<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pimatic doesnt receive any signal]]></title><description><![CDATA[<p dir="auto">Hi,<br />
1-I installed Pimatic.<br />
2-I installed Serial Gateway on the Arduino Nano.<br />
3-I installed the Light sketch from MySensors on the Nano.</p>
<h2>Pimatic logs look like below. It seems it doesnt receive any signal.<br />
I think there is someting wrong with the USB port...<br />
Are my USB port settings correct?<br />
{<br />
"plugin": "mysensors",<br />
"driver": "serialport",<br />
"protocols": "1.5.1",<br />
"startingNodeId": 1,<br />
"driverOptions": {<br />
"//": "'/dev/ttyACM1' if using serial Gateway",<br />
"serialDevice": "/dev/ttyMySensorsGateway",<br />
"baudrate": 115200<br />
}<br />
}</h2>
<h2>PIMATIC LOG</h2>
<p dir="auto">2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...<br />
19:23:46info [pimatic-mobile-frontend]: rendering html finished<br />
19:23:20info [pimatic-mobile-frontend]: rendering html<br />
19:23:20info [pimatic-mobile-frontend]: packing static assets finished<br />
19:23:18info [pimatic-mobile-frontend]: packing static assets<br />
19:23:18info [pimatic]: New device "Light"...<br />
19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)<br />
19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)<br />
19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)<br />
19:22:59</p>
]]></description><link>https://forum.mysensors.org/topic/3571/pimatic-doesnt-receive-any-signal</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 08:42:15 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3571.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Apr 2016 16:38:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pimatic doesnt receive any signal on Wed, 06 Apr 2016 17:04:41 GMT]]></title><description><![CDATA[<p dir="auto">This can probably marked as solved in <a href="http://forum.mysensors.org/topic/797/pimatic-mysensors-controller-plugin/85" rel="nofollow ugc">http://forum.mysensors.org/topic/797/pimatic-mysensors-controller-plugin/85</a> ?</p>
]]></description><link>https://forum.mysensors.org/post/36133</link><guid isPermaLink="true">https://forum.mysensors.org/post/36133</guid><dc:creator><![CDATA[Oitzu]]></dc:creator><pubDate>Wed, 06 Apr 2016 17:04:41 GMT</pubDate></item><item><title><![CDATA[Reply to Pimatic doesnt receive any signal on Wed, 06 Apr 2016 16:42:45 GMT]]></title><description><![CDATA[<p dir="auto">First check where your usb device is.</p>
<p dir="auto">Open the terminal and type:</p>
<pre><code>ls -l /dev/ttyU*
</code></pre>
<p dir="auto">You should see something like:</p>
<pre><code>crw-rw---- 1 root dialout 188, 0 Apr  6 18:36 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Apr  6 07:00 /dev/ttyUSB1
</code></pre>
<p dir="auto">In my case it is <code>/dev/ttyUSB1</code> (other one is my homeduino).</p>
<p dir="auto">add this to the plugins:</p>
<pre><code>{
      "driverOptions": {
        "serialDevice": "/dev/ttyUSB1",
        "baudrate": 115200
</code></pre>
<p dir="auto">Then start pimatic and see if you can find the connected message:</p>
<pre><code>Connected to MySensors Gateway
</code></pre>
]]></description><link>https://forum.mysensors.org/post/36132</link><guid isPermaLink="true">https://forum.mysensors.org/post/36132</guid><dc:creator><![CDATA[Sweebee]]></dc:creator><pubDate>Wed, 06 Apr 2016 16:42:45 GMT</pubDate></item></channel></rss>
