<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Reboot Node]]></title><description><![CDATA[<p dir="auto">Hi.<br />
If good understand then Watchdog is used for low powre timer , when use .sleep function then use this timer for max 8s .<br />
But I need reboot Node . Then how can I do that ?<br />
I use BCD encoder for manuany set  Node ID . If want chagne ID then powr Off battery and change position on BCD encoder .. and Powr On and Node set new ID .<br />
But I want do it in my loop function .. if change BCD encoder then in loop I compare BCD ID with Node ID if not equal then<br />
I want reboot node .</p>
<p dir="auto">but how to do it if watch dog is used for timer not reset ??</p>
<p dir="auto">how use funtion gw.reboot();  ???</p>
<p dir="auto">regards ..</p>
]]></description><link>https://forum.mysensors.org/topic/3925/reboot-node</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 11:17:45 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3925.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 May 2016 17:34:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Reboot Node on Sat, 21 May 2016 08:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dzairo" aria-label="Profile: dzairo">@<bdi>dzairo</bdi></a> search the Web for rebooting arduino from code. There are many ways each with its own (dis) advantages.</p>
]]></description><link>https://forum.mysensors.org/post/39455</link><guid isPermaLink="true">https://forum.mysensors.org/post/39455</guid><dc:creator><![CDATA[AWI]]></dc:creator><pubDate>Sat, 21 May 2016 08:01:02 GMT</pubDate></item></channel></rss>
