<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Witch temp&#x2F;hum sensor is best to use for battery powered sensors?]]></title><description><![CDATA[<p dir="auto">I know there are a lot of different temp/hum sensors but witch kind is best to use in a battery powered sensor?</p>
]]></description><link>https://forum.mysensors.org/topic/3801/witch-temp-hum-sensor-is-best-to-use-for-battery-powered-sensors</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:45:16 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3801.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 May 2016 05:25:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Witch temp&#x2F;hum sensor is best to use for battery powered sensors? on Thu, 05 May 2016 17:59:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/awi" aria-label="Profile: AWI">@<bdi>AWI</bdi></a> I fully agree! The AM2302 (aka DHT-22) does not work, when the supply drops slightly below 3.3V, while the AM2321works at much lower voltage. I have used the AM2321 for more than 6 months to monitor my greenhouse</p>
]]></description><link>https://forum.mysensors.org/post/38464</link><guid isPermaLink="true">https://forum.mysensors.org/post/38464</guid><dc:creator><![CDATA[chrille]]></dc:creator><pubDate>Thu, 05 May 2016 17:59:05 GMT</pubDate></item><item><title><![CDATA[Reply to Witch temp&#x2F;hum sensor is best to use for battery powered sensors? on Tue, 03 May 2016 06:33:04 GMT]]></title><description><![CDATA[<p dir="auto">I use HTU21 without power regulator. directly battery operated with 2 pcs AA batteries/elements, have been working for a few months now.<br />
Just set sleep to maybe 5 min and do reading, if reading = old reading goto sleep again. else send reading to controller.<br />
This saves your battery usage</p>
]]></description><link>https://forum.mysensors.org/post/38347</link><guid isPermaLink="true">https://forum.mysensors.org/post/38347</guid><dc:creator><![CDATA[bjacobse]]></dc:creator><pubDate>Tue, 03 May 2016 06:33:04 GMT</pubDate></item><item><title><![CDATA[Reply to Witch temp&#x2F;hum sensor is best to use for battery powered sensors? on Tue, 03 May 2016 05:48:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cliff-karlsson" aria-label="Profile: Cliff-Karlsson">@<bdi>Cliff-Karlsson</bdi></a> use an i2C model <em>BME280</em>/Si7021/ SHT21/ HTU21. These work on low voltages and consume minimal. You can find boards with or without voltage regulator and/or pull-up's on Ali.  Take a look at a great <a href="http://www.kandrsmith.org/RJS/Misc/Hygrometers/calib_many.html" rel="nofollow ugc">study</a> which compares many of the sensors available.<br />
<img src="/uploads/files/1462254372658-upload-79a354cb-d5fe-4348-a646-54119c97bd55" alt="0_1462254372062_upload-79a354cb-d5fe-4348-a646-54119c97bd55" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/post/38344</link><guid isPermaLink="true">https://forum.mysensors.org/post/38344</guid><dc:creator><![CDATA[AWI]]></dc:creator><pubDate>Tue, 03 May 2016 05:48:25 GMT</pubDate></item></channel></rss>
