<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Battery Level and Step Up Power Converter]]></title><description><![CDATA[<p dir="auto">I don't think this was discussed before so here are the questions:</p>
<p dir="auto">How would I know the battery level if I measure it before the step up power converter.</p>
<p dir="auto">If I am correct I can not use the 1.1 reference because the supplied current is always the same.</p>
<p dir="auto">Is it as simple as compare the input on A0 (in the sample) with the measured current using my multi meter?</p>
<p dir="auto">Would the formula be comparable if I use 2 x 10MOhm resistors instead of what is mentioned 1MOhm and 470KOhm.</p>
]]></description><link>https://forum.mysensors.org/topic/435/battery-level-and-step-up-power-converter</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:31:14 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/435.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Sep 2014 21:00:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Battery Level and Step Up Power Converter on Sat, 04 Oct 2014 14:01:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marceltrapman" aria-label="Profile: marceltrapman">@<bdi>marceltrapman</bdi></a><br />
Good question, one in which I have no answer.  My sensors typically return ~75% for 2 fully charged AA batteries.</p>
]]></description><link>https://forum.mysensors.org/post/5246</link><guid isPermaLink="true">https://forum.mysensors.org/post/5246</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sat, 04 Oct 2014 14:01:15 GMT</pubDate></item><item><title><![CDATA[Reply to Battery Level and Step Up Power Converter on Sun, 28 Sep 2014 07:20:25 GMT]]></title><description><![CDATA[<p dir="auto">@ServiceXp said:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marceltrapman" aria-label="Profile: marceltrapman">@<bdi>marceltrapman</bdi></a> I take "before" as before the converter as in off the battery directly?</p>
</blockquote>
<p dir="auto">That is exactly what I mean :)</p>
<blockquote>
<p dir="auto">I use the Vin post on the converter to supply the battery sense circuit.</p>
</blockquote>
<p dir="auto">What I fail to see, probably my ignorance, is how I can recalculate the outputted value on A0 (in case of the example) to a value that really represents the battery level.</p>
]]></description><link>https://forum.mysensors.org/post/5058</link><guid isPermaLink="true">https://forum.mysensors.org/post/5058</guid><dc:creator><![CDATA[marceltrapman]]></dc:creator><pubDate>Sun, 28 Sep 2014 07:20:25 GMT</pubDate></item><item><title><![CDATA[Reply to Battery Level and Step Up Power Converter on Sat, 27 Sep 2014 23:12:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marceltrapman" aria-label="Profile: marceltrapman">@<bdi>marceltrapman</bdi></a><br />
I'm not sure I understand.. I take "before" as before the converter as in off the battery directly? Do you mean something else?</p>
]]></description><link>https://forum.mysensors.org/post/5046</link><guid isPermaLink="true">https://forum.mysensors.org/post/5046</guid><dc:creator><![CDATA[RJ_Make]]></dc:creator><pubDate>Sat, 27 Sep 2014 23:12:16 GMT</pubDate></item></channel></rss>
