<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[issue with V_TEXT sensor type]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I'm playing with LCD screen. I want to display in my LCD a string from my mqtt broker.<br />
Ex:<br />
OpenHAB --&gt; MQTT Broker --&gt; MQTT Gateway --&gt; LCD (directly connected on gateway)</p>
<p dir="auto">I can send a message Ex: "TEST_LCD_1_MIKA_COOL":<br />
Result:</p>
<pre><code>0;0;3;0;9;Message arrived on topic: mygateway1-in/0/3/1/V_TEXT/47
Incoming msg DATA: TEST_LCD_1_MIKA_COOL
</code></pre>
<p dir="auto">but when I send a shorter message Ex: "TEST_LCD_2_SUPER"</p>
Incoming msg DATA: TEST_LCD_2_SUPERCOOL
</code></pre>
<p dir="auto">We can see that message.getString is false. It adds the end of the last string on this new string.</p>
<p dir="auto">buffer not empty ?</p>
<p dir="auto">My conf:</p>
<pre><code>void receive(const MyMessage &amp;message) {
  if (message.type==V_TEXT &amp;&amp; message.sensor == LCD_CHILD) {
    lcd.clear();
    Serial.print("Incoming msg DATA: ");
    lcd.print("Incoming msg DATA: ");
    lcd.setCursor ( 0, 1 );
    Serial.println(message.getString());
    lcd.print(message.getString());
</code></pre>
<p dir="auto">can you help me please ?</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.mysensors.org/topic/2771/issue-with-v_text-sensor-type</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 05:09:12 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2771.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Jan 2016 15:57:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to issue with V_TEXT sensor type on Sun, 10 Jan 2016 16:13:10 GMT]]></title><description><![CDATA[<p dir="auto">I'm sorry for that ;)<br />
It works perfectly after the library update</p>
<p dir="auto">thank you very much <a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a></p>
]]></description><link>https://forum.mysensors.org/post/28205</link><guid isPermaLink="true">https://forum.mysensors.org/post/28205</guid><dc:creator><![CDATA[mickaelh51]]></dc:creator><pubDate>Sun, 10 Jan 2016 16:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to issue with V_TEXT sensor type on Sun, 10 Jan 2016 16:06:31 GMT]]></title><description><![CDATA[<p dir="auto">I think it should work: <a href="https://github.com/mysensors/Arduino/issues/322" rel="nofollow ugc">https://github.com/mysensors/Arduino/issues/322</a><br />
Lets hope so, good luck.</p>
]]></description><link>https://forum.mysensors.org/post/28203</link><guid isPermaLink="true">https://forum.mysensors.org/post/28203</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Sun, 10 Jan 2016 16:06:31 GMT</pubDate></item><item><title><![CDATA[Reply to issue with V_TEXT sensor type on Sun, 10 Jan 2016 16:02:23 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a><br />
I'm going to update my library now !</p>
<p dir="auto">I will tell you if it works</p>
]]></description><link>https://forum.mysensors.org/post/28201</link><guid isPermaLink="true">https://forum.mysensors.org/post/28201</guid><dc:creator><![CDATA[mickaelh51]]></dc:creator><pubDate>Sun, 10 Jan 2016 16:02:23 GMT</pubDate></item><item><title><![CDATA[Reply to issue with V_TEXT sensor type on Sun, 10 Jan 2016 16:00:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mickaelh51" aria-label="Profile: mickaelh51">@<bdi>mickaelh51</bdi></a><br />
See my post here: <a href="http://forum.mysensors.org/topic/2617/receivetime-and-request-in-1-6" rel="nofollow ugc">http://forum.mysensors.org/topic/2617/receivetime-and-request-in-1-6</a> I think it might be same.<br />
I have seen some activity on github lately (about this I think), have you downloaded the latest lib? It might be working now... dont know 100% though.</p>
]]></description><link>https://forum.mysensors.org/post/28198</link><guid isPermaLink="true">https://forum.mysensors.org/post/28198</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Sun, 10 Jan 2016 16:00:42 GMT</pubDate></item></channel></rss>
