<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What is the minimum distance between main voltages (PCB)]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am trying to design my own power supply and I am a bit worry about the minimum distance between hot and neutral lines ? I read in this <a href="http://www.avrfreaks.net/comment/558568#comment-558568" rel="nofollow ugc">link</a> that according to EN61010, it shall be 3mm.</p>
<p dir="auto">Lots of people here do design there boards and I guess they have faced this issue before.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.mysensors.org/topic/3515/what-is-the-minimum-distance-between-main-voltages-pcb</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 06:05:01 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3515.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Mar 2016 20:25:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What is the minimum distance between main voltages (PCB) on Mon, 28 Mar 2016 07:04:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahmedadelhosni" aria-label="Profile: ahmedadelhosni">@<bdi>ahmedadelhosni</bdi></a> Yes - sorry, didnt read carefull enough.</p>
]]></description><link>https://forum.mysensors.org/post/35420</link><guid isPermaLink="true">https://forum.mysensors.org/post/35420</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Mon, 28 Mar 2016 07:04:09 GMT</pubDate></item><item><title><![CDATA[Reply to What is the minimum distance between main voltages (PCB) on Sun, 27 Mar 2016 23:51:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a> creepege differs from clearance. I guess if I add creepege then clearance can be decreased.</p>
<p dir="auto">I just cant find online which values are the minimum. Most of the search results requests to buy the certificates.</p>
]]></description><link>https://forum.mysensors.org/post/35416</link><guid isPermaLink="true">https://forum.mysensors.org/post/35416</guid><dc:creator><![CDATA[ahmedadelhosni]]></dc:creator><pubDate>Sun, 27 Mar 2016 23:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to What is the minimum distance between main voltages (PCB) on Sun, 27 Mar 2016 21:49:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahmedadelhosni" aria-label="Profile: ahmedadelhosni">@<bdi>ahmedadelhosni</bdi></a></p>
<p dir="auto">In my DRU I use 100 mil clearance for AC lines (and 100 mil width).</p>
]]></description><link>https://forum.mysensors.org/post/35412</link><guid isPermaLink="true">https://forum.mysensors.org/post/35412</guid><dc:creator><![CDATA[GertSanders]]></dc:creator><pubDate>Sun, 27 Mar 2016 21:49:30 GMT</pubDate></item><item><title><![CDATA[Reply to What is the minimum distance between main voltages (PCB) on Sun, 27 Mar 2016 21:20:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">It depends... <a href="http://creepage.com/" rel="nofollow ugc">http://creepage.com/</a></p>
<p dir="auto">Example:<br />
Insulation: Basic<br />
Pollution Degree:	2<br />
Material Group:	IIIa or IIIb<br />
Working Voltage:	250 Vrms or Vdc</p>
<p dir="auto">Creepage is 2.5 mm or 98.4 mils</p>
<p dir="auto">I try 3mm on my boards.</p>
]]></description><link>https://forum.mysensors.org/post/35409</link><guid isPermaLink="true">https://forum.mysensors.org/post/35409</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Sun, 27 Mar 2016 21:20:02 GMT</pubDate></item></channel></rss>
