<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ethernet Gateway 1.4 with Vera UI7]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am hiving some trouble getting the Ethernet 1.4 gateway going with Vera UI7. It seems to compile and install OK, but it doesn't function. Often pressing the "Start for inclusion button" on the Vera doesn't send any data (but sometimes it does), and after a short time following a reboot of the Vera, it sends the gateway all sorts of rubbish.</p>
<p dir="auto">I can telnet to the gateway port and what I type in shows in the serial debug nicely, and I can manually put the gateway into inclusion mode and I see the sensor data OK. Following is the serial debug (without the network traffic, and including a few extra debug statements)</p>
<pre><code>Hello
Gateway Started
Hello, Ethernet Started
Server Started
0;0;3;0;9;Inclusion started by button.
0;0;3;0;5;1
0;0;3;0;5;1
0;255;0;0;17;1.4
0;0;0;0;7;1.4
0;1;0;0;6;1.4
0;0;3;0;5;0
eth0-Hello - This is some text from telnet
</code></pre>
<p dir="auto">It seems to start off ok, asking for the version, but then goes wrong. Following is a trace of the network traffic coming from the vera and going to the gateway:</p>
<pre><code>0;0;3;0;2;Get Version
.......1.0..@.........0..E.......1.0..@.........0..E...FFooma...^......1....2.........2.........1.0..@.........00..E...Fooma...^......1....22........2.........1.0..@..........0..E...Fooma...^......0..@.........0..E...Fooma....^......1....2........2..........1.0..@.........0..E....Fooma...^......1....2.........2.........1.0..@..........0..E...Fooma...^......1.....2........2.........1.0..@..........0..E...Fooma...^.......1....2........2.........11.0..@.........0..E...Fooma....^......1....2........2..........1.0..@.........0..E....Fooma...^......1....2.........2.........1.0..@..........0..E...Fooma...^......1.....2........2.........1.0..@..........0..E...Fooma...^.......1....2........2..........1.0..@.........0..E...Foomaa...^......1....2........2..........1.0..@.........0..E....Fooma...^......1....2.........2.........1.0..@..........0..E...Fooma...^......1.....2........2.........1.0..@@.........0..E...Fooma...^.......1....2........2..........1.0..@.........0..E...Foomma...^......1....2........2..........1.0..@.........0..EE...Fooma...^......1....2.........2.........1.0..@..........0..E...Fooma...^......1.....2........2.........1.0...@.........0..E...Fooma...^.......1....2........2..........1.0..@.........0..E...Foooma...^......1....2........22.........1.0..@.........0...E...Fooma...^......1....2.........2.........1.0..@..........0
================================= CUT CUT CUT =========================
...~....dM-SEEARCH * HTTP/1.1
..@.@..C..........0..@j...E..1..@.@......
f..
...~.....M-SEARCH *  HTTP/1.1
...3.t.@............Bp....E..(!.@.?..a..........6..........P...r
.........=.....@...........Bp....E...(!.@.?..`.........6..........!P...q.........N%p^..@............Bp....E..(!.@.?.._..........6.........=P...q.............fF.@...........Bp.....E..(!.@.?..^.........6.....803006 3 ipp://192.168.10..102:631/printers/Brother_HLL-2140_series "Office" "Brotther HL-2140 series" "Brotheer HL-1240 Foomatic/hl1250 ((recommended)" job-sheets=noone,none lease-duration=300
'..4.@...........Bp....E...(!.@.?..H.........6...........P...oN.........7AKz.@............Bp....E..(!/@.?..G..........6..........P...o2..........mZ}..@...........Bp.....E..(!0@.?..F.........6...
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/346/ethernet-gateway-1-4-with-vera-ui7</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 02:02:58 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/346.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Sep 2014 04:32:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ethernet Gateway 1.4 with Vera UI7 on Mon, 22 Sep 2014 07:50:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I changed over to using a wiznet5100 based board (iboard) and it seems to have fixed the problem.</p>
]]></description><link>https://forum.mysensors.org/post/4858</link><guid isPermaLink="true">https://forum.mysensors.org/post/4858</guid><dc:creator><![CDATA[jtm312]]></dc:creator><pubDate>Mon, 22 Sep 2014 07:50:16 GMT</pubDate></item><item><title><![CDATA[Reply to Ethernet Gateway 1.4 with Vera UI7 on Sun, 21 Sep 2014 08:23:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jtm312" aria-label="Profile: jtm312">@<bdi>jtm312</bdi></a><br />
I suggest you do as I am and go back to UI5.</p>
]]></description><link>https://forum.mysensors.org/post/4841</link><guid isPermaLink="true">https://forum.mysensors.org/post/4841</guid><dc:creator><![CDATA[Homer]]></dc:creator><pubDate>Sun, 21 Sep 2014 08:23:04 GMT</pubDate></item></channel></rss>
