<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble with ethernet gateway]]></title><description><![CDATA[<p dir="auto">Hello again ;)</p>
<p dir="auto">I'm trying to go with the EthernetGateway and a w5100 ethernetshield.<br />
I am not sure, if the ethernet part is working.</p>
<p dir="auto">why?</p>
<ol>
<li>I can't finde the nodes in domoticz (although domoticz claims to be connected to the GW)</li>
<li>when doing an nc to the gateway:port nothing happens</li>
</ol>
<p dir="auto">the nodes can find the GW, at least in the gw serial monitor i can see them polling for an ID</p>
<p dir="auto">Log:</p>
<pre><code>0;255;3;0;9;Starting gateway (RNNGAS, 1.6.0-beta)
0;255;3;0;9;Radio init successful.
IP: 192.168.100.10
0;255;3;0;9;Init complete, id=0, parent=0, distance=0
</code></pre>
<p dir="auto">Any Idea?</p>
]]></description><link>https://forum.mysensors.org/topic/2703/trouble-with-ethernet-gateway</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 01:41:56 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2703.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Jan 2016 00:46:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble with ethernet gateway on Mon, 04 Jan 2016 01:47:35 GMT]]></title><description><![CDATA[<p dir="auto">hmm this helped ... i think oO did  a lot of stuff and suddenly iw works :confused:  really strange</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mysensors.org/post/27603</link><guid isPermaLink="true">https://forum.mysensors.org/post/27603</guid><dc:creator><![CDATA[dakky]]></dc:creator><pubDate>Mon, 04 Jan 2016 01:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with ethernet gateway on Mon, 04 Jan 2016 01:43:36 GMT]]></title><description><![CDATA[<p dir="auto">Try to erase EEPROM in arduino. You find the sketch under MySensors-Clear....</p>
<p dir="auto">If that node has been connected before maybe that is the problem.</p>
]]></description><link>https://forum.mysensors.org/post/27602</link><guid isPermaLink="true">https://forum.mysensors.org/post/27602</guid><dc:creator><![CDATA[flopp]]></dc:creator><pubDate>Mon, 04 Jan 2016 01:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with ethernet gateway on Mon, 04 Jan 2016 01:39:02 GMT]]></title><description><![CDATA[<p dir="auto">As soon as i hardcode a node ID in my sketch, i can see everthing as usual in die serials (node reporting values, arriving on gateway, signing ok etc)</p>
<p dir="auto">As soon as i set a AUTO id, nothing works, because i get no node id from domoticz</p>
<p dir="auto">:(</p>
]]></description><link>https://forum.mysensors.org/post/27601</link><guid isPermaLink="true">https://forum.mysensors.org/post/27601</guid><dc:creator><![CDATA[dakky]]></dc:creator><pubDate>Mon, 04 Jan 2016 01:39:02 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with ethernet gateway on Mon, 04 Jan 2016 01:03:01 GMT]]></title><description><![CDATA[<p dir="auto">I also just setup an Ethernet Gateway, was using Serial before.</p>
<p dir="auto">If you have DEBUG mode ON you shall see data from the nodes in Arduino IDE Serial Monitor.<br />
Do you see data coming from Sensor?</p>
<p dir="auto">If you see them in Arduino IDE they should appear in Domoticz.</p>
]]></description><link>https://forum.mysensors.org/post/27599</link><guid isPermaLink="true">https://forum.mysensors.org/post/27599</guid><dc:creator><![CDATA[flopp]]></dc:creator><pubDate>Mon, 04 Jan 2016 01:03:01 GMT</pubDate></item></channel></rss>
