<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PiGatewaySerial doesn&#x27;t write to virtual serial device &#x2F;dev&#x2F;ttyMySensorsGateway]]></title><description><![CDATA[<p dir="auto">Hi, I have some troubles with PiGatewaySerial (last version from github), raspberry pi Model B Revision 2.0 (000e)</p>
<pre><code>$ cat /proc/cpuinfo
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 2.00
Features	: half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 000e
Serial		: 00000000b9b39005
</code></pre>
<p dir="auto">When i execute ./PiGatewaySerial, it prints on the screen values read from sensors, but<br />
it doesn't write anything on the  virtual serial device <em>/dev/ttyMySensorsGateway</em></p>
<pre><code>$ sudo ./PiGatewaySerial
Starting PiGatewaySerial...
Protocol version - 1.4
Created PTY '/dev/pts/0'
Gateway tty: /dev/ttyMySensorsGateway
================ SPI Configuration ================
CSN Pin   = CE0 (PI Hardware Driven)
CE Pin   = Custom GPIO25
Clock Speed = 8 Mhz
================ NRF Configuration ================
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xa8a8e1fc01 0xa8a8e1fc00
RX_ADDR_P2-5 = 0xff 0xc4 0xc5 0xc6
TX_ADDR = 0xa8a8e1fc01
RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
EN_AA = 0x3b
EN_RXADDR = 0x06
RF_CH = 0x4c
RF_SETUP = 0x23
CONFIG = 0x0e
DYNPD/FEATURE = 0x3f 0x06
Data Rate = 250KBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_LOW
read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
send: 255-194-1-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
read: 255-0-8 s=255,c=3,t=3,pt=0,l=0:
send: 255-194-1-8 s=255,c=3,t=3,pt=0,l=0,st=fail:
</code></pre>
<p dir="auto">instead, if i read from <em>/dev/ttyMySensorsGateway</em> i obtain only the first<br />
message by the gateway, nothing else.</p>
<pre><code>$ sudo cat /dev/ttyMySensorsGateway
</code></pre>
<pre><code>$ ls -al /dev/ttyMySensorsGateway
lrwxrwxrwx 1 root root 10 nov  5 16:32 /dev/ttyMySensorsGateway -&gt; /dev/pts/0
</code></pre>
<pre><code>$ ls -al /dev/pts/*
crw-rw---- 1 root tty  136, 0 nov  5 16:32 /dev/pts/0
crw--w---- 1 pi   tty  136, 1 nov  5 16:33 /dev/pts/1
c--------- 1 root root   5, 2 gen  1  1970 /dev/pts/ptmx
</code></pre>
<p dir="auto">if i understood anything i think i should find all the messages from remote nodes in <em>/dev/ttyMySensorsGateway</em> but it isn't working like this.<br />
Can you help me please?</p>
]]></description><link>https://forum.mysensors.org/topic/2323/pigatewayserial-doesn-t-write-to-virtual-serial-device-dev-ttymysensorsgateway</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 23:24:04 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2323.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Nov 2015 16:46:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PiGatewaySerial doesn&#x27;t write to virtual serial device &#x2F;dev&#x2F;ttyMySensorsGateway on Thu, 05 Nov 2015 20:43:35 GMT]]></title><description><![CDATA[<p dir="auto">I added the capacitor, but there's always the same problem :(</p>
]]></description><link>https://forum.mysensors.org/post/23974</link><guid isPermaLink="true">https://forum.mysensors.org/post/23974</guid><dc:creator><![CDATA[Michele Rappazzo]]></dc:creator><pubDate>Thu, 05 Nov 2015 20:43:35 GMT</pubDate></item><item><title><![CDATA[Reply to PiGatewaySerial doesn&#x27;t write to virtual serial device &#x2F;dev&#x2F;ttyMySensorsGateway on Thu, 05 Nov 2015 17:58:38 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, can't help you with this one. .. only saw some st=fails in the log which could indicate powering issue of the radio...</p>
]]></description><link>https://forum.mysensors.org/post/23964</link><guid isPermaLink="true">https://forum.mysensors.org/post/23964</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Thu, 05 Nov 2015 17:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to PiGatewaySerial doesn&#x27;t write to virtual serial device &#x2F;dev&#x2F;ttyMySensorsGateway on Thu, 05 Nov 2015 17:55:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> really? Have you read all? How can adding a capacitor write things on the serial instead of terminal output? :O</p>
]]></description><link>https://forum.mysensors.org/post/23963</link><guid isPermaLink="true">https://forum.mysensors.org/post/23963</guid><dc:creator><![CDATA[Michele Rappazzo]]></dc:creator><pubDate>Thu, 05 Nov 2015 17:55:09 GMT</pubDate></item><item><title><![CDATA[Reply to PiGatewaySerial doesn&#x27;t write to virtual serial device &#x2F;dev&#x2F;ttyMySensorsGateway on Thu, 05 Nov 2015 17:53:22 GMT]]></title><description><![CDATA[<p dir="auto">Try adding a capacitor on the radio.</p>
]]></description><link>https://forum.mysensors.org/post/23962</link><guid isPermaLink="true">https://forum.mysensors.org/post/23962</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Thu, 05 Nov 2015 17:53:22 GMT</pubDate></item></channel></rss>
