<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Irrigation Controller - Relays not working??]]></title><description><![CDATA[<p dir="auto">Hi All<br />
<strong>Background</strong>: I have been following the tutorial on the MySensors build section for the "Irrigation Controller"<br />
I have a Raspberry Pi 2b with Domoticz installed acting as the "Controller". The RaPi2b is powered by a 12v AC Transformer to an inline battery charger with an output of 12v DC and this output is connected to a cigarette/USB (the car charger type) with a 5v output.<br />
The RaPi2b is connected  by a USB cable to an Arduino Uno R3 and this has the Serial Gateway code running on it with the NRF24L01+.</p>
<p dir="auto">I have another Arduino Uno R2 with an NRF24L01+ with the IrrigationController sketch running on it. It compiles and uploads fine.<br />
This Uno has a breadboard and I have connected every thing up as per the tutorial.<br />
a short video  - apologies for the lack of narrative but I sound awful and just hate the sound of my own voice - one of those things :)</p>
<p dir="auto"><strong>Main Issue</strong> : From the video - everything works OK (so it seems) except that the relays don't come on. I have tested the relays with this <a href="https://arduino-info.wikispaces.com/ArduinoPower" rel="nofollow ugc">IDE sketch</a> - (go right to the bottom and look for the  8-channel Solid State Relay Board sketch) and the relays works fine!!<br />
This is the 8 Relay module (Active Low) with the optocouplers. All I want to see and hear  is that the LED on the relay comes on and you can hear the click (just for testing) of the relay.<br />
I have the relay 1 on pin15 on the shift register and relays 2-8 on pins 1-7. The Gnd and VCC is connected OK<br />
I checked that the wiring was correct on the shift register as well as for the radio, LCD, push button etc as per the wiring diagram for the Irrigation Controller - all seems OK<br />
The debug output from the terminal monitor seems OK as well - Is there something on the code that has changed.<br />
I haven't changed anything on the code except for the LCD display as the tutorial guide used the 1602 (16 characters 2 lines) LCD and I have the 2004A.<br />
Apart from that change - nothing else.</p>
<p dir="auto">I bought another 8 Relay Module to test and exactly the same. When I push the pushbutton for example Zone 1 it counts down and off it goes abut the realy LED does not come on or the "click" sound of the relay activating</p>
<p dir="auto">Any ideas - I am really stuck as I must be doing something wrong??<br />
I have uploaded the video on my dropbox folder<br />
<a href="https://www.dropbox.com/s/2pfwk8hdgrydu7r/video1.mp4?dl=0" rel="nofollow ugc">https://www.dropbox.com/s/2pfwk8hdgrydu7r/video1.mp4?dl=0</a></p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.mysensors.org/topic/2720/irrigation-controller-relays-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 08:31:50 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2720.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Jan 2016 16:26:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Irrigation Controller - Relays not working?? on Mon, 11 Jan 2016 10:57:39 GMT]]></title><description><![CDATA[<p dir="auto">OK:) - Good news I have resolved the issues and thought I would update :)</p>
<p dir="auto">As mentioned I used the UNO's as my micro controllers - I decided to use the Pro Minis instead. I set it up on the breadboard and for some reason they worked. I noticed in the code that there was an interrupt command for the Pro Mini and I am not at the coding experience to understand if this might have been the problem when I used the UNO's??</p>
<pre><code>attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
</code></pre>
<p dir="auto">Anyway the code worked like a charm except now the LCD display kept crashing the system. After MUCH hours trying to figure out why and lots of experiments, I swapped out the Pro Mini for another one and this worked 100%.<br />
Having a closer look at my soldering on the A4 and A5 pins became clear where the issue was :)</p>
<p dir="auto">Anyway - its up and running 100% and am very happy. I can now control all the zones from my Domoticz (Raspberry Pi), notifications through Clikatell (SMS) and e-mail works well and I am very chuffed it works!!<br />
Thanks to Pete and Bulldog as well as the forum for the help !! You guys rock!!<br />
My next project is my Gargage door (open/closed) with the ultrasonic sensors - the wife is always leaving it open!!<br />
Cheers<br />
Wallis</p>
]]></description><link>https://forum.mysensors.org/post/28289</link><guid isPermaLink="true">https://forum.mysensors.org/post/28289</guid><dc:creator><![CDATA[ciscokid]]></dc:creator><pubDate>Mon, 11 Jan 2016 10:57:39 GMT</pubDate></item><item><title><![CDATA[Reply to Irrigation Controller - Relays not working?? on Wed, 06 Jan 2016 18:42:32 GMT]]></title><description><![CDATA[<p dir="auto">I am also using this with some of the code commented out to handle the time duration for the zones as per Bulldogs recommendations</p>
<pre><code>/*
MySprinkler for MySensors
Arduino Multi-Zone Sprinkler Control
May 31, 2015
*** Version 2.0
*** Upgraded to http://MySensors.org version 1.4.1
*** Expanded for up to 16 Valves
*** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
*** Switch to bitshift method vs byte arrays
*** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
*** Added optional LCD display featuring remaining time, date last ran &amp; current time
*** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
*** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
*** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
Utilizing your Vera home automation controller and the MySensors.org gateway you can
control up to a sixteen zone irrigation system with only three digital pins.  This sketch
will create NUMBER_OF_VALVES + 1 devices on your Vera controller
This sketch features the following:
* Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
* Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
  using Variable1 as the "ON" time in minutes in each of the vera devices created.
* Use the individual zone controller to activate a single zone.  This feature uses
  Variable2 as the "ON" time for each individual device/zone.
* Connect according to pinout below and uses Shift Registers as to allow the MySensors
  standard radio configuration and still leave available digital pins
* Turning on any zone will stop the current process and begin that particular process.
* Turning off any zone will stop the current process and turn off all zones.
* To push your new time intervals for your zones, simply change the variable on your Vera and
  your arduino will call to Vera once a minute and update accordingly.  Variables will also be
  requested when the device is first powered on.
* Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
* LED status indicator
PARTS LIST:
Available from the MySensors store - http://www.mysensors.org/store/
* Relays (8 channel)
* Female Pin Header Connector Strip
* Prototype Universal Printed Circuit Boards (PCB)
* NRF24L01 Radio
* Arduino (I used a Pro Mini)
* FTDI USB to TTL Serial Adapter
* Capacitors (10uf and .1uf)
* 3.3v voltage regulator
* Resistors (270 &amp; 10K)
* Female Dupont Cables
* 1602 LCD (with I2C Interface)
* LED
* Push button
* Shift Register (SN74HC595)
* 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
* 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
* 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
* 18 gauge wire (for relay)
* Irrigation Power Supply (24-Volt/750 mA Transformer)
INSTRUCTIONS:
* A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
* After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
  A4 and A5) and relays, and load the sketch.
* Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
* Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
  the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
  you may use the defaulet zone names by leaving Variable3 blank.
* Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
* Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
  on the serial monitor.
* Your arduino should slow-flash, indicating that it is in ready mode.
* There are multiple debug serial prints that can be monitored to assure that it is operating properly.
* ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
#include &lt;Wire.h&gt;
#include &lt;Time.h&gt;
#include &lt;MySensor.h&gt;
#include &lt;SPI.h&gt;
#include &lt;LiquidCrystal.h&gt;
#include &lt;LiquidCrystal_I2C.h&gt;
#define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
#define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
#define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
#define SKETCH_NAME "MySprinkler"
#define SKETCH_VERSION "2.0"
#define CHILD_ID_SPRINKLER 0
#define ACTIVE_LOW // comment out this line if your relays are active high
#define DEBUG_ON   // comment out to supress serial monitor output
#ifdef ACTIVE_LOW
#define BITSHIFT_VALVE_NUMBER ~(1U &lt;&lt; (valveNumber-1))
#define ALL_VALVES_OFF 0xFFFF
#else
#define BITSHIFT_VALVE_NUMBER (1U &lt;&lt; (valveNumber-1))
#define ALL_VALVES_OFF 0U
#ifdef DEBUG_ON
#define DEBUG_PRINT(x)   Serial.print(x)
#define SERIAL_START(x)  Serial.begin(x)
#else
typedef enum {
  STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
SprinklerStates;
SprinklerStates state = STAND_BY_ALL_OFF;
SprinklerStates lastState;
byte menuState = 0;
unsigned long menuTimer;
byte countDownTime = 10;
int allZoneTime [NUMBER_OF_VALVES + 1] = {0,20,20,20,20,20,20,20,20};
int valveSoloTime [NUMBER_OF_VALVES + 1] = {0,20,20,20,20,20,20,20,20};
int valveNumber;
int lastValve;
unsigned long startMillis;
const int ledPin = 5;
const int waterButtonPin = 3;
boolean buttonPushed = false;
boolean showTime = true;
boolean clockUpdating = false;
boolean recentUpdate = true;
const char *dayOfWeek[] = {
  "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
// Name your Zones here or use Vera to edit them by adding a name in Variable3...
String valveNickName[17] = {
  "All Zones", "5 Sprinkler Front Door", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
time_t lastTimeRun = 0;
//Setup Shift Register...
const int latchPin = 8;
const int clockPin = 4;
const int dataPin  = 7;
byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
  SERIAL_START(115200);
  DEBUG_PRINTLN(F("Initialising..."));
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(waterButtonPin, INPUT_PULLUP);
  //pinMode(waterButtonPin, INPUT);
  digitalWrite (ledPin, HIGH);
  DEBUG_PRINTLN(F("Turning All Valves Off..."));
  updateRelays(ALL_VALVES_OFF);
  //delay(5000);
  lcd.begin(20, 4); //(16 characters and 2 line display)
  lcd.clear();
  lcd.backlight();
  lcd.createChar(0, clock);
  lcd.createChar(1, raindrop);
  //check for saved date in EEPROM
  DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
  delay(500);
  if (gw.loadState(0) == 0xFF); // EEPROM flag
    DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
    for (int i = 0; i &lt; 4 ; i++)
      lastTimeRun = lastTimeRun &lt;&lt; 8;
      lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
  gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
  gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
  for (byte i = 0; i &lt;= NUMBER_OF_VALVES; i++)
    gw.present(i, S_LIGHT);
  DEBUG_PRINTLN(F("Sensor Presentation Complete"));
  digitalWrite (ledPin, LOW);
  DEBUG_PRINTLN(F("Ready..."));
  lcd.setCursor(0, 0);
  lcd.print(F(" Syncing Time  "));
  lcd.setCursor(15, 0);
  lcd.write(byte(0));
  lcd.setCursor(0, 1);
  int clockCounter = 0;
  while (timeStatus() == timeNotSet &amp;&amp; clockCounter &lt; 21)
    gw.process();
    gw.requestTime(receiveTime);
    DEBUG_PRINTLN(F("Requesting time from Gateway:"));
    delay(1000);
    lcd.print(".");
    clockCounter++;
    if (clockCounter &gt; 16)
      DEBUG_PRINTLN(F("Failed initial clock synchronization!"));
      lcd.clear();
      lcd.print(F("  Failed Clock  "));
      lcd.print(F(" Syncronization "));
      delay(2000);
      break;
  lcd.clear();
  //Update valve data when first powered on
    lcd.print(F(" Updating  "));
    lcd.print(F(" Valve Data: "));
    lcd.print(i);
    boolean flashIcon = false;
    DEBUG_PRINT(F("Calling for Valve "));
    DEBUG_PRINT(i);
    DEBUG_PRINTLN(F(" Data..."));
    while (gw.process() == false)
      flashIcon = !flashIcon;
      flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
      gw.request(i, V_VAR1);
      delay(100);
      gw.request(i, V_VAR2);
      delay(100);
      gw.request(i, V_VAR3);
      delay(100);
  lcd.clear();
  gw.process();
  updateClock();
  updateDisplay();
 // goGetValveTimes();
  if (buttonPushed)
    menuTimer = millis();
    DEBUG_PRINTLN(F("Button Pressed"));
    if (state == STAND_BY_ALL_OFF)
      state = ZONE_SELECT_MENU;
      menuState = 0;
    else if (state == ZONE_SELECT_MENU)
      menuState++;
      if (menuState &gt; NUMBER_OF_VALVES)
        menuState = 0;
    else
    slowToggleLED ();
    if (state != lastState)
      DEBUG_PRINTLN(F("State Changed... all Zones off"));
        delay(50);
        gw.send(msg1valve.setSensor(i).set(false), false);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print(F("** Irrigation **"));
      lcd.setCursor(0,1);
      lcd.print(F("**   Halted   **"));
      delay(2000);
      lastValve = -1;
  else if (state == RUN_ALL_ZONES)
    if (lastValve != valveNumber)
        if (i == 0 || i == valveNumber)
          gw.send(msg1valve.setSensor(i).set(true), false);
        else
    lastValve = valveNumber;
    fastToggleLed();
      valveNumber = 1;
      DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
    unsigned long nowMillis = millis();
    if (nowMillis - startMillis &lt; VALVE_RESET_TIME)
    else if (nowMillis - startMillis &lt; (allZoneTime[valveNumber] * 60000UL))
      updateRelays(BITSHIFT_VALVE_NUMBER);
    else
      DEBUG_PRINTLN(F("Changing Valves..."));
      startMillis = millis();
      valveNumber++;
      if (valveNumber &gt; NUMBER_OF_VALVES)
        state = CYCLE_COMPLETE;
        lastValve = -1;
        lastTimeRun = now();
        saveDateToEEPROM(lastTimeRun);
        DEBUG_PRINT(F("State = "));
        DEBUG_PRINTLN(state);
  else if (state == RUN_SINGLE_ZONE)
    fastToggleLed();
        else
      DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
      DEBUG_PRINT(F("Zone: "));
      DEBUG_PRINTLN(valveNumber);
    else if (nowMillis - startMillis &lt; (valveSoloTime [valveNumber] * 60000UL))
    else
  else if (state == CYCLE_COMPLETE)
    if (millis() - startMillis &lt; 30000UL)
      fastToggleLed();
    else
  else if (state = ZONE_SELECT_MENU)
    displayMenu();
  lastState = state;
void displayMenu(void)
  static byte lastMenuState = -1;
  static int lastSecond;
  if (menuState != lastMenuState)
    lcd.clear();
    lcd.print(valveNickName[menuState]);
    lcd.print(F("Starting"));
    DEBUG_PRINT(valveNickName[menuState]);
    Serial.print(F(" Starting Shortly"));
  int thisSecond = (millis() - menuTimer) / 1000UL;
  if (thisSecond != lastSecond &amp;&amp; thisSecond &lt; 8)
    lcd.print(F("."));
    Serial.print(".");
  lastSecond = thisSecond;
  if (millis() - menuTimer &gt; 10000UL)
    if (menuState == 0)
      valveNumber = 1;
      state = RUN_ALL_ZONES;
    else
      valveNumber = menuState;
      state = RUN_SINGLE_ZONE;
  else
  lastMenuState = menuState;
void updateRelays(int value)
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
  shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
  digitalWrite(latchPin, HIGH);
void PushButton() //interrupt with debounce
  static unsigned long last_interrupt_time = 0;
  unsigned long interrupt_time = millis();
  if (interrupt_time - last_interrupt_time &gt; 200)
    buttonPushed = true;
  last_interrupt_time = interrupt_time;
void fastToggleLed()
  static unsigned long fastLedTimer;
  if (millis() - fastLedTimer &gt;= 100UL)
    digitalWrite(ledPin, !digitalRead(ledPin));
    fastLedTimer = millis ();
void slowToggleLED ()
  static unsigned long slowLedTimer;
  if (millis() - slowLedTimer &gt;= 1250UL)
    slowLedTimer = millis ();
void getVariables(const MyMessage &amp;message)
  boolean zoneTimeUpdate = false;
  if (message.isAck())
    DEBUG_PRINTLN(F("This is an ack from gateway"));
    if (message.sensor == i)
      if (message.type == V_LIGHT)
        int switchState = atoi(message.data);
        if (switchState == 0)
          DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
        else
          if (i == 0)
            valveNumber = 1;
            DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
          else
            valveNumber = i;
            DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
            DEBUG_PRINTLN(i);
      else if (message.type == V_VAR1)
        int variable1 = atoi(message.data);// RUN_ALL_ZONES time
        DEBUG_PRINT(F("Recieved variable1 valve:"));
        DEBUG_PRINT(i);
        DEBUG_PRINT(F(" = "));
        DEBUG_PRINTLN(variable1);
        if (variable1 != allZoneTime[i])
          allZoneTime[i] = variable1;
          zoneTimeUpdate = true;
      else if (message.type == V_VAR2)
        int variable2 = atoi(message.data);// RUN_SINGLE_ZONE time
        DEBUG_PRINT(F("Recieved variable2 valve:"));
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(variable2);
        if (variable2 != valveSoloTime[i])
          valveSoloTime[i] = variable2;
      else if (message.type == V_VAR3)
        String newMessage = String(message.data);
        if (newMessage.length() == 0)
          DEBUG_PRINT(F("No Name Recieved for zone "));
          DEBUG_PRINTLN(i);
          break;
        if (newMessage.length() &gt; 16)
          newMessage.substring(0, 16);
        valveNickName[i] = "";
        valveNickName[i] += newMessage;
        DEBUG_PRINT(F("Recieved new name for zone "));
        DEBUG_PRINT(i);
        DEBUG_PRINT(F(" and it is now called: "));
        DEBUG_PRINTLN(valveNickName[i]);
  if (zoneTimeUpdate)
    DEBUG_PRINTLN(F("New Zone Times Recieved..."));
      if (i != 0)
        DEBUG_PRINT(F("Zone "));
        DEBUG_PRINT(i);
        DEBUG_PRINT(F(" individual time: "));
        DEBUG_PRINT(valveSoloTime[i]);
        DEBUG_PRINT(F(" group time: "));
        DEBUG_PRINTLN(allZoneTime[i]);
  else
    recentUpdate = false;
void updateDisplay()
  static unsigned long lastUpdateTime;
  static boolean displayToggle = false;
  //static byte toggleCounter = 0;
  static SprinklerStates lastDisplayState;
  if (state != lastDisplayState || millis() - lastUpdateTime &gt;= 3000UL)
    displayToggle = !displayToggle;
    switch (state) {
      case STAND_BY_ALL_OFF:
        fastClear();
        if (displayToggle)
          lcd.print(F("  System Ready "));
          if (clockUpdating)
            lcd.write(byte(0));
          lcd.print(hourFormat12() &lt; 10 ? F(" ") : F(""));
          lcd.print(hourFormat12());
          lcd.print(minute() &lt; 10 ? F(":0") : F(":"));
          lcd.print(minute());
          lcd.print(isAM() ? F("am") : F("pm"));
          lcd.print(month() &lt; 10 ? F(" 0") : F(" "));
          lcd.print(month());
          lcd.print(day() &lt; 10 ? F("/0") : F("/"));
          lcd.print(day());
          lcd.print(F("/"));
          lcd.print(year() % 100);
        else
          lcd.print(F("  Last Watered "));
          if (clockUpdating)
            lcd.write(byte(0));
          lcd.print(dayOfWeek[weekday(lastTimeRun)]);
          lcd.setCursor(11, 1);
          lcd.print(month(lastTimeRun) &lt; 10 ? F(" ") : F(""));
          lcd.print(month(lastTimeRun));
          lcd.print(day(lastTimeRun) &lt; 10 ? F("/0") : F("/"));
          lcd.print(day(lastTimeRun));
        break;
      case RUN_SINGLE_ZONE:
        fastClear();
        if (displayToggle)
          lcd.print(F("Single Zone Mode"));
          lcd.print(F(" Zone:"));
          if (valveNumber &lt; 10) lcd.print(F("0"));
          lcd.print(valveNumber);
          lcd.print(F(" Active"));
        else
          lcd.print(F(" Time Remaining "));
          if (valveSoloTime[valveNumber] == 0)
            lcd.print(F(" No Valve Time "));
          else
            unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
            lcd.print(timeRemaining / 60 &lt; 10 ? "   0" : "   ");
            lcd.print(timeRemaining / 60);
            lcd.print("min");
            lcd.print(timeRemaining % 60 &lt; 10 ? " 0" : " ");
            lcd.print(timeRemaining % 60);
            lcd.print("sec  ");
        break;
      case RUN_ALL_ZONES:
        fastClear();
        if (displayToggle)
          lcd.print(F(" All-Zone  Mode "));
          lcd.print(F(" Active "));
        else
          int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
          lcd.print((timeRemaining / 60) &lt; 10 ? "   0" : "   ");
          lcd.print("min");
          lcd.print("sec  ");
        break;
      case CYCLE_COMPLETE:
        if (displayToggle)
          lcd.print(F(" Watering Cycle "));
          lcd.print(F("    Complete    "));
        else
          int totalTimeRan = 0;
          for (int i = 1; i &lt; NUMBER_OF_VALVES + 1; i++)
            totalTimeRan += allZoneTime[i];
          lcd.print(F(" Total Time Run "));
          lcd.print(totalTimeRan &lt; 10 ? "   0" : "   ");
          lcd.print(totalTimeRan);
          lcd.print(" Minutes   ");
    lastUpdateTime = millis();
  lastDisplayState = state;
void receiveTime(time_t newTime)
  DEBUG_PRINTLN(F("Time value received and updated..."));
  int lastSecond = second();
  int lastMinute = minute();
  int lastHour = hour();
  setTime(newTime);
  if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
    DEBUG_PRINTLN(F("Clock updated...."));
    DEBUG_PRINT(F("Sensor's time currently set to:"));
    DEBUG_PRINT(hourFormat12() &lt; 10 ? F(" 0") : F(" "));
    DEBUG_PRINT(hourFormat12());
    DEBUG_PRINT(minute() &lt; 10 ? F(":0") : F(":"));
    DEBUG_PRINT(minute());
    DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
    DEBUG_PRINT(month());
    DEBUG_PRINT(F("/"));
    DEBUG_PRINT(day());
    DEBUG_PRINTLN(year());
    DEBUG_PRINTLN(dayOfWeek[weekday()]);
    showTime = false;
  else
    DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
void fastClear()
  lcd.print(F("                "));
  lcd.print(F("                "));
void updateClock()
  static unsigned long lastVeraGetTime;
  if (millis() - lastVeraGetTime &gt;= 3600000UL) // updates clock time and gets zone times from vera once every hour
    DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
    lcd.write(byte(0));
    clockUpdating = true;
    lastVeraGetTime = millis();
void saveDateToEEPROM(unsigned long theDate)
  DEBUG_PRINTLN(F("Saving Last Run date"));
  if (gw.loadState(0) != 0xFF)
    gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
  for (int i = 1; i &lt; 5; i++)
    gw.saveState(5 - i, byte(theDate &gt;&gt; 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
void goGetValveTimes()
  static unsigned long valveUpdateTime;
  static byte valveIndex = 1;
  if (millis() - valveUpdateTime &gt;= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
    DEBUG_PRINTLN(F("Calling for Valve Data..."));
    lcd.write(byte(1)); //lcd.write(1);
    gw.request(valveIndex, V_VAR1);
    gw.request(valveIndex, V_VAR2);
    gw.request(valveIndex, V_VAR3);
    valveUpdateTime = millis();
    valveIndex++;
    if (valveIndex &gt; NUMBER_OF_VALVES + 1)
      valveIndex = 1;
</code></pre>
<p dir="auto">Cheers<br />
Wallis</p>
]]></description><link>https://forum.mysensors.org/post/27809</link><guid isPermaLink="true">https://forum.mysensors.org/post/27809</guid><dc:creator><![CDATA[ciscokid]]></dc:creator><pubDate>Wed, 06 Jan 2016 18:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to Irrigation Controller - Relays not working?? on Wed, 06 Jan 2016 18:38:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi<br />
I am using the same code from the tutorial<br />
see below</p>
<pre><code>/*
May 31, 2015
*** Version 2.0
PARTS LIST:
* NRF24L01 Radio
* LED
* Push button
INSTRUCTIONS:
#ifdef ACTIVE_LOW
#else
#ifdef DEBUG_ON
#else
typedef enum {
SprinklerStates;
byte menuState = 0;
int valveNumber;
int lastValve;
  "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
  //delay(5000);
  lcd.clear();
  lcd.backlight();
  delay(500);
  lcd.write(byte(0));
    gw.process();
    delay(1000);
    lcd.print(".");
    clockCounter++;
      lcd.clear();
      delay(2000);
      break;
  lcd.clear();
    lcd.print(i);
    DEBUG_PRINT(i);
      delay(100);
      delay(100);
      delay(100);
  lcd.clear();
  gw.process();
  updateClock();
  updateDisplay();
  //goGetValveTimes();
  if (buttonPushed)
      menuState = 0;
      menuState++;
        menuState = 0;
    else
    slowToggleLED ();
        delay(50);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      delay(2000);
      lastValve = -1;
        else
    fastToggleLed();
      valveNumber = 1;
    else
      valveNumber++;
        lastValve = -1;
    fastToggleLed();
        else
    else
      fastToggleLed();
    else
    displayMenu();
  lastState = state;
    lcd.clear();
    lcd.print(F("."));
    Serial.print(".");
    if (menuState == 0)
      valveNumber = 1;
    else
  else
        else
          if (i == 0)
            valveNumber = 1;
          else
            valveNumber = i;
            DEBUG_PRINTLN(i);
        DEBUG_PRINT(i);
        DEBUG_PRINT(i);
          DEBUG_PRINTLN(i);
          break;
        DEBUG_PRINT(i);
  if (zoneTimeUpdate)
      if (i != 0)
        DEBUG_PRINT(i);
  else
    switch (state) {
        fastClear();
        if (displayToggle)
          if (clockUpdating)
            lcd.write(byte(0));
          lcd.print(month());
          lcd.print(day());
          lcd.print(F("/"));
        else
          if (clockUpdating)
            lcd.write(byte(0));
        break;
        fastClear();
        if (displayToggle)
        else
          else
            lcd.print("min");
            lcd.print("sec  ");
        break;
      case RUN_ALL_ZONES:
        fastClear();
        if (displayToggle)
        else
          lcd.print("min");
          lcd.print("sec  ");
        break;
        if (displayToggle)
        else
  setTime(newTime);
    DEBUG_PRINT(day());
    showTime = false;
  else
void fastClear()
  lcd.print(F("                "));
  lcd.print(F("                "));
void updateClock()
    lcd.write(byte(0));
    valveIndex++;
      valveIndex = 1;
</code></pre>
<p dir="auto">I have been through Bulldogs posts and the workarounds for Domoticz with regard to VAR_1 2 and 3 which works but the Relays LED's dont switch on<br />
<a href="http://forum.mysensors.org/topic/153/irrigation-controller-up-to-16-valves-with-shift-registers/91" rel="nofollow ugc">http://forum.mysensors.org/topic/153/irrigation-controller-up-to-16-valves-with-shift-registers/91</a><br />
Cheers<br />
Wallis</p>
]]></description><link>https://forum.mysensors.org/post/27808</link><guid isPermaLink="true">https://forum.mysensors.org/post/27808</guid><dc:creator><![CDATA[ciscokid]]></dc:creator><pubDate>Wed, 06 Jan 2016 18:38:20 GMT</pubDate></item><item><title><![CDATA[Reply to Irrigation Controller - Relays not working?? on Wed, 06 Jan 2016 16:57:59 GMT]]></title><description><![CDATA[<p dir="auto">Post your exact code, that could help us looking at the problem.</p>
]]></description><link>https://forum.mysensors.org/post/27805</link><guid isPermaLink="true">https://forum.mysensors.org/post/27805</guid><dc:creator><![CDATA[ericvdb]]></dc:creator><pubDate>Wed, 06 Jan 2016 16:57:59 GMT</pubDate></item></channel></rss>
