<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[5v on input to act like a button]]></title><description><![CDATA[<p dir="auto">I have a cheap 433mhz dorbell where I have removed the internal speaker and connected those cables to PIN 3 and GND.</p>
<p dir="auto">When the remote button is pressed the cables supply 4.7v for a couple of seconds. I am powering the arduino from the same three AA batteries that runs the reciever and they are connected to the RAW, GBD on the arduino.</p>
<p dir="auto">I have tried running <a href="http://www.mysensors.org/build/binary" rel="nofollow ugc">http://www.mysensors.org/build/binary</a> but that dont work. How would I modify that sketch to report button pressed when PIN 3 recieves ~5v.</p>
<p dir="auto">Also the arduino is powerd up when I connect the speaker cables to PIN 3, GND and when GND from power supply. Even if I don´t connect the "power" frm the power supply.</p>
]]></description><link>https://forum.mysensors.org/topic/2614/5v-on-input-to-act-like-a-button</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 17:41:08 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2614.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Dec 2015 15:57:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 5v on input to act like a button on Wed, 23 Dec 2015 14:47:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cliff-karlsson" aria-label="Profile: Cliff-Karlsson">@<bdi>Cliff-Karlsson</bdi></a> if you have an AC waveform it will probably be a lot of noise and/or a "sine like"  wave of a certain frequency.<br />
<img src="/uploads/files/1450881227189-upload-6c2f3ec0-fffc-4b45-b839-886304797eb9" alt="upload-6c2f3ec0-fffc-4b45-b839-886304797eb9" class=" img-fluid img-markdown" />. Connected to an optocoupler this will trigger very frequently.</p>
<p dir="auto">What I suggest you do is rectify the signal so that you get a "DC"  signal to use as a trigger.</p>
<p dir="auto"><img src="/uploads/files/1450881699785-upload-768f93c3-149b-4902-8fb3-628813e04a4f" alt="upload-768f93c3-149b-4902-8fb3-628813e04a4f" class=" img-fluid img-markdown" /><br />
thnx <a href="https://en.wikipedia.org/wiki/Rectifier#Full-wave_rectification" rel="nofollow ugc">wiki</a></p>
<p dir="auto">Connect the +Vo and GND to your optocoupler (in series with a resistor of around 470 Ohm). C1 = 100uF &amp;  R1 = 1kOhm will do to get a reasonable clean signal.</p>
<p dir="auto">You can attach the optocoupler to the interrupt (D2 or D3) and do whatever you want with it using gw.sleep(...)</p>
]]></description><link>https://forum.mysensors.org/post/26893</link><guid isPermaLink="true">https://forum.mysensors.org/post/26893</guid><dc:creator><![CDATA[AWI]]></dc:creator><pubDate>Wed, 23 Dec 2015 14:47:47 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Tue, 22 Dec 2015 15:44:57 GMT]]></title><description><![CDATA[<p dir="auto">Well I "tapped" the signal from the speaker wires and as soward stated above "The speaker is probably being sent an AC waveform" -maybe that is causing the strange behaviour. I tried finding other places to use but most of them only gave me ~0.1V when the button was pushed and I thought I needed more power to trigger the octocoupler.</p>
<p dir="auto">But can I modify the code somehow so that I culd use sleep on interrupt but force the arduino to only report the first "trigger" and the go back to sleep again?</p>
<p dir="auto">I will upload a picture too if unclear.</p>
]]></description><link>https://forum.mysensors.org/post/26832</link><guid isPermaLink="true">https://forum.mysensors.org/post/26832</guid><dc:creator><![CDATA[Cliff Karlsson]]></dc:creator><pubDate>Tue, 22 Dec 2015 15:44:57 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Tue, 22 Dec 2015 13:28:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cliff-karlsson" aria-label="Profile: Cliff-Karlsson">@<bdi>Cliff-Karlsson</bdi></a> I find it hard to figure out why you are getting a double trigger from your circuit. As you don't have a mechanical switch I think the cause is in the circuit. Can draw it or post a picture?</p>
]]></description><link>https://forum.mysensors.org/post/26828</link><guid isPermaLink="true">https://forum.mysensors.org/post/26828</guid><dc:creator><![CDATA[AWI]]></dc:creator><pubDate>Tue, 22 Dec 2015 13:28:36 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Mon, 21 Dec 2015 05:58:40 GMT]]></title><description><![CDATA[<p dir="auto">Ok, thanks. I think I read somewhere that there could be problems using debounce and sleep. Can I still use debounce and sleep until interrupt on Pin 3?</p>
]]></description><link>https://forum.mysensors.org/post/26746</link><guid isPermaLink="true">https://forum.mysensors.org/post/26746</guid><dc:creator><![CDATA[Cliff Karlsson]]></dc:creator><pubDate>Mon, 21 Dec 2015 05:58:40 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Mon, 21 Dec 2015 05:17:42 GMT]]></title><description><![CDATA[<p dir="auto">Yup  just change the debounce until your second trigger is no longer an issue. and well done going opto it's much safer.</p>
<p dir="auto">That delay is only 5ms  and the 1000 is 1s.<br />
Times on delays are only approximate as the program takes time to run itself causing other slight delays.</p>
]]></description><link>https://forum.mysensors.org/post/26744</link><guid isPermaLink="true">https://forum.mysensors.org/post/26744</guid><dc:creator><![CDATA[BSB]]></dc:creator><pubDate>Mon, 21 Dec 2015 05:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Mon, 21 Dec 2015 05:07:53 GMT]]></title><description><![CDATA[<p dir="auto">OK, so if I change</p>
<pre><code>debouncer.interval(5);
</code></pre>
<p dir="auto">to</p>
<pre><code>debouncer.interval(1000);
</code></pre>
<p dir="auto">It will skip any button that are sent within 1 sec of the first buttonpress?<br />
Regarding the voltage-spike I am using a optocoupler this time so there are no current sent to the arduino. It only acts like I connect PIN 3 to GND.</p>
]]></description><link>https://forum.mysensors.org/post/26743</link><guid isPermaLink="true">https://forum.mysensors.org/post/26743</guid><dc:creator><![CDATA[Cliff Karlsson]]></dc:creator><pubDate>Mon, 21 Dec 2015 05:07:53 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Sun, 20 Dec 2015 22:15:02 GMT]]></title><description><![CDATA[<p dir="auto">Find out where the second pulse comes from and mitigate it.</p>
<p dir="auto">You already have a debounce in there so increase the time there to start with.</p>
<p dir="auto">You may also want to put a voltage divider in there too in case its actually a voltage spike as suggested already.</p>
<p dir="auto">Is there any sort of relay involved in the whole circuit as it could also be chatter ?</p>
]]></description><link>https://forum.mysensors.org/post/26734</link><guid isPermaLink="true">https://forum.mysensors.org/post/26734</guid><dc:creator><![CDATA[BSB]]></dc:creator><pubDate>Sun, 20 Dec 2015 22:15:02 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Sun, 20 Dec 2015 19:34:18 GMT]]></title><description><![CDATA[<p dir="auto">But now I have a new problem. I am using this sketch:</p>
<pre><code>// Enable debug prints to serial monitor
#include &lt;SPI.h&gt;
#include &lt;MySensor.h&gt;
#include &lt;Bounce2.h&gt;
#define CHILD_ID 3
#define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
Bounce debouncer = Bounce();
int oldValue=-1;
  // Setup the button
  pinMode(BUTTON_PIN,INPUT);
  // Activate internal pull-up
  debouncer.attach(BUTTON_PIN);
void presentation() {
  present(CHILD_ID, S_DOOR);
  debouncer.update();
  // Get the update value
  int value = debouncer.read();
  if (value != oldValue) {
     // Send in the new value
     send(msg.set(value==HIGH ? 1 : 0));
     oldValue = value;
</code></pre>
<p dir="auto">But I always get two triggers for one one button press. So the status is never changed like: Start state= ON, trigger OFF,TriggerON.</p>
<p dir="auto">How can I make it so that It has to be more then 2 seconds apart from the triggers? So that the second rapid trigger command is filtered and not reported to domoticz ?</p>
<p dir="auto">Also I would like the arduino to sleep as long as it is not detecting any button-press on PIN 3</p>
]]></description><link>https://forum.mysensors.org/post/26717</link><guid isPermaLink="true">https://forum.mysensors.org/post/26717</guid><dc:creator><![CDATA[Cliff Karlsson]]></dc:creator><pubDate>Sun, 20 Dec 2015 19:34:18 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Sun, 20 Dec 2015 19:26:52 GMT]]></title><description><![CDATA[<p dir="auto">Solved it by using a optocoupler on the signal from the speakers.</p>
]]></description><link>https://forum.mysensors.org/post/26716</link><guid isPermaLink="true">https://forum.mysensors.org/post/26716</guid><dc:creator><![CDATA[Cliff Karlsson]]></dc:creator><pubDate>Sun, 20 Dec 2015 19:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to 5v on input to act like a button on Sun, 20 Dec 2015 16:31:40 GMT]]></title><description><![CDATA[<p dir="auto">The speaker is probably being sent an AC waveform, and the meter is just averaging it out so you see 4.7v. Likewise there may be some DC power from one side of it to gnd all the time since it's able to energize the Arduino.</p>
<p dir="auto">Best would be to trace the circuit further back and see if there is something else you can tap into ahead of the speaker and it's driver.</p>
<p dir="auto">If not you might be able to tie the speaker outputs together through a diode and a small resistor ( say 16Ohm ) and hook that to pin 3 -- or not depending on how it's driven. Or you could build a voltage dividing circuit to keep the AC voltage down to ~2v and use an ADC pin to read the waveform being sent to the speaker.</p>
]]></description><link>https://forum.mysensors.org/post/26708</link><guid isPermaLink="true">https://forum.mysensors.org/post/26708</guid><dc:creator><![CDATA[soward]]></dc:creator><pubDate>Sun, 20 Dec 2015 16:31:40 GMT</pubDate></item></channel></rss>
