<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Code that was send by mysensor devices]]></title><description><![CDATA[<p dir="auto">Hello.<br />
I habe build my own Sensors with Attiny85 and 433Mhz Sender.<br />
Im new in FHEM and i will use mysensors.<br />
My attiny Sensors only send 5 digit number.<br />
Device, Temp, Hum...and special code for alarm.<br />
Now i will emulate mysensors output.<br />
I dont understand this at the moment.<br />
What will be send at the Start?<br />
Is there a code so that FHEM autocreate this Sensor?<br />
What will be send if it is a temp Sensor?</p>
<p dir="auto">Can anyone give me an example?<br />
Many thanks....hope you unterstand my bad english</p>
]]></description><link>https://forum.mysensors.org/topic/4841/code-that-was-send-by-mysensor-devices</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:04:18 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/4841.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Sep 2016 04:06:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Code that was send by mysensor devices on Tue, 13 Sep 2016 08:58:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fleischtorte" aria-label="Profile: Fleischtorte">@<bdi>Fleischtorte</bdi></a><br />
OK this will help.<br />
I think i flash the mysensor code to an Arduino and let him talk to serial monitor, so i can see it better.<br />
Nice Nick...was für ein Name :-)</p>
]]></description><link>https://forum.mysensors.org/post/47587</link><guid isPermaLink="true">https://forum.mysensors.org/post/47587</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 13 Sep 2016 08:58:06 GMT</pubDate></item><item><title><![CDATA[Reply to Code that was send by mysensor devices on Tue, 13 Sep 2016 07:04:58 GMT]]></title><description><![CDATA[<p dir="auto">@ArduPino check this site <a href="https://www.mysensors.org/download/serial_api_20" rel="nofollow ugc">https://www.mysensors.org/download/serial_api_20</a></p>
]]></description><link>https://forum.mysensors.org/post/47583</link><guid isPermaLink="true">https://forum.mysensors.org/post/47583</guid><dc:creator><![CDATA[Fleischtorte]]></dc:creator><pubDate>Tue, 13 Sep 2016 07:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to Code that was send by mysensor devices on Tue, 13 Sep 2016 06:48:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m26872" aria-label="Profile: m26872">@<bdi>m26872</bdi></a><br />
Hello...und ja ich spreche Deutsch :)<br />
I think my question was not good.<br />
I want to know what data will be send from this mysensor things.<br />
I see somithing like this:<br />
12;0;6;0;25.5<br />
At the start the mysensor Sensor will send an other code.<br />
I will emulate this codes, but i dont know the right structure for the start.</p>
<p dir="auto">I think its the wrong forum here</p>
]]></description><link>https://forum.mysensors.org/post/47582</link><guid isPermaLink="true">https://forum.mysensors.org/post/47582</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 13 Sep 2016 06:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to Code that was send by mysensor devices on Tue, 13 Sep 2016 05:59:26 GMT]]></title><description><![CDATA[<p dir="auto">I don't know about MySensors v2.0.x, I've only used v1.5.x (and v1.4.x for Eth-gateway). Fhem autocreate will work once you've defined a MySensors gateway, activated autocreate and switched on inclusion mode. Creation and readings will be recieved from normal MySensors standard examples (don't know anything about Attiny85 though, only Atmega328p).</p>
<p dir="auto"><a href="https://forum.mysensors.org/topic/540/fhem/14">Fhem start guide</a> should be enough regarding the Fhem config.</p>
<p dir="auto">In general, as you can see, the Fhem section of the MySensors forum isn't very energetic. If you speak german you'll find more info and help over at the Fhem-forum.</p>
]]></description><link>https://forum.mysensors.org/post/47579</link><guid isPermaLink="true">https://forum.mysensors.org/post/47579</guid><dc:creator><![CDATA[m26872]]></dc:creator><pubDate>Tue, 13 Sep 2016 05:59:26 GMT</pubDate></item></channel></rss>
