<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Makefile arduino-mk]]></title><description><![CDATA[<p dir="auto">Hello I've been using the arduino-mk Makefile for my project instead of using the IDE as I generally program using vim anyhow, why fire up the IDE when you can just 'make' and<br />
'make upload'?</p>
<p dir="auto">Anyhow, I'm also interested in this project.  But when I combine the two I get errors like:</p>
<pre><code>fatal error: MySensor.h: No such file or directory
</code></pre>
<p dir="auto">my Makefile is pretty simplistic:</p>
<pre><code>include /home/george/git/Arduino-Makefile/Arduino.mk
ARDUINO_LIBS     = SPI MySensors DHT
</code></pre>
<p dir="auto">USER_LIB_PATH is computed to be:</p>
<pre><code>- [DEFAULT]            USER_LIB_PATH = /home/thoth/sketchbook/libraries
</code></pre>
<p dir="auto">and the MySensors folder is in there:</p>
<pre><code>ls ~/sketchbook/libraries/MySensors
core  drivers  examples  keywords.txt  library.json  library.properties  MyConfig.h  MySensor.h  tests
</code></pre>
<p dir="auto">Is anyone else using the arduino-mk Makefile?  And if so any hints as to what might be wrong here?</p>
<p dir="auto">note I've tried with latest everything on Archlinux, and using a docker container with debian jessie here:<br />
<a href="https://github.com/joshuacox/mkarduino" rel="nofollow ugc">https://github.com/joshuacox/mkarduino</a></p>
<p dir="auto">same result in both environments</p>
<p dir="auto">*Note in debian I use this include line:</p>
<pre><code>include /usr/share/arduino/Arduino.mk
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/3786/makefile-arduino-mk</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 18:02:28 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3786.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 May 2016 00:16:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Makefile arduino-mk on Mon, 20 Jun 2016 14:19:55 GMT]]></title><description><![CDATA[<p dir="auto">I don't seem to be getting any replies here, so I'm moving to github here:<br />
<a href="https://github.com/mysensors/Arduino/issues/480" rel="nofollow ugc">https://github.com/mysensors/Arduino/issues/480</a></p>
]]></description><link>https://forum.mysensors.org/post/41422</link><guid isPermaLink="true">https://forum.mysensors.org/post/41422</guid><dc:creator><![CDATA[Josh Cox]]></dc:creator><pubDate>Mon, 20 Jun 2016 14:19:55 GMT</pubDate></item></channel></rss>
