<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problem with manual node_id]]></title><description><![CDATA[<p dir="auto">i wanted  to assign manual node id to every sensor in order to have a list that will track nodes location and task along my project.<br />
so for my repeater i changed to:<br />
gw.begin(NULL, 1, true)<br />
1 is for example of course.<br />
and for a binary-senosr sketch i changed<br />
gw.begin()<br />
to<br />
gw.begin(NULL, 3);</p>
<p dir="auto">now, the repeater node works fine, even with a great distance from the controller - through 1 or 2 repeaters on the way.<br />
but the binars-switch connects only when it is close to the controller but not through repeaters. another strange thing is that the nrf (+pa +lna +sma antennna) gets warm after some time.</p>
<p dir="auto">is there someting wrong with the code? thats the only thing ive changed.</p>
<p dir="auto">setup: rpi2 with domoticz and serial gateway.<br />
boards - sparkfun redboard</p>
]]></description><link>https://forum.mysensors.org/topic/2867/problem-with-manual-node_id</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 07:00:07 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2867.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Jan 2016 09:40:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to problem with manual node_id on Sun, 24 Jan 2016 14:23:02 GMT]]></title><description><![CDATA[<p dir="auto">ok i think its solved. well sort of...<br />
i tried clearing the eeprom of the board and uploading again ( with (NULL , 3) modification) but still i didnt get any siganl on domoticz and again the radio started getting hot.<br />
so switched to another board (chinese NANO) with original sketch with gw.begin() and it worked.<br />
i dont know if its the board replacment or the sketch replacement that did the trick but for now its working.</p>
]]></description><link>https://forum.mysensors.org/post/29497</link><guid isPermaLink="true">https://forum.mysensors.org/post/29497</guid><dc:creator><![CDATA[abrasha]]></dc:creator><pubDate>Sun, 24 Jan 2016 14:23:02 GMT</pubDate></item></channel></rss>
