]></description><link>https://forum.mysensors.org/post/26086</link><guid isPermaLink="true">https://forum.mysensors.org/post/26086</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:25:10 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:22:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> you are right it works fine with</p>
<pre><code>#define TIME_OUT 500
</code></pre>
<p dir="auto">in <a href="https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47" rel="nofollow ugc">https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47</a></p>
<pre><code>0�~?�4�!�{�OAa�0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
0;0;3;0;9;Radio init successful.
scandone
.state: 2 -&gt; 3 (0)
add 0
aid 3
cnt
chg_B:-60
connected with PandoraBox_1BB657, channel 1
dhcp client start...
.ip:192.168.2.165,mask:255.255.255.0,gw:192.168.2.1
.IP: 192.168.2.165
0;0;3;0;9;Init complete, id=0, parent=0, distance=0
chg_B:-120
0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.8
0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:54
0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
0;0;3;0;9;read: 1-1-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.4
0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.7
0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:51
0;0;3;0;9;Client 0 connected
0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.5
</code></pre>
<p dir="auto">I don't try with other timeout values.</p>
]]></description><link>https://forum.mysensors.org/post/26083</link><guid isPermaLink="true">https://forum.mysensors.org/post/26083</guid><dc:creator><![CDATA[Fabien]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:22:42 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 21:15:15 GMT]]></title><description><![CDATA[<p dir="auto">With the last git developpement it works. except when a node start presentation, gateway reboot. And sometimes it reboots randomless.<br />
node is a sensebender with MySensors 1.6 and gateway with 1.6 too.<br />
Important : You have to define MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN on ESP8266</p>
#define MY_RF69_IRQ_PIN 15
#define MY_RF69_SPI_CS 2
#define MY_RF69_IRQ_NUM 15
</code></pre>
<p dir="auto">Result is</p>
<pre><code>connected with PandoraBox_1BB657, channel 1
.IP: 192.168.2.165
chg_B:-120
Soft WDT reset
ctx: cont
sp: 3ffef9a0 end: 3ffefc60 offset: 01b0
3ffefb50:  00000001 3ffefd00 3ffeff68 00000001
3ffefb60:  00000024 3ffefd00 3ffeff68 402022f2
3ffefb70:  3ffe8496 00000000 3ffefd00 40202378
3ffefb80:  3ffe8496 00000000 3ffefd00 40202563
3ffefb90:  3ffefd1e 00000001 3ffefd00 40202a43
3ffefba0:  3fffdc20 00000000 3ffeec28 3ffefcd8
3ffefbb0:  3fffdc20 3ffefd1d 3ffefd00 40202e0c
3ffefbc0:  40209c8d 00000000 3ffeec28 40203ed1
3ffefbd0:  00000000 00000002 3ffefe58 402039d0
3ffefbe0:  00000000 3ffefd00 3ffeff68 40202338
3ffefbf0:  40101500 402059d6 3ffeff50 3ffefc20
3ffefc00:  3ffefc10 00000004 3ffefcf9 40202358
3ffefc10:  3fffdc20 00000000 00000000 3ffeec30
3ffefc20:  3fffdc20 00000000 3ffeec28 3ffeec30
3ffefc30:  3fffdc20 00000000 3ffeec28 40203aee
3ffefc40:  00000000 00000000 3ffeec28 402041a0
3ffefc50:  00000000 00000000 3ffeec40 40100114
�!�L�&lt;1���0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
scandone
add 0
aid 3
cnt
chg_B:-60
.IP: 192.168.2.165
chg_B:-120
0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.6
0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.4
</code></pre>
<p dir="auto">And something strange, I only recieve Humidity one time. (sensebender defaut sketch with FORCE_TRANSMIT_INTERVAL 0 )</p>
]]></description><link>https://forum.mysensors.org/post/26082</link><guid isPermaLink="true">https://forum.mysensors.org/post/26082</guid><dc:creator><![CDATA[Fabien]]></dc:creator><pubDate>Wed, 09 Dec 2015 21:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Wed, 09 Dec 2015 06:16:02 GMT]]></title><description><![CDATA[<p dir="auto">Are you getting the same error in dev branch?</p>
]]></description><link>https://forum.mysensors.org/post/26024</link><guid isPermaLink="true">https://forum.mysensors.org/post/26024</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Wed, 09 Dec 2015 06:16:02 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 gateway and sensor node not talking  - noobie on Tue, 08 Dec 2015 23:56:13 GMT]]></title><description><![CDATA[<p dir="auto">I have same bug : <a href="http://forum.mysensors.org/topic/2538/esp8266-and-rfm69w-loop-reboot" rel="nofollow ugc">http://forum.mysensors.org/topic/2538/esp8266-and-rfm69w-loop-reboot</a></p>
]]></description><link>https://forum.mysensors.org/post/26021</link><guid isPermaLink="true">https://forum.mysensors.org/post/26021</guid><dc:creator><![CDATA[Fabien]]></dc:creator><pubDate>Tue, 08 Dec 2015 23:56:13 GMT</pubDate></item></channel></rss>
