<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New nRF24 driver in MySensors 2.0.0]]></title><description><![CDATA[<p dir="auto">MySensors 2.0.0 will feature a refactored nRF24 driver having:</p>
<ul>
<li>reduced code size (-2kb)</li>
<li>two-fold speed increase (processing)</li>
<li>fewer register writing/polling</li>
<li>fully defined init state</li>
<li>SPI transactions</li>
</ul>
<p dir="auto">Please feel free to test <a href="https://github.com/mysensors/Arduino/tree/development" rel="nofollow ugc">MySensors 2.0.0-beta</a> and provide feedback if you encounter any issues.</p>
]]></description><link>https://forum.mysensors.org/topic/3758/new-nrf24-driver-in-mysensors-2-0-0</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 07:25:25 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3758.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Apr 2016 18:39:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Tue, 03 May 2016 04:41:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gertsanders" aria-label="Profile: GertSanders">@<bdi>GertSanders</bdi></a></p>
<p dir="auto">No, you have to update manually...</p>
]]></description><link>https://forum.mysensors.org/post/38340</link><guid isPermaLink="true">https://forum.mysensors.org/post/38340</guid><dc:creator><![CDATA[tbowmo]]></dc:creator><pubDate>Tue, 03 May 2016 04:41:34 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Tue, 03 May 2016 00:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a> wow</p>
]]></description><link>https://forum.mysensors.org/post/38335</link><guid isPermaLink="true">https://forum.mysensors.org/post/38335</guid><dc:creator><![CDATA[Michel - It]]></dc:creator><pubDate>Tue, 03 May 2016 00:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Mon, 02 May 2016 23:42:13 GMT]]></title><description><![CDATA[<p dir="auto">Does the DEV library update automatically in the Arduino library manager ?</p>
]]></description><link>https://forum.mysensors.org/post/38334</link><guid isPermaLink="true">https://forum.mysensors.org/post/38334</guid><dc:creator><![CDATA[GertSanders]]></dc:creator><pubDate>Mon, 02 May 2016 23:42:13 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Mon, 02 May 2016 21:53:30 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it should be compatible. But if you're using UI7 you should probably update the plugin to the UI7 branch on github though.</p>
]]></description><link>https://forum.mysensors.org/post/38328</link><guid isPermaLink="true">https://forum.mysensors.org/post/38328</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Mon, 02 May 2016 21:53:30 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Mon, 02 May 2016 21:16:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a><br />
Correct, I already flashed Ethernet Gateway (W5100) and a test node (Relay Actuator) with new beta version of the library.<br />
In Vera I removed Ethernet Gateway and added it again, so it shows in properties:<br />
<strong>Plugin Version:1.5<br />
Lib Version: Unit: {empty}</strong><br />
Inlcusion mode doesn't search for new nodes, so this is why I asked - is the old Vera plugin developed for library 1.5 compartible with library 2.0 ?</p>
]]></description><link>https://forum.mysensors.org/post/38326</link><guid isPermaLink="true">https://forum.mysensors.org/post/38326</guid><dc:creator><![CDATA[Alexander Ivanov]]></dc:creator><pubDate>Mon, 02 May 2016 21:16:11 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Mon, 02 May 2016 17:05:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexander-ivanov" aria-label="Profile: Alexander-Ivanov">@<bdi>Alexander-Ivanov</bdi></a><br />
You have to download and install this version of the library:<br />
<a href="https://github.com/mysensors/Arduino" rel="nofollow ugc">https://github.com/mysensors/Arduino</a></p>
]]></description><link>https://forum.mysensors.org/post/38299</link><guid isPermaLink="true">https://forum.mysensors.org/post/38299</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Mon, 02 May 2016 17:05:29 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Mon, 02 May 2016 14:42:41 GMT]]></title><description><![CDATA[<p dir="auto">Can I test it with current version of Vera plugin, which shows<br />
Lib Version: Unit: 1.5.1<br />
is it compartible ?</p>
]]></description><link>https://forum.mysensors.org/post/38291</link><guid isPermaLink="true">https://forum.mysensors.org/post/38291</guid><dc:creator><![CDATA[Alexander Ivanov]]></dc:creator><pubDate>Mon, 02 May 2016 14:42:41 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Wed, 27 Apr 2016 19:10:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a> first off: great work!</p>
<ul>
</ul>
<p dir="auto">great. :)</p>
<ul>
</ul>
<p dir="auto">Any number, test cases on that? In which situations does that apply?</p>
<ul>
</ul>
<p dir="auto">Also great. :)</p>
<p dir="auto">But as far as i see some features needed also to go away?</p>
]]></description><link>https://forum.mysensors.org/post/37941</link><guid isPermaLink="true">https://forum.mysensors.org/post/37941</guid><dc:creator><![CDATA[Oitzu]]></dc:creator><pubDate>Wed, 27 Apr 2016 19:10:11 GMT</pubDate></item><item><title><![CDATA[Reply to New nRF24 driver in MySensors 2.0.0 on Wed, 27 Apr 2016 19:01:03 GMT]]></title><description><![CDATA[<p dir="auto">Awesome! Great work <a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a> !</p>
]]></description><link>https://forum.mysensors.org/post/37940</link><guid isPermaLink="true">https://forum.mysensors.org/post/37940</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Wed, 27 Apr 2016 19:01:03 GMT</pubDate></item></channel></rss>
