<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] MQTT ESP8266 Gateway 1.6]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2285/mqtt-broker-support-in-mysensors-1-6">MQTT Broker support in MySensors 1.6</a></p>
<p dir="auto">I running ver 1.6 from 19 Jan 2016 version with a RFM69 radio, all work well for a few hours, then it appears that the gateway stops communication with the broker, looks like the MQTT task and the WiFi task are no longer communication.</p>
<p dir="auto">I can still PING the gateway, so the WiFi stack is running......</p>
<p dir="auto">From debug port...</p>
<p dir="auto">0;255;3;0;9;Attempting MQTT connection...<br />
0;255;3;0;9;read: 1-1-0 s=1,c=2,t=24,pt=0,l=0,sg=0:<br />
0;255;3;0;9;Attempting MQTT connection...</p>
<p dir="auto">Also, I noted that the WiFi stack is still acting as an access point. Is there a way to turn off just the access point??</p>
<p dir="auto">Thanks<br />
0;255;3;0;9;read: 1-1-0 s=1,c=2,t=24,pt=0,l=0,sg=0:</p>
]]></description><link>https://forum.mysensors.org/topic/2868/solved-mqtt-esp8266-gateway-1-6</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 10:38:58 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2868.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Jan 2016 15:38:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] MQTT ESP8266 Gateway 1.6 on Sat, 23 Jan 2016 08:01:27 GMT]]></title><description><![CDATA[<p dir="auto">Great that you found a solution, thanks for reporting back!</p>
]]></description><link>https://forum.mysensors.org/post/29334</link><guid isPermaLink="true">https://forum.mysensors.org/post/29334</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sat, 23 Jan 2016 08:01:27 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] MQTT ESP8266 Gateway 1.6 on Sat, 23 Jan 2016 03:01:57 GMT]]></title><description><![CDATA[<p dir="auto">This has been fixed.... It was an error on my part, I had a unlisted device with the same IP address as the GW... it was a pain to find this as GW would work for 3 to 4 hours.</p>
<p dir="auto">I have tested removing access point and GW re covers<br />
I remove MWTT broker and GW recovers</p>
]]></description><link>https://forum.mysensors.org/post/29320</link><guid isPermaLink="true">https://forum.mysensors.org/post/29320</guid><dc:creator><![CDATA[lafleur]]></dc:creator><pubDate>Sat, 23 Jan 2016 03:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] MQTT ESP8266 Gateway 1.6 on Thu, 21 Jan 2016 15:45:36 GMT]]></title><description><![CDATA[<p dir="auto">I've done some more testing, It stop working in 3 to 4 hours, very consistent over the last 24 hrs. I have changes ESP8266, same issue, ESP code is ver 2.0..</p>
<p dir="auto">It also appears that the code may not be trying to close, open the WiFi connection when there is a network error...</p>
<p dir="auto">Anyone have any ideas??</p>
]]></description><link>https://forum.mysensors.org/post/29174</link><guid isPermaLink="true">https://forum.mysensors.org/post/29174</guid><dc:creator><![CDATA[lafleur]]></dc:creator><pubDate>Thu, 21 Jan 2016 15:45:36 GMT</pubDate></item></channel></rss>
