<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change the device view of Multimeter?]]></title><description><![CDATA[<p dir="auto">Hello from Spain! , I just created my first project , inspired by some post here .<br />
It is a small module that runs on a battery and a solar panel , use a multimeter device that brings me the voltage (through resistors) to the vera.<br />
My problem is that the multimeter does not show me the voltage on the main screen , only impedance , is there any way to change the view ?</p>
<p dir="auto">Greetings and thanks</p>
]]></description><link>https://forum.mysensors.org/topic/3389/change-the-device-view-of-multimeter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 12:58:57 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3389.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Mar 2016 19:34:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change the device view of Multimeter? on Mon, 12 Jun 2017 02:29:11 GMT]]></title><description><![CDATA[<p dir="auto">I have just found and fixed this problem. I know it is very old but in the D_Multimeter1.json file there are 6 references to :arduino-cc: in the service fields - this all need to be replaced with :micasaverde-com:</p>
<p dir="auto">I have just loaded a pull request to the GITHUB repo to have this reflected in the master source but you can edit this and reload the LUUP file in Vera which will fix the problem.</p>
]]></description><link>https://forum.mysensors.org/post/69042</link><guid isPermaLink="true">https://forum.mysensors.org/post/69042</guid><dc:creator><![CDATA[itbeyond]]></dc:creator><pubDate>Mon, 12 Jun 2017 02:29:11 GMT</pubDate></item></channel></rss>
