<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Re-assign ID]]></title><description><![CDATA[<p dir="auto">Hi.<br />
I try find in this formum solution why not possible manualy reassign new id to my node.<br />
I use Ethernet Gateway with MYSController 0.1.2.282 .<br />
I can Assign new firmware from list .. work perfect .. but if try change - reassign new ID then still use same ..<br />
In sketch is  :</p>
<pre><code>gw.begin(incomingMessage, AUTO, true);
</code></pre>
<p dir="auto">this define auto .. then not problem to reassign .. I think ..<br />
If try it manualy also not working .. if try .. clear eeprom ...and must automatic reassign .. still use same ID ..</p>
<p dir="auto">regards.</p>
]]></description><link>https://forum.mysensors.org/topic/3759/re-assign-id</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 12:24:32 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3759.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Apr 2016 18:44:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Re-assign ID on Wed, 27 Apr 2016 18:58:12 GMT]]></title><description><![CDATA[<pre><code> [2016-04-27 20:55:10.973 Info] INFO	*** Logging START ***
 [2016-04-27 20:55:10.974 Info] VERSION	MYSController 0.1.2.282
 [2016-04-27 20:55:33.569 Info] NODE	New node discovered, node id=2
 [2016-04-27 20:55:33.570 Info] CHILD	New child discovered, node id=2, child id=internal
 [2016-04-27 20:55:33.570 Info] DEBUG	Assigned firmware=Blink to node=2
 [2016-04-27 20:55:33.571 Info] INFO	BL version=257
 [2016-04-27 20:55:33.572 Info] INFO	Send FW info to node 2: type=A, version=1, blocks=0x02C8, CRC=0xB718
 [2016-04-27 20:55:33.573 Info] TX	2;0;4;0;1;0A000100C80218B7
 [2016-04-27 20:55:33.574 Info] RX	2;255;4;0;0;0A000100C80218B70101
 [2016-04-27 20:55:33.655 Info] SIGNING	Node 2 does not require signing
 [2016-04-27 20:55:33.656 Info] SIGNING	MYSController is not signing
 [2016-04-27 20:55:33.656 Info] TX	2;255;3;0;15;0
 [2016-04-27 20:55:33.658 Info] RX	2;255;3;0;15;0
 [2016-04-27 20:55:33.658 Info] DEBUG	Update child id=255, type=ARDUINO_NODE
 [2016-04-27 20:55:33.659 Info] RX	2;255;0;0;17;1.5.4
 [2016-04-27 20:55:33.662 Info] TX	2;255;3;0;6;M
 [2016-04-27 20:55:33.663 Info] RX	2;255;3;0;6;0
 [2016-04-27 20:55:35.671 Info] RX	2;255;3;0;11;Bin.Sensor Sleep
 [2016-04-27 20:55:35.674 Info] RX	2;255;3;0;12;1.0
 [2016-04-27 20:55:35.676 Info] CHILD	New child discovered, node id=2, child id=3
 [2016-04-27 20:55:35.677 Info] DEBUG	Update child id=3, type=DOOR
 [2016-04-27 20:55:35.678 Info] RX	2;3;0;0;0;
 [2016-04-27 20:55:35.679 Info] CHILD	New child discovered, node id=2, child id=4
 [2016-04-27 20:55:35.679 Info] DEBUG	Update child id=4, type=DOOR
 [2016-04-27 20:55:35.681 Info] RX	2;4;0;0;0;
 [2016-04-27 20:55:35.722 Info] RX	2;3;1;0;16;1
 [2016-04-27 20:55:35.745 Info] RX	2;255;3;0;0;79
 [2016-04-27 20:55:40.876 Info] RX	2;4;1;0;16;0
 [2016-04-27 20:55:41.375 Info] RX	2;4;1;0;16;1
 [2016-04-27 20:55:42.819 Info] RX	2;3;1;0;16;0
 [2016-04-27 20:55:43.461 Info] RX	2;3;1;0;16;1
 [2016-04-27 20:55:54.189 Info] TX	2;0;3;0;13;0
 [2016-04-27 20:56:13.510 Info] REPO	FW "Blink" loaded. t=10, v=1, blocks=712, crc=0xB718
 [2016-04-27 20:56:13.523 Info] REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
 [2016-04-27 20:56:13.542 Info] REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
 [2016-04-27 20:56:13.552 Info] REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
 [2016-04-27 20:56:13.552 Info] REPO	FW repository loaded. Items=4
 [2016-04-27 20:56:17.551 Info] TX	2;0;3;0;13;0
 [2016-04-27 20:57:00.075 Info] CHILD	New child discovered, node id=2, child id=3
 [2016-04-27 20:57:00.076 Info] RX	2;3;1;0;16;0
 [2016-04-27 20:57:00.439 Info] RX	2;3;1;0;16;1
 [2016-04-27 20:57:02.092 Info] CHILD	New child discovered, node id=2, child id=4
 [2016-04-27 20:57:02.094 Info] RX	2;4;1;0;16;0
 [2016-04-27 20:57:02.363 Info] RX	2;4;1;0;16;1
</code></pre>
]]></description><link>https://forum.mysensors.org/post/37939</link><guid isPermaLink="true">https://forum.mysensors.org/post/37939</guid><dc:creator><![CDATA[dzairo]]></dc:creator><pubDate>Wed, 27 Apr 2016 18:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to Re-assign ID on Wed, 27 Apr 2016 18:52:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dzairo" aria-label="Profile: dzairo">@<bdi>dzairo</bdi></a> please provide logs with debug enabled.</p>
]]></description><link>https://forum.mysensors.org/post/37938</link><guid isPermaLink="true">https://forum.mysensors.org/post/37938</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Wed, 27 Apr 2016 18:52:40 GMT</pubDate></item></channel></rss>
