<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Why does MySensors setup both a Node device and Temperature device in Vera?]]></title><description><![CDATA[<p dir="auto">As I am beginning my journey with MySensors, I wondered if anyone could explain to me what the design decision was around having two separate devices created in Vera for each sensor?  In my case adding a temperature sensor created two devices, a 'Node' device and a 'Temperature' device.  I'm just curious to understand why these needed to be created as two separate devices instead of one combined device?</p>
<p dir="auto">Thanks,<br />
Troy.</p>
]]></description><link>https://forum.mysensors.org/topic/335/why-does-mysensors-setup-both-a-node-device-and-temperature-device-in-vera</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 07:32:48 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/335.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Sep 2014 17:21:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Why does MySensors setup both a Node device and Temperature device in Vera? on Mon, 01 Sep 2014 17:29:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troyf" aria-label="Profile: TroyF">@<bdi>TroyF</bdi></a></p>
<p dir="auto">The node device contains the information related to the Arduino-node  such as battery level, library version and in the case of relaying nodes a clear button for relay information. On vera you cannot modify or add information to the standard devices.</p>
]]></description><link>https://forum.mysensors.org/post/3949</link><guid isPermaLink="true">https://forum.mysensors.org/post/3949</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Mon, 01 Sep 2014 17:29:18 GMT</pubDate></item></channel></rss>
